メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola Droid RAZR HD Power Button Replacement
必要な工具と部品
  1. Motorola Droid RAZR HD Power Button Replacement, Front Panel Assembly: 手順 1、 1の画像 1
    • Power off the device before disassembly to avoid damage or harm from electrical surges.
    • Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
    FixBotに聞いてみる
    コメントを追加
  2. Motorola Droid RAZR HD Power Button Replacement: 手順 2、 1の画像 1
    • Holding the device in your hand, push the screen towards the top of the phone until it disconnects from the base of the phone.
    FixBotに聞いてみる
    コメントを追加
  3. Motorola Droid RAZR HD Power Button Replacement: 手順 3、 1の画像 1
    • Use a plastic opening tool to lift the screen from the phone.
    • Do not try to completely detach the screen; cables are still connected to the device and can be damaged.
    FixBotに聞いてみる
    コメントを追加
  4. Motorola Droid RAZR HD Power Button Replacement: 手順 4、 2の画像 1 Motorola Droid RAZR HD Power Button Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • Use tweezers to remove the yellow tape covering the lcd/digitizer cable connector.
    • Carefully lift up the black locking tab to release the lcd/digitizer cable.
    • The cable connector is located on the bottom right section of the phone.
    FixBotに聞いてみる
    コメントを追加
  5. Motorola Droid RAZR HD Power Button Replacement: 手順 5、 1の画像 1
    • Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
    • This connector is located on the top right section of the phone.
    • Use tweezers to lift the black bar on top of the ZIF connector.
    • Pull the ribbon cable out of the connector with tweezers.
    • Now that there are no cables connecting the screen to the motherboard, remove the screen.
    FixBotに聞いてみる
    コメントを追加
  6. Motorola Droid RAZR HD Power Button Replacement, Rear Facing Camera: 手順 6、 2の画像 1 Motorola Droid RAZR HD Power Button Replacement, Rear Facing Camera: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Remove the two 3.5mm Torx T4 screws securing the rear facing camera.
    • Using tweezers, remove the metal shield protecting the rear facing camera.
    FixBotに聞いてみる
    コメントを追加
  7. Motorola Droid RAZR HD Power Button Replacement: 手順 7、 2の画像 1 Motorola Droid RAZR HD Power Button Replacement: 手順 7、 2の画像 2
    • Use a plastic opening tool to lift up the rear camera.
    • Use tweezers to lift and unlock the black bar on top of the rear camera's ZIF connector.
    • Pull the camera out of the connector.
    • You will need to unplug the rear camera from its connector on the motherboard.
    FixBotに聞いてみる
    コメントを追加
  8. Motorola Droid RAZR HD Power Button Replacement, Motherboard: 手順 8、 2の画像 1 Motorola Droid RAZR HD Power Button Replacement, Motherboard: 手順 8、 2の画像 2
    この手順で使用する道具:
    • Remove the two 3.5mm Torx T4 screws securing the headphone jack cable/cover.
    • Using tweezers, disconnect the headphone jack cable/cover and remove it. The headphone jack will stay where it is.
    • The metal shield is attached to the headphone jack.
    FixBotに聞いてみる
    コメントを追加
  9. Motorola Droid RAZR HD Power Button Replacement: 手順 9、 3の画像 1 Motorola Droid RAZR HD Power Button Replacement: 手順 9、 3の画像 2 Motorola Droid RAZR HD Power Button Replacement: 手順 9、 3の画像 3
    • Using a plastic opening tool or tweezers, disconnect the power button connector.
    • Carefully peel back the adhesive cable with the tweezers so it is not in the way of the motherboard.
    FixBotに聞いてみる
    コメントを追加
  10. Motorola Droid RAZR HD Power Button Replacement: 手順 10、 2の画像 1 Motorola Droid RAZR HD Power Button Replacement: 手順 10、 2の画像 2
    • Disconnect the battery from the motherboard by lifting up with the plastic opening tool near the base of the cable.
    • Bend the battery cable straight up and out of the way of the motherboard.
    FixBotに聞いてみる
    コメントを追加
  11. Motorola Droid RAZR HD Power Button Replacement: 手順 11、 2の画像 1 Motorola Droid RAZR HD Power Button Replacement: 手順 11、 2の画像 2
    • Using tweezers, peel back the adhesive covering the speaker connector.
    • Using tweezers, disconnect the speaker connector by lifting underneath the base of the connector.
    FixBotに聞いてみる
    コメントを追加
  12. Motorola Droid RAZR HD Power Button Replacement: 手順 12、 1の画像 1
    • Locate the sim card/micro sd tray on the side of the device.
    • Push a small rod, such as a paper clip or sim card tool, into the opening to eject and remove the tray.
    FixBotに聞いてみる
    コメントを追加
  13. Motorola Droid RAZR HD Power Button Replacement: 手順 13、 2の画像 1 Motorola Droid RAZR HD Power Button Replacement: 手順 13、 2の画像 2
    • Remove the six 3.5mm Torx T4 screws securing the motherboard to the device frame.
    • Carefully pry up the motherboard from the frame using a plastic opening tool.
    • Watch for obstructions such as loose cables.
    FixBotに聞いてみる
    コメントを追加
  14. Motorola Droid RAZR HD Power Button Replacement, Battery: 手順 14、 2の画像 1 Motorola Droid RAZR HD Power Button Replacement, Battery: 手順 14、 2の画像 2
    • Use a plastic opening tool to lift up the battery from the frame of the device.
    • Remove the battery.
    FixBotに聞いてみる
    コメントを追加
  15. Motorola Droid RAZR HD Power Button Replacement, Power Button: 手順 15、 1の画像 1
    • Remove the three 3.5mm Torx T3 screws holding the power/volume button cable to the side of the frame.
    FixBotに聞いてみる
    コメントを追加
  16. Motorola Droid RAZR HD Power Button Replacement: 手順 16、 2の画像 1 Motorola Droid RAZR HD Power Button Replacement: 手順 16、 2の画像 2
    この手順で使用する道具:
    • Using tweezers, remove the power/volume button flex cable.
    • Remove the flex cable from the metal bracket using a plastic opening tool.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
5 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Blake Nielsen
メンバー登録日: 04/14/15
536 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-4, Maness Spring 2015 Cal Poly, Team 4-4, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S4G4
5 メンバー
24のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 21
今までの合計 2,493
