はじめに
If your volume control button has been getting stuck or malfunctioning, it is very likely that it needs to be replaced. This guide is a step by step process on how to go about fixing it.
必要な工具と部品
Begin by using a heat gun or the iOpener (This will take longer.) to melt the adhesive all around the outer edge of the screen.
Insert the opening picks just under the screen and black edging. Be sure to place them evenly on each side.
Using the gap created by the picks, slowly pry the screen from the body of the Microsoft Surface 2 with a plastic opening tool. Pry as uniformly as possible.
Remove ten 3.45 mm T3 screws from the corners of the black plastic bezel.
Remove the remaining seventeen 4.4 mm T5 screws from the perimeter of the bezel.
Once all screws have been removed, lift and remove the bezel from the rest of the device.
