メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Midiman Oxygen 8 Power Port Replacement
必要な工具と部品
  1. Midiman Oxygen 8 Power Port Replacement, Midiman Oxygen 8 Backplate Disassembly: 手順 1、 2の画像 1 Midiman Oxygen 8 Power Port Replacement, Midiman Oxygen 8 Backplate Disassembly: 手順 1、 2の画像 2
    • Remove the 8 mm M3 Phillips head self tapping machine screws.
    • Several of the screws are in narrow, deep sockets; make sure to use an appropriate screw driver to remove them so as not to damage the cover during removal.
    • Remove all 13 of the back plate screws.
    FixBotに聞いてみる
    コメントを追加
  2. Midiman Oxygen 8 Power Port Replacement: 手順 2、 2の画像 1 Midiman Oxygen 8 Power Port Replacement: 手順 2、 2の画像 2
    • Remove the two highlighted 10 mm M3 galvanized machine screws using the J1 head fro the iFixit Tool Kit or a comparable tool.
    FixBotに聞いてみる
    コメントを追加
  3. Midiman Oxygen 8 Power Port Replacement: 手順 3、 3の画像 1 Midiman Oxygen 8 Power Port Replacement: 手順 3、 3の画像 2 Midiman Oxygen 8 Power Port Replacement: 手順 3、 3の画像 3
    • Removal of Ribbon Cables
    • Prior to removal, note, mark, or take photo’s of the position of all connectors. Specifically note the side that the red wire is on, as ribbon cables are polarized cables that must be re-installed correctly. Installing the cables backwards may cause damage to the device or significantly hinder the troubleshooting process.
    • To separate the back plate, remove all five cables that connect to the motherboard but do not originate from the back plate; the key assembly, LCD circuit, rotor tuning circuit, and the pitch and modulator circuits. None of these cables require tools to remove, simply apply firm upward pressure to remove them.
    FixBotに聞いてみる
    コメントを追加
  4. Midiman Oxygen 8 Power Port Replacement: 手順 4、 2の画像 1 Midiman Oxygen 8 Power Port Replacement: 手順 4、 2の画像 2
    • Remove the key assembly from the key board.
    • What remains is the back plate and the top plate assemblies.
    FixBotに聞いてみる
    コメントを追加
  5. Midiman Oxygen 8 Power Port Replacement, Power Port: 手順 5、 1の画像 1
    • The power plug port in soldered onto the motherboard, and screwed onto the back plate.
    FixBotに聞いてみる
    コメントを追加
  6. Midiman Oxygen 8 Power Port Replacement: 手順 6、 1の画像 1
    • The battery power cord must be detached and removed from the motherboard prior to it being unsecured from the back plate.
    • Using the point tip of the black spudger tool, press into the gap between the plug and retaining clip in the socket, then gently pull on the plug wires to remove it from the socket.
    FixBotに聞いてみる
    コメントを追加
  7. Midiman Oxygen 8 Power Port Replacement: 手順 7、 2の画像 1 Midiman Oxygen 8 Power Port Replacement: 手順 7、 2の画像 2
    • There are 4 M1.5 x 3 screws that must be removed to separate the motherboard from the back plate.
    FixBotに聞いてみる
    コメントを追加
  8. Midiman Oxygen 8 Power Port Replacement: 手順 8、 1の画像 1
    • There are 3 solder points that connect the power socket to the motherboard, 2 electrical and 1 to secure the housing.
    • De-Solder the three connections to remove the old power port.
    • Solder on the new power port to complete the replacement.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Scott Miller
メンバー登録日: 10/04/16
437 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 1-6, Sullivan Fall 2016 USF Tampa, Team 1-6, Sullivan Fall 2016人のメンバー
USFT-SULLIVAN-F16S1G6
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 44
今までの合計 827
