メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Marshall Woburn Subwoofer Replacement
必要な工具と部品
    1. Marshall Woburn Subwoofer Replacement, Back Panel: 手順 1、 2の画像 1 Marshall Woburn Subwoofer Replacement, Back Panel: 手順 1、 2の画像 2
      • Before starting, unplug the speaker from any power source. After unplugging the device, wait around 10 minutes before starting to let the capacitor fully discharge.
      • On a flat surface, orient the device so that the front grille is facing downward.
      • Using a Phillips #1 screwdriver, remove the ten outer 28.6 mm screws marked in red.
      • Remove the eight inner 28.6 mm screws with the Phillips #1 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    2. Marshall Woburn Subwoofer Replacement: 手順 2、 2の画像 1 Marshall Woburn Subwoofer Replacement: 手順 2、 2の画像 2
      • Lift the back input board slightly above the back panel.
      • Rotate the input board so that you can slide it into the hole in the back panel that it came from.
      • Fully slide the input board through the back panel and set it down gently inside the speaker.
      FixBotに聞いてみる
      コメントを追加
    3. Marshall Woburn Subwoofer Replacement: 手順 3、 1の画像 1
      • Grab the panel by the large hole and lift one side until you can fit your hand under.
      • Use your hand to fully remove the back panel from the rest of the frame.
      FixBotに聞いてみる
      コメントを追加
    1. Marshall Woburn Subwoofer Replacement, I/O Board: 手順 4、 1の画像 1
      • Disconnect the 5 wires circled in red from the back input board.
      • Grip and pull the connectors, not the wires.
      • There may be a little resistance when pulling on the connectors, but it should not require excessive force.
      FixBotに聞いてみる
      コメントを追加
    2. Marshall Woburn Subwoofer Replacement: 手順 5、 2の画像 1 Marshall Woburn Subwoofer Replacement: 手順 5、 2の画像 2
      • Remove the two 12.7 mm screws marked in red from the front of the back input panel with a Phillips #1 screwdriver.
      • Remove the power input from the back side of the panel.
      FixBotに聞いてみる
      コメントを追加
    3. Marshall Woburn Subwoofer Replacement: 手順 6、 1の画像 1
      • Completely remove the I/O board and the attached plate.
      FixBotに聞いてみる
      コメントを追加
    1. Marshall Woburn Subwoofer Replacement, Subwoofer: 手順 7、 1の画像 1
      • Using a Phillips #1 screwdriver, remove the eight 15.8 mm screws attaching the subwoofers to the frame.
      FixBotに聞いてみる
      コメントを追加
    2. Marshall Woburn Subwoofer Replacement: 手順 8、 1の画像 1
      • Lift each subwoofer up and out of the case and remove them together.
      • This may require a little force.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
3人の作成者と共同で作成されました。
Kenneth
メンバー登録日: 10/29/23
174 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2023人のメンバー
UMASSD-GULBRANDSEN-F23S2G4
3 メンバー
18のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 23
過去 30 日: 81
今までの合計 2,258
