はじめに
このガイドを使って、ヒートシンクを交換する、もしくはプロセッサに放熱グリスを再装着してください。
必要な工具と部品
上部ケースとバッテリーを固定している3本のペンタローブネジを外します。このスペシャルドライバーで対応できます。
くぼみがドライバーの先端より大きい場合は、より大きなビットのドライバーを探してください。ドライバーを回す前に、ぴったりとくぼみにフィットするか再度確認してください。
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
15 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
2 件のコメント
Hey ifixit, I really appreciate the level of description to your various guides. I was following this guide to a tee except that I couldn't find my spudger, but managed with using creditcard like. I was following this guide as I want to change the thermal paste. I completed step 23, but from there on it was a bust, it felt way too tight when I was trying too lift the logic board, I could only get i a few centimeters up on the left side. It felt stuck at the bottom/uppercase. i checked that all screws and connections were free and I couldn't find any obstacles, but didn't want to use force lifting it. should it be easy/hard to lift??
To answer Mike’s question (although 4 years late, I hope this helps others), when I disassembled my 2009 15” MacBook Pro I had to use more force than I would have liked when removing the Logic Board, it turns out that one of the heatsinks has some adhesive on it that sticks to the keyboard, and you have to break it apart. So more force than you’ll probably be comfortable with is required.
