はじめに
The LCD Screen Replacement is one of the trickier guides. The LCD screen is attached on adhesive foam tape that may be difficult to pry off. However, once you are able to remove the LCD Screen, the replacement itself is fairly simple.
必要な工具と部品
Using the Phillips #1 screwdriver, remove the battery cover screw.
Remove the battery cover from its hinges and set aside.
Using the Phillips #1 screwdriver, remove the 7mm screw under the battery cover.
Using the blue plastic opening tools, begin prying open the corners and disconnecting the seven clasps around the edges of the parent unit.
3 の人々がこのガイドを完成させました。
