メインコンテンツにスキップ
Motorola Moto G 1st Generation Battery Replacement
必要な工具と部品
  1. Motorola Moto G 1st Generation Battery Replacement, Rear Panel: 手順 1、 3の画像 1 Motorola Moto G 1st Generation Battery Replacement, Rear Panel: 手順 1、 3の画像 2 Motorola Moto G 1st Generation Battery Replacement, Rear Panel: 手順 1、 3の画像 3
    • Before you start following any of the steps of this guide, completely turn the device off.
    • Take the plastic back cover off by either using a plastic Pry tool or simply using your hands. Start from the bottom by the charging port
    • Remove any installed SIM card and memory microSD cards.
    • Push the SIM card into the phone, and the spring eject mechanism should release the card.
    • The microSD memory card(s) may not have an eject mechanism. If so, they must be removed carefully by pushing on the raised edge/bump that is built onto the card. Use your fingernail or a plastic or rubber tool, but not one that will scratch and damage the delicate card.
    • Patience must be taken to prevent irreversible damage and loss of data on the card.
  2. Motorola Moto G 1st Generation Battery Replacement, Removing the Screws: 手順 2、 1の画像 1
    • Unscrew the 3.5mm screws, total of 14, located on the back protective cover by using a T5 Torx screwdriver.
    Warning: The SIM card and microSD memory cards MUST BE REMOVED to complete the next step (Step 3 Battery Cover).
    If they are not removed before prying away the battery cover, they may be damaged, and important data may be destroyed (cannot be recovered)!!
    Failure to remove them will also make removing the battery cover in Step 3 difficult, if not impossible.
    FixWiki - 返信
  3. Motorola Moto G 1st Generation Battery Replacement, Battery Cover: 手順 3、 2の画像 1 Motorola Moto G 1st Generation Battery Replacement, Battery Cover: 手順 3、 2の画像 2
    • Use a plastic opening tool to remove the protective cover.
    • Carefully work the plastic tool around all the edges of the phone.
    • The protective cover holds the Volume and the Home buttons which might fall off the assembly when the cover is removed.
  4. Motorola Moto G 1st Generation Battery Replacement, Disconnecting the Battery: 手順 4、 2の画像 1 Motorola Moto G 1st Generation Battery Replacement, Disconnecting the Battery: 手順 4、 2の画像 2
    • Disconnect the connection between the Battery and the Mother Board by using the Pry tool.
  5. Motorola Moto G 1st Generation Battery Replacement, Removing the Battery: 手順 5、 2の画像 1 Motorola Moto G 1st Generation Battery Replacement, Removing the Battery: 手順 5、 2の画像 2
    • With the battery already disconnected,work around its edge with the pry tool to remove it from the assembly.
    • The battery is attached with a sticker, so it may take some work to pry up. Just work at it slowly and carefully until you get it.
終わりに
3 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Radostin Lobodov
メンバー登録日: 10/16/14
2,904 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-7, Vijaybhaskar Fall 2014人のメンバー
UMASSD-VIJAYBHASKAR-F14S5G7
3 メンバー
8のガイドは作成済み
1 Guide Comment
Hello!
I have just completed this operation. I would like you to know that my Moto G 1st Generation needed a T4 Torx screwdriver.
Other than that, everything went fine!
Best Wishes,
Bubba G
Bubba G - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 29
今までの合計 4,220
