はじめに
Use this guide to replace the screen of your Motorola Moto C due to a defective LCD or broken front panel.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
You’ll need replacement adhesive to reattach components during reassembly.
必要な工具と部品
Insert a thumbnail, or spudger, into the notch on the bottom right corner to start separating the phone unit from the back cover.
Move it to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
Prepare an iOpener and apply it to the upper half of the display for at least two minutes to loosen the adhesive beneath the vibration motor and the rear facing camera.
Use a pair of tweezers to disconnect the antenna cable on the left of the daughterboard.
Prepare an iOpener and apply it to the bottom part of the display for at least two minutes to loosen the adhesive beneath the daughterboard.
Use a pair of tweezers to grab and remove the charging port rubber gasket.
Prepare an iOpener and apply it for at least two minutes on the back of the phone to loosen the adhesive tape that sits on top of the display flex cable.
2 の人々がこのガイドを完成させました。
