メインコンテンツにスキップ
Motorola Moto X4 Rear Camera Replacement
必要な工具と部品
  1. Motorola Moto X4 Rear Camera Replacement, Heat the screen: 手順 1、 2の画像 1 Motorola Moto X4 Rear Camera Replacement, Heat the screen: 手順 1、 2の画像 2
    • Before you begin, turn off your phone.
    • Heat an iOpener and apply it to the left edge of the phone for two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take note of the the following areas:
    • Display cable—be careful not to slice too deeply near the edge here, or you may damage the display cable.
    • Fingerprint sensor cable—be careful not to slice too deeply near the edge here, or you may damage the fingerprint sensor cable.
  2. Motorola Moto X4 Rear Camera Replacement, Create a gap: 手順 2、 3の画像 1 Motorola Moto X4 Rear Camera Replacement, Create a gap: 手順 2、 3の画像 2 Motorola Moto X4 Rear Camera Replacement, Create a gap: 手順 2、 3の画像 3
    • Apply a suction cup to the screen, as close to the heated edge as possible.
    • Pull on the suction cup with strong, steady force to create a gap in the seam.
    • Insert the point of an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
  3. Motorola Moto X4 Rear Camera Replacement, Slice the screen adhesive: 手順 3、 3の画像 1 Motorola Moto X4 Rear Camera Replacement, Slice the screen adhesive: 手順 3、 3の画像 2 Motorola Moto X4 Rear Camera Replacement, Slice the screen adhesive: 手順 3、 3の画像 3
    • Slide the opening pick along the edge to slice through the adhesive.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
  4. Motorola Moto X4 Rear Camera Replacement: 手順 4、 3の画像 1 Motorola Moto X4 Rear Camera Replacement: 手順 4、 3の画像 2 Motorola Moto X4 Rear Camera Replacement: 手順 4、 3の画像 3
    • Heat the top edge of the phone with an iOpener.
    • Carefully slice around the corner and through the top edge to separate the adhesive.
  5. Motorola Moto X4 Rear Camera Replacement: 手順 5、 3の画像 1 Motorola Moto X4 Rear Camera Replacement: 手順 5、 3の画像 2 Motorola Moto X4 Rear Camera Replacement: 手順 5、 3の画像 3
    • Heat the screen's right edge with an iOpener.
    • Be careful not to slice too deeply near the cables to avoid damaging them.
    • Use an opening pick to slice along the right edge to separate the adhesive.
  6. Motorola Moto X4 Rear Camera Replacement: 手順 6、 2の画像 1 Motorola Moto X4 Rear Camera Replacement: 手順 6、 2の画像 2
    • Repeat the previous steps to heat and slice the bottom edge of the phone.
  7. Motorola Moto X4 Rear Camera Replacement: 手順 7、 2の画像 1 Motorola Moto X4 Rear Camera Replacement: 手順 7、 2の画像 2
    • Do not try to remove the screen yet—it is still attached to the phone by delicate flex cables.
    • Carefully lift up the left edge of the screen and cut away remaining adhesives with an opening pick.
  8. Motorola Moto X4 Rear Camera Replacement: 手順 8、 1の画像 1
    • Swing open the screen and prop it up with a small box as you work on disconnecting the flex cables.
    • During reassembly, this is a good time to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  9. Motorola Moto X4 Rear Camera Replacement, Detach the fingerprint sensor cable: 手順 9、 2の画像 1 Motorola Moto X4 Rear Camera Replacement, Detach the fingerprint sensor cable: 手順 9、 2の画像 2
    • Slide the point of a spudger underneath the fingerprint sensor cable and gently pry up to loosen the cable from the phone.
    • Do not pull on the cable. It is still attached to the phone by a delicate ZIF socket.
  10. Motorola Moto X4 Rear Camera Replacement, Disconnect the fingerprint sensor: 手順 10、 3の画像 1 Motorola Moto X4 Rear Camera Replacement, Disconnect the fingerprint sensor: 手順 10、 3の画像 2 Motorola Moto X4 Rear Camera Replacement, Disconnect the fingerprint sensor: 手順 10、 3の画像 3
    この手順で使用する道具:
    購入する
    • Use the point of a spudger to flip up the lock bar on the fingerprint sensor's ZIF socket, near the bottom right of the phone.
    • Use tweezers to carefully slide the fingerprint sensor cable out of the socket.
  11. Motorola Moto X4 Rear Camera Replacement, Disconnect the display cable: 手順 11、 3の画像 1 Motorola Moto X4 Rear Camera Replacement, Disconnect the display cable: 手順 11、 3の画像 2 Motorola Moto X4 Rear Camera Replacement, Disconnect the display cable: 手順 11、 3の画像 3
    • Use an opening tool to flip up the wide lock bar on the display cable's ZIF socket, near the top right of the phone.
