メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Microsoft Zune 80 Hard Drive Replacement
必要な工具と部品
    1. Microsoft Zune 80 Hard Drive Replacement, Case: 手順 1、 1の画像 1
      • Use a metal spudger or Zune opening tool to remove the small silver plastic cap on top of the device.
      FixBotに聞いてみる
      コメントを追加
    2. Microsoft Zune 80 Hard Drive Replacement: 手順 2、 1の画像 1
      • There are two T3 screws under the cap. Remove both with a T3 screwdriver.
      • Be careful with removing these screws! These screwheads are prone to breaking.
      FixBotに聞いてみる
      コメントを追加
    3. Microsoft Zune 80 Hard Drive Replacement, Remove the Casing: 手順 3、 2の画像 1 Microsoft Zune 80 Hard Drive Replacement, Remove the Casing: 手順 3、 2の画像 2
      • Using a metal spudger or Zune opening tool, remove the aluminum backing starting from the top. There are 5 clips on each side and two on the bottom.
      • Be careful not to press the tools in too far; there are exposed cables right inside the edge of the device.
      FixBotに聞いてみる
      コメントを追加
    1. Microsoft Zune 80 Hard Drive Replacement, Remove the Silver Tape: 手順 4、 2の画像 1 Microsoft Zune 80 Hard Drive Replacement, Remove the Silver Tape: 手順 4、 2の画像 2
      • Remove the silver tape from the bottom center and the top right. This allows access to the hard drive and the battery.
      FixBotに聞いてみる
      コメントを追加
    2. Microsoft Zune 80 Hard Drive Replacement: 手順 5、 3の画像 1 Microsoft Zune 80 Hard Drive Replacement: 手順 5、 3の画像 2 Microsoft Zune 80 Hard Drive Replacement: 手順 5、 3の画像 3
      • Unclick the black bar connecting the orange hard drive cable to the bottom of the hard drive. Gently push towards the bottom of the device on the black bar until you hear a click sound, it is now disengaged from the hard drive.
      • If the cable doesn't come off easily, the black bar has not been un-clicked.
      • The hard drive cable (ZIF cable) is very fragile. Try to keep it in its original shape and bend it as little as possible.
      • Now gently pull the orange hard drive cable to remove it from the hard drive.
      • Lift the hard drive from the device.
      • Hard Drive Replacement Only: Check to make sure the hard drive cable is in good condition and then connect the new hard drive in the same place, following the steps in reverse order.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
8 の人々がこのガイドを完成させました。
作成者
12人の作成者と共同で作成されました。
turey
メンバー登録日: 11/11/09
417 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 6-5, Maness Fall 2009 Cal Poly, Team 6-5, Maness Fall 2009人のメンバー
CPSU-MANESS-F09S6G5
5 メンバー
18のガイドは作成済み
1件のガイドコメント
what model hard drive did you utilize during its replacement?
thanksss
RAFI V DEMIRJIAN - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 68
今までの合計 14,334
