はじめに
If you are having issues with the Moto Z2 Force's motherboard, use this guide to replace it.
パーツ
パーツは指定されていません。
Place the phone on a flat surface with the screen facing up.
Insert the flat end of a nylon spudger into the crease separating the screen and the body in the lower right corner of the phone.
Pry open part of the screen by pulling the tool and the screen toward you.
Wedge the plastic opening tool between the gap created by separating the screen and body of the phone in the right hand corner to hold it open.
Insert the nylon spudger into the lower left corner of the screen and pry the screen toward you.
Continue to insert the plastic opening and spudger tools around the phone, and pry open the screen until it is fully separated from the device.
Insert the flat end of the nylon spudger on the side of the rear facing camera closest to the battery.
Pry up the camera by pushing down on the spudger until the camera pops up.
3 の人々がこのガイドを完成させました。
3 件のコメント
My lcd came apart the entire assembly didn't come up as the instructions showed it would and it tore the ribbon connector.
This phone is not a good first DIY for anyone. I’ve been repairing phones since years and i separated the AMOLED panel from it’s frame too. Lucky me i was gently, used a lot of heat and flooded it with IPA so i could still re use this panel, but i realized it can be a pain in the ass for someone less expert than me.
Rafael B -
