メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Midiman Oxygen 8 LCD Screen Replacement
必要な工具と部品
    1. Midiman Oxygen 8 LCD Screen  Replacement, Midiman Oxygen 8 Backplate Disassembly: 手順 1、 2の画像 1 Midiman Oxygen 8 LCD Screen  Replacement, Midiman Oxygen 8 Backplate Disassembly: 手順 1、 2の画像 2
      • Remove the 8 mm M3 Phillips head self tapping machine screws.
      • Several of the screws are in narrow, deep sockets; make sure to use an appropriate screw driver to remove them so as not to damage the cover during removal.
      • Remove all 13 of the back plate screws.
      FixBotに聞いてみる
      コメントを追加
    2. Midiman Oxygen 8 LCD Screen  Replacement: 手順 2、 2の画像 1 Midiman Oxygen 8 LCD Screen  Replacement: 手順 2、 2の画像 2
      • Remove the two highlighted 10 mm M3 galvanized machine screws using the J1 head fro the iFixit Tool Kit or a comparable tool.
      FixBotに聞いてみる
      コメントを追加
    3. Midiman Oxygen 8 LCD Screen  Replacement: 手順 3、 3の画像 1 Midiman Oxygen 8 LCD Screen  Replacement: 手順 3、 3の画像 2 Midiman Oxygen 8 LCD Screen  Replacement: 手順 3、 3の画像 3
      • Removal of Ribbon Cables
      • Prior to removal, note, mark, or take photo’s of the position of all connectors. Specifically note the side that the red wire is on, as ribbon cables are polarized cables that must be re-installed correctly. Installing the cables backwards may cause damage to the device or significantly hinder the troubleshooting process.
      • To separate the back plate, remove all five cables that connect to the motherboard but do not originate from the back plate; the key assembly, LCD circuit, rotor tuning circuit, and the pitch and modulator circuits. None of these cables require tools to remove, simply apply firm upward pressure to remove them.
      FixBotに聞いてみる
      コメントを追加
    4. Midiman Oxygen 8 LCD Screen  Replacement: 手順 4、 2の画像 1 Midiman Oxygen 8 LCD Screen  Replacement: 手順 4、 2の画像 2
      • Remove the key assembly from the key board.
      • What remains is the back plate and the top plate assemblies.
      FixBotに聞いてみる
      コメントを追加
    1. Midiman Oxygen 8 LCD Screen  Replacement, LCD Screen: 手順 5、 1の画像 1
      • The LCD screen is attached to the same circuit as the Data Slide bar on the reverse of the front face plate.
      • Remove the four M1.5 x 3 screws
      FixBotに聞いてみる
      コメントを追加
    2. Midiman Oxygen 8 LCD Screen  Replacement: 手順 6、 1の画像 1
      • There are 12 contacts that must be de-soldered in order to remove the LCD screen,
      FixBotに聞いてみる
      コメントを追加
    3. Midiman Oxygen 8 LCD Screen  Replacement: 手順 7、 1の画像 1
      • Once the LCD screen has been de-soldered, it can be removed and replaced with a new screen.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Scott Miller
メンバー登録日: 10/04/16
437 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 1-6, Sullivan Fall 2016 USF Tampa, Team 1-6, Sullivan Fall 2016人のメンバー
USFT-SULLIVAN-F16S1G6
4 メンバー
6のガイドは作成済み
1件のガイドコメント
It’s an LED display, not an LCD screen.
Peter D - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 23
今までの合計 598
