はじめに
This guide will go over how to replace the power button, volume button, and left speaker unit on the Microsoft Surface Pro 5. The iOpener is used in this guide, but a hair dryer or heat gun could also be used. See instructions for the iOpener here.
必要な工具と部品
Use a spudger to flip up the small locking flaps on the display cable ZIF connectors.
Slide an opening pick under the display board to separate the adhesive holding it onto the back of the screen.
この手順で使用する道具:Tweezers$4.99
Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
Remove the nine Torx screws securing the heat sink:
Five 2.6 mm-long T3 screws
Four 3.3 mm-long T5 screws
Screw 1
Screw 2
Screw 3
Screw 4
Remove the Torx T5 x 6mm screw connecting the black tie bar to the power button/volume control/speaker assembly.
Use a Torx T5 to remove the two 4.5mm silver screws on the power button/volume control/speaker assembly.
ある他の人がこのガイドを完成しました。
