メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Motorola Droid RAZR HD Front Panel Replacement
必要な工具と部品
  1. Motorola Droid RAZR HD Front Panel Replacement, Front Panel Assembly: 手順 1、 1の画像 1
    • Power off the device before disassembly to avoid damage or harm from electrical surges.
    • Remove the two 4.5mm screws in the bottom left and right corners of the device using a T4 Torx Screwdriver.
    FixBotに聞いてみる
    コメントを追加
  2. Motorola Droid RAZR HD Front Panel Replacement: 手順 2、 1の画像 1
    • Holding the device in your hand, push the screen towards the top of the phone until it disconnects from the base of the phone.
    FixBotに聞いてみる
    コメントを追加
  3. Motorola Droid RAZR HD Front Panel Replacement: 手順 3、 1の画像 1
    • Use a plastic opening tool to lift the screen from the phone.
    • Do not try to completely detach the screen; cables are still connected to the device and can be damaged.
    FixBotに聞いてみる
    コメントを追加
  4. Motorola Droid RAZR HD Front Panel Replacement: 手順 4、 2の画像 1 Motorola Droid RAZR HD Front Panel Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • Use tweezers to remove the yellow tape covering the lcd/digitizer cable connector.
    • Carefully lift up the black locking tab to release the lcd/digitizer cable.
    • The cable connector is located on the bottom right section of the phone.
    FixBotに聞いてみる
    コメントを追加
  5. Motorola Droid RAZR HD Front Panel Replacement: 手順 5、 1の画像 1
    • Lift up the screen further to reveal another cable at the top of the device connecting the motherboard to the screen.
    • This connector is located on the top right section of the phone.
    • Use tweezers to lift the black bar on top of the ZIF connector.
    • Pull the ribbon cable out of the connector with tweezers.
    • Now that there are no cables connecting the screen to the motherboard, remove the screen.
    FixBotに聞いてみる
    コメントを追加
  6. Motorola Droid RAZR HD Front Panel Replacement, Front Panel: 手順 6、 2の画像 1 Motorola Droid RAZR HD Front Panel Replacement, Front Panel: 手順 6、 2の画像 2
    この手順で使用する道具:
    • Remove the two 2.0mm T4 Torx screws near the top of the screen.
    • Remove the metal plate protecting the front camera and ear speaker with tweezers.
    FixBotに聞いてみる
    コメントを追加
  7. Motorola Droid RAZR HD Front Panel Replacement: 手順 7、 2の画像 1 Motorola Droid RAZR HD Front Panel Replacement: 手順 7、 2の画像 2
    • Using a plastic openining tool, lift up the front camera and ear speaker assembly.
    • Remove the assembly with tweezers.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Brendan Baronia
メンバー登録日: 04/14/15
681 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 4-4, Maness Spring 2015 Cal Poly, Team 4-4, Maness Spring 2015人のメンバー
CPSU-MANESS-S15S4G4
5 メンバー
24のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 36
今までの合計 2,015
