メインコンテンツにスキップ
Muffled Microphone
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Muffled Microphone, Muffled Microphone: 手順 1、 2の画像 1 Muffled Microphone, Muffled Microphone: 手順 1、 2の画像 2
    • The frame of this iMac model is identical to its 2012-2015 predecessors, except that the microphone is behind the bottom-right edge of the display.
    • In this new position, the "4R" strip completely covers the microphone and the holes in front of it, deadening any sound picked up.
  2. Muffled Microphone: 手順 2、 1の画像 1
    • Use scissors to cut off the part of the adhesive strip that will cover the microphone.
    • Continue with adhesive installation and reassembly as instructed.
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Oros
メンバー登録日: 03/13/17
6,563 ポイント
1ガイドが承認済み
チーム
SoroS SoroS人のメンバー
Business
2 メンバー
1のガイドは作成済み
5 件のコメント
I just bought the new custom iMac 2017 and it has very muffled microphone, kind of disappointed...
Alexander Borisenko - 返信
Yes, me too… I bought one 4k iMac 2017 and every-time when I try to talk to someone on FaceTime and Discord, the other people on the call never listen me… For me especially, is so much disappoint, because I'm from brazil and 1 iMac price here, it's like 3 or 4 at the USA.
Matheus Cabral Rosa -
Hey Oros,
It’s awesome that you’ve started a guide for this. It’s such an essential issue, and I never seemed to get around to doing it myself. I was wondering if, maybe, you could mention me somewhere. Not anything lengthy; it would just be a nice for me to feel like I contributed. Especially since I see that you used some of what I wrote from my forum post (Muffled Microphone - iMac 21.5" (mid 2017) - Following Adhesive Strips) directly in this guide, verbatim. Don’t get me wrong… I think it’s great and I have no problem with it. But it would be nice to see my name floating around somewhere. :)
Warren Wilson - 返信
Sorry but this solution does not work! I encountered this problem after upgrading my imac 27 2017, even after cutting these stripes, the sound quality is still VERY poor (as if you were speak into a pipe), Siri works bad, Skype constantly reduces the sensitivity of the microphone to a minimum (apparently because it registers some noise from inside)
I guess the problem is that the sound from the inside of the imac should not get on the microphone and most likely there are two microphones installed - one for noise canceling the other for capturing sound and they need to be separated, the original strips that Apple uses have a small cutout in the center, insulating the microphone somehow [|https://ibb.co/kABrEo], Dear iFixit I beg you to find a solution to this problem, at the moment it's very difficult to use the built-in microphone
Thank you!
Dmitry Sukhov - 返信
Like Dmitry I have the same problem. First time I completely went over the microphone. Second time I cut out the pice over the mic and now its works but the quality is really bad indeed like an echo chamber. I wonder what was the original adhesive doing differently? I am waiting before i go in for a third time.
Would love it if somebody can post their solution! :-)
Thank you
maarten B - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 12
今までの合計 1,088
