はじめに
Oftentimes the ear cushions get ripped, and these will eventually need to be replaced. This has been known to be a very common issue when using these headphones.
If they are not ripped, they may just need to be put back into place and potentially glued down. Doing all this is very easy and will not require more than 5 minutes of your time.
必要な工具と部品
Grab the ear cushion by the bottom, pull down, forward and then up to take off the cushion as a whole.
ある他の人がこのガイドを完成しました。
