メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Makerbot Digitizer stepper bracket Replacement
必要な工具と部品
  1. Makerbot Digitizer stepper bracket Replacement, Removing the turntable cap: 手順 1、 2の画像 1 Makerbot Digitizer stepper bracket Replacement, Removing the turntable cap: 手順 1、 2の画像 2
    • Use a flat spudger or screwdriver to remove the 1-1/2" cap from the turntable center.
    • There is a small indentation on the underside of one side of the cap.
    FixBotに聞いてみる
    コメントを追加
  2. Makerbot Digitizer stepper bracket Replacement, Loosen the turntable screw: 手順 2、 1の画像 1
    • Loosen the exposed T15 screw.
    • You do not need to remove it from the turntable, but it must be completely loosened.
    • It has a series of metal-rubber-metal washers, and if you leave the screw in the turntable, you don't need to mess with the washers.
    FixBotに聞いてみる
    コメントを追加
  3. Makerbot Digitizer stepper bracket Replacement, Remove turntable: 手順 3、 3の画像 1 Makerbot Digitizer stepper bracket Replacement, Remove turntable: 手順 3、 3の画像 2 Makerbot Digitizer stepper bracket Replacement, Remove turntable: 手順 3、 3の画像 3
    • Use two flat tools under both sides of the turntable to to pop it out.
    • The turntable slides down onto the bearing with some friction, but I've taken mine on and off 10 times and it still fits snugly.
    FixBotに聞いてみる
    コメントを追加
  4. Makerbot Digitizer stepper bracket Replacement, Remove stepper screws: 手順 4、 3の画像 1 Makerbot Digitizer stepper bracket Replacement, Remove stepper screws: 手順 4、 3の画像 2 Makerbot Digitizer stepper bracket Replacement, Remove stepper screws: 手順 4、 3の画像 3
    • Remove two T15 screws that hold the stepper bracket in place.
    FixBotに聞いてみる
    コメントを追加
  5. Makerbot Digitizer stepper bracket Replacement, Snap some pictures: 手順 5、 3の画像 1 Makerbot Digitizer stepper bracket Replacement, Snap some pictures: 手順 5、 3の画像 2 Makerbot Digitizer stepper bracket Replacement, Snap some pictures: 手順 5、 3の画像 3
    • That's basically it. My stepper has enough slack to maneuver it around without further disassembly.
    FixBotに聞いてみる
    コメントを追加
  6. Makerbot Digitizer stepper bracket Replacement, Reinstall the turntable: 手順 6、 3の画像 1 Makerbot Digitizer stepper bracket Replacement, Reinstall the turntable: 手順 6、 3の画像 2 Makerbot Digitizer stepper bracket Replacement, Reinstall the turntable: 手順 6、 3の画像 3
    • To reinstall the turntable, the stepper side must go in first, in order for the turntable gears to align with the stepper gears.
    • Otherwise, the turntable will sit too high and not contact the stepper gear.
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble, just follow these instructions in reverse.
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Job McKee
メンバー登録日: 10/07/12
241 ポイント
2のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 21
今までの合計 166
