メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Microsoft Surface Charging Port Replacement
必要な工具と部品
  1. Microsoft Surface Charging Port Replacement, Back Cover: 手順 1、 3の画像 1 Microsoft Surface Charging Port Replacement, Back Cover: 手順 1、 3の画像 2 Microsoft Surface Charging Port Replacement, Back Cover: 手順 1、 3の画像 3
    • Prior to any repairs make sure that the device is orientated correctly, and you are familiar with all ports and buttons. The screen should be facing up with the Windows logo located on the bottom.
    • Turn off device prior to continuing
    FixBotに聞いてみる
    コメントを追加
  2. Microsoft Surface Charging Port Replacement: 手順 2、 3の画像 1 Microsoft Surface Charging Port Replacement: 手順 2、 3の画像 2 Microsoft Surface Charging Port Replacement: 手順 2、 3の画像 3
    • Carefully turn the tablet over so the screen is facing down.
    • Pull up on the bottom corners to open the stand.
    FixBotに聞いてみる
    コメントを追加
  3. Microsoft Surface Charging Port Replacement: 手順 3、 2の画像 1 Microsoft Surface Charging Port Replacement: 手順 3、 2の画像 2
    • Remove the two 5.1 mm T5 Torx screws.
    • The two screws will be located on the left and right sides in the kickstand.
    • Make sure when removing the screws to be careful to prevent stripping of the head.
    • With all the screws removed gently wiggle the stand side to side until the lever in the middle is free, releasing the stand.
    FixBotに聞いてみる
    コメントを追加
  4. Microsoft Surface Charging Port Replacement: 手順 4、 2の画像 1 Microsoft Surface Charging Port Replacement: 手順 4、 2の画像 2
    • Use a spudger or similar flat headed tool to release the small bezels out lined in the image. Remove the plastic trim covering the camera with the soft flat headed tool.
    • Be patient; you will have to work around the casing because there are several small bezels along the edges.
    FixBotに聞いてみる
    コメントを追加
  5. Microsoft Surface Charging Port Replacement: 手順 5、 2の画像 1 Microsoft Surface Charging Port Replacement: 手順 5、 2の画像 2
    • Next, remove the ten 5.92mm T5 torx screws located underneath the kickstand.
    • Remove the seven 5.87mm T5 torx screws located under the camera casing. There is a sticker covering the second screw from the left.
    • Disconnect the rear cover from the main shell of the system by loosening it with a spudger where the gaps exist.
    • There is an electrical ribbon connecting the rear cover to the motherboard. Do not pull apart the rear cover from the motherboard once you have loosened the rear cover from the main system.
    • Continue working your way around to each corner and loosen the snap-ons on each side until the rear cover comes off.
    FixBotに聞いてみる
    コメントを追加
  6. Microsoft Surface Charging Port Replacement: 手順 6、 3の画像 1 Microsoft Surface Charging Port Replacement: 手順 6、 3の画像 2 Microsoft Surface Charging Port Replacement: 手順 6、 3の画像 3
    • Rotate the device 180 degrees so that the bottom of the device is facing you.
    • A ribbon connects the battery on the rear cover, to the motherboard. Slowly lift the bottom of the rear cover up until you can see the ribbon.
    • Use a spudger to push the ribbon away from the motherboard and parallel to the motherboard in order to remove the ribbon.
    • Separate the rear cover by lifting it up away from the main system.
    • When reassembling the rear cover to the motherboard, reinserting the ribbon cable with a spudger may prove difficult. In this case, gently use your hands to slide the cable end into the slot until they click into place.
    FixBotに聞いてみる
    コメントを追加
  7. Microsoft Surface Charging Port Replacement, Charging Port: 手順 7、 3の画像 1 Microsoft Surface Charging Port Replacement, Charging Port: 手順 7、 3の画像 2 Microsoft Surface Charging Port Replacement, Charging Port: 手順 7、 3の画像 3
    • Orient the Surface so the side with the charging port is facing you.
    • Use your finger to lift the tab and unplug the orange ribbon from the motherboard.
    • Remove the two 3.6 mm T4 Torx screws that hold the charging port in place.
    • Remove the charging port by sliding it out from the main board.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
12 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Erin Beane
メンバー登録日: 01/11/13
346 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 17-23, Forte Winter 2013 Cal Poly, Team 17-23, Forte Winter 2013人のメンバー
CPSU-FORTE-W13S17G23
5 メンバー
17のガイドは作成済み
5件のガイドコメント
Can anyone confirm whether this charging port will work for a Microsoft Surface 3 (non-pro)? The port is loose and cannot get a fitting connection with a micro-usb cable. Thank you.
Michael Zimmerman - 返信 共有
Probably, As They Are The Same Aren’t They? I’d Say About 80% Chance Of It Working, Good Luck!
I’ll Have To Do This Myself Soon, All The Pins Seemed To Have Been Sucked Into The Actual Body Of The Device.
Callum Hull - 返信 共有
Is the charging circuitry also located on this board or is it only the port?
rolfeilert1970 - 返信 共有
The light on the charger connector is on when connected to the Surface. Does this suggest that the charger is working or that the Surface is charging? The unit will not turn on. When I turned it on earlier, I got the ‘low battery symbol’ on the screen but after charging I can get nothing on the screen. I am hesitant to take apart.
dickrwh - 返信 共有
My surface is not charging anymore, and the pins on the charger are black (at least 2 of them are) does it help to repair the charging port? Or is the charging circuitry located somewhere else?
Rick Okkersen - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 32
過去 30 日: 117
今までの合計 55,547
