はじめに
Dim picture? No display? Discolored output? No problem! Use this guide to replace the burnt light bulb with a new one. To complete this replacement, you will need the following parts ready:
必要な工具と部品
Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
Remove the light bulb from the door panel by gently wiggling it back and forth. Do not twist the light bulb.
ある他の人がこのガイドを完成しました。
1件のガイドコメント
Mi nuevo proyector no prende la luz ni el ventilador al conectarlo al tomacorriente y encenderlo.
JAVIER MUNOZ - 返信 共有
