はじめに
The Motorola Moto G6 features a rear-facing camera (the circular glass protrusion on the back of the device). This component allows the user to take photos while looking at the screen of their phone. If your rear-facing camera is shattered, scratched, or otherwise beyond repair, it will need to be replaced. Use this guide to install a new camera into your Moto G6.
This guide teaches how to perform a rear-facing camera replacement. No repair experience is required. However, this replacement will require tools to remove the needed components of the device. The specific device model in this guide is XT1925-12. Other model numbers include: XT1925-4, XT1925-5, XT1925-6, and XT1925DL.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Before beginning the repair, make sure the device is turned off and disconnected from an external power source. Gather the suggested tools listed below and a new Motorola Moto G6 rear-facing camera.
必要な工具と部品
If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
Use a Phillips driver to remove seventeen screws securing the plastic cover:
Eleven grey 3 mm-long screws
Five black 2.5 mm-long screws
One silver 3.5 mm-long screw
Using the iFixit opening tool, pop up the three press-fit connectors in the bottom right corner of the motherboard.
Begin with both the back shell and the motherboard of the Motorola Moto G6 removed and set aside. Your device should look like the photo to the left at this point in the process.
3 の人々がこのガイドを完成させました。
