メインコンテンツにスキップ
Motorola Droid Turbo Display Assembly Replacement
必要な工具と部品
  1. Motorola Droid Turbo Display Assembly Replacement, Rear Case: 手順 1、 1の画像 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
  2. Motorola Droid Turbo Display Assembly Replacement: 手順 2、 2の画像 1 Motorola Droid Turbo Display Assembly Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
  3. Motorola Droid Turbo Display Assembly Replacement, Midframe: 手順 3、 1の画像 1
    • Remove the midframe bezel.
  4. Motorola Droid Turbo Display Assembly Replacement: 手順 4、 1の画像 1
    • Remove the four Torx T5 screws securing the midframe plate.
  5. Motorola Droid Turbo Display Assembly Replacement: 手順 5、 1の画像 1
    • Remove the midframe.
  6. Motorola Droid Turbo Display Assembly Replacement, Earpiece Speaker: 手順 6、 2の画像 1 Motorola Droid Turbo Display Assembly Replacement, Earpiece Speaker: 手順 6、 2の画像 2
    • Use a Jimmy to pry under the speaker and lift to remove it.
    • Be sure to place your tool under the entire speaker assembly, against the plastic frame, and pry there.
    • These photos show an incorrect tool position—prying this high up on the speaker assembly may damage it. Place your tool underneath the speaker assembly, not on the edge as shown here.
    • The speaker is secured with some light adhesive, so some force may be required.
  7. Motorola Droid Turbo Display Assembly Replacement, Battery: 手順 7、 2の画像 1 Motorola Droid Turbo Display Assembly Replacement, Battery: 手順 7、 2の画像 2
    • Use the point of a spudger to pop up the battery connector.
  8. Motorola Droid Turbo Display Assembly Replacement: 手順 8、 2の画像 1 Motorola Droid Turbo Display Assembly Replacement: 手順 8、 2の画像 2
    • Fold the wireless charging coil away from the battery.
  9. Motorola Droid Turbo Display Assembly Replacement: 手順 9、 2の画像 1 Motorola Droid Turbo Display Assembly Replacement: 手順 9、 2の画像 2
    • Use a spudger to gently pry the battery up from the rest of the device.
    • The battery is secured with some moderate adhesive, so some force may be necessary.
  10. Motorola Droid Turbo Display Assembly Replacement, Display Assembly: 手順 10、 1の画像 1
    • Remove the four Torx T5 screws securing the lower antenna board to the motherboard.
  11. Motorola Droid Turbo Display Assembly Replacement: 手順 11、 2の画像 1 Motorola Droid Turbo Display Assembly Replacement: 手順 11、 2の画像 2
    • Remove the lower antenna board.
  12. Motorola Droid Turbo Display Assembly Replacement: 手順 12、 2の画像 1 Motorola Droid Turbo Display Assembly Replacement: 手順 12、 2の画像 2
    • Remove the SIM card holder/volume button rocker.
  13. Motorola Droid Turbo Display Assembly Replacement: 手順 13、 2の画像 1 Motorola Droid Turbo Display Assembly Replacement: 手順 13、 2の画像 2
    • Carefully lift up the motherboard to expose the display connector.
  14. Motorola Droid Turbo Display Assembly Replacement: 手順 14、 2の画像 1 Motorola Droid Turbo Display Assembly Replacement: 手順 14、 2の画像 2
    • Use the flat end of a spudger to flip up the retaining flap on the display ZIF connector.
    • Pull the display ribbon cable free of the connector.
終わりに
17 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Geoff Wacker
メンバー登録日: 09/30/13
91,070 ポイント
89のガイドは作成済み
8 件のコメント
This has a bunch of unecessary steps and is missing so,e just kinda bricked my phone thanks to this
fake name - 返信
Yep. It repeats a bunch of steps, and seems to switch from replacing the display to replacing the motherboard. :(
Richard Klein -
has anyone ever had the buttons break on this phone? i know on my old droid maxx one little mistake when putting the board in the metal frame was enough to break the volume buttons.
Dudefoxlive - 返信
You don’t need to remove the battery from the board…the whole thing comes up as one.
Jason Stewart - 返信
What if your screen is glitchy after the install?
Help me J - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 9
今までの合計 16,806