    • Use tweezers to carefully slide the display cable out of the ZIF socket.
  12. Motorola Moto X4 Rear Camera Replacement, Remove the screen: 手順 12、 2の画像 1 Motorola Moto X4 Rear Camera Replacement, Remove the screen: 手順 12、 2の画像 2
    • Remove the screen.
    • During reassembly, follow this guide to clean the existing adhesive off and install custom-cut adhesives for your phone.
  13. Motorola Moto X4 Rear Camera Replacement, Unscrew the midframe: 手順 13、 2の画像 1 Motorola Moto X4 Rear Camera Replacement, Unscrew the midframe: 手順 13、 2の画像 2
    • Remove the following twenty screws securing the midframe:
    • Eleven silver 2.7 mm-long T3 screws
    • Nine black 3.6 mm-long T4 screws
    • The midframe is still held in place by clips.
  14. Motorola Moto X4 Rear Camera Replacement, Loosen the midframe: 手順 14、 3の画像 1 Motorola Moto X4 Rear Camera Replacement, Loosen the midframe: 手順 14、 3の画像 2 Motorola Moto X4 Rear Camera Replacement, Loosen the midframe: 手順 14、 3の画像 3
    • The next few steps show how to loosen the midframe clips.
    • Insert the flat end of a spudger under the right edge of the metal midframe and pry up to loosen the midframe.
    • Insert an opening pick in the edge to hold the midframe in place.
  15. Motorola Moto X4 Rear Camera Replacement: 手順 15、 2の画像 1 Motorola Moto X4 Rear Camera Replacement: 手順 15、 2の画像 2
    • Insert the flat end of a spudger under the lower right edge of the midframe and pry up to release the midframe clip.
  16. Motorola Moto X4 Rear Camera Replacement: 手順 16、 3の画像 1 Motorola Moto X4 Rear Camera Replacement: 手順 16、 3の画像 2 Motorola Moto X4 Rear Camera Replacement: 手順 16、 3の画像 3
    • Grasp the lower edge of the midframe and pull the edge slightly to the right, to clear the metal midframe clip.
  17. Motorola Moto X4 Rear Camera Replacement: 手順 17、 2の画像 1 Motorola Moto X4 Rear Camera Replacement: 手順 17、 2の画像 2
    • Insert the point of an opening pick under the top left corner of the midframe and twist slightly to release the top clip.
  18. Motorola Moto X4 Rear Camera Replacement, Remove the midframe: 手順 18、 3の画像 1 Motorola Moto X4 Rear Camera Replacement, Remove the midframe: 手順 18、 3の画像 2 Motorola Moto X4 Rear Camera Replacement, Remove the midframe: 手順 18、 3の画像 3
    • Remove the midframe.
    • To reinstall the midframe:
    • Align the the midframe's top edge to the phone and press it into position.
    • Shift the bottom edge slightly to the left, to maneuver the left metal midframe clip underneath the phone edge.
    • Press the midframe's bottom edge into position.
  19. Motorola Moto X4 Rear Camera Replacement, Disconnect the battery: 手順 19、 2の画像 1 Motorola Moto X4 Rear Camera Replacement, Disconnect the battery: 手順 19、 2の画像 2
    • Insert the point of a spudger underneath the top edge of the battery connector.
    • Be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Gently pry up the connector to disconnect the battery.
  20. Motorola Moto X4 Rear Camera Replacement: 手順 20、 3の画像 1 Motorola Moto X4 Rear Camera Replacement: 手順 20、 3の画像 2 Motorola Moto X4 Rear Camera Replacement: 手順 20、 3の画像 3
    • To re-connect the battery, align the connector on top of the socket, and press it down with your finger or a spudger.
  21. Motorola Moto X4 Rear Camera Replacement, Rear Camera: 手順 21、 2の画像 1 Motorola Moto X4 Rear Camera Replacement, Rear Camera: 手順 21、 2の画像 2
    • Using a T3 Torx screwdriver, remove both 1cm screws. To do this, insert the screwdriver into the head of the screw, then turn counter-clockwise.
  22. Motorola Moto X4 Rear Camera Replacement: 手順 22、 2の画像 1 Motorola Moto X4 Rear Camera Replacement: 手順 22、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use the tweezers to gently lift the rear camera up and out of your Moto X4.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto X4 Answers community for help.
3 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Brian Buchanan
メンバー登録日: 01/24/18
1,047 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team S18-G4, Livingston Winter 2018 Cal Poly, Team S18-G4, Livingston Winter 2018人のメンバー
CPSU-LIVINGSTON-W18S18G4
4 メンバー
13のガイドは作成済み
コメント 1 件
I'm up based anyone know where I can get a replacement camera
Ashley Fall - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 17
今までの合計 3,404
