メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Microsoft Kinect Microphone Panel Replacement
必要な工具と部品
  1. Microsoft Kinect Microphone Panel Replacement, Case: 手順 1、 3の画像 1 Microsoft Kinect Microphone Panel Replacement, Case: 手順 1、 3の画像 2 Microsoft Kinect Microphone Panel Replacement, Case: 手順 1、 3の画像 3
    • Remove the two plastic strips off the bottom of the main Kinect housing using the metal spudger's sharper side.
    • Peel off the two Xbox 360 stickers from the bottom of the case to reveal two hidden screws.
    • Some force may be required to remove the adhesive. Applying heat to the adhesive may make it easier to remove.
    • Do not overheat as it may cause damage to the internal components.
    FixBotに聞いてみる
    コメントを追加
  2. Microsoft Kinect Microphone Panel Replacement: 手順 2、 1の画像 1
    • Unscrew the six 12mm T10 Torx screws.
    FixBotに聞いてみる
    コメントを追加
  3. Microsoft Kinect Microphone Panel Replacement: 手順 3、 3の画像 1 Microsoft Kinect Microphone Panel Replacement: 手順 3、 3の画像 2 Microsoft Kinect Microphone Panel Replacement: 手順 3、 3の画像 3
    • Remove the top portion of the case from the rest of the body.
    • Detach the side portions of the case from the body.
    • Remove the fan piece from the side of the body. Unplug it from the logic board to fully remove it.
    • When unplugging the fan, be sure to pull from the white connector at the end of the wire to avoid breaking it.
    FixBotに聞いてみる
    コメントを追加
  4. Microsoft Kinect Microphone Panel Replacement: 手順 4、 1の画像 1
    • Remove the bottom portion of the case by sliding it out from under the body.
    • The bottom of the case may be difficult to remove if there is any residual adhesive. If the residual adhesive prevents you from removing the case, apply gentle heat and wiggle the case out.
    FixBotに聞いてみる
    コメントを追加
  5. Microsoft Kinect Microphone Panel Replacement: 手順 5、 2の画像 1 Microsoft Kinect Microphone Panel Replacement: 手順 5、 2の画像 2
    • Remove the four 7mm T10 Torx screws (two on each side of the metal body).
    FixBotに聞いてみる
    コメントを追加
  6. Microsoft Kinect Microphone Panel Replacement: 手順 6、 2の画像 1 Microsoft Kinect Microphone Panel Replacement: 手順 6、 2の画像 2
    • Remove the front portion of the case containing the lens coverings for the cameras.
    • The LED component is connected to the front portion of the case. To disconnect it, just pull it out of its plastic connector.
    FixBotに聞いてみる
    コメントを追加
  7. Microsoft Kinect Microphone Panel Replacement, Microphone Panel: 手順 7、 1の画像 1
    • Unplug the microphone from motherboard.
    FixBotに聞いてみる
    コメントを追加
  8. Microsoft Kinect Microphone Panel Replacement: 手順 8、 1の画像 1
    • Pull off the microphone panel and snake the cable that was connected to the motherboard through the hole on the camera panel.
    • Pull the cable out carefully to avoid damage.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Nick Carlucci
メンバー登録日: 04/26/15
394 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 14-7, Amido Spring 2015 Cal Poly, Team 14-7, Amido Spring 2015人のメンバー
CPSU-AMIDO-S15S14G7
4 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 26
過去 30 日: 79
今までの合計 1,606
