メインコンテンツにスキップ
MacBook Pro 13" Unibody Mid 2010のハードドライブケーブルの交換
必要な工具と部品
  1. MacBook Pro 13" Unibody Mid 2010のハードドライブケーブルの交換, 下部ケースのネジを外す: 手順 1、 1の画像 1
    • MacBook Pro 13インチ Unibodyに留められた底ケースから次のネジを10本外します。
    • 3 mmプラスネジー7本
    • 13.5 mmプラスネジー3本
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - 返信
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - 返信
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - 返信
    I use a magnetic mat and place the screws in order on that :)
    Cary B - 返信
  2. MacBook Pro 13" Unibody Mid 2010のハードドライブケーブルの交換, 下部ケースを持ち上げて外す: 手順 2、 1の画像 1
    • 取付台タブを外すため、底ケースをわずかに持ち上げて、デバイス本体の背中側に向けて押します。
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - 返信
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - 返信
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. MacBook Pro 13" Unibody Mid 2010のハードドライブケーブルの交換, バッテリー: 手順 3、 1の画像 1
    • 作業前の注意点として、放電を防ぐためロジックボードからバッテリーコネクターの接続を外してください。
    • スパッジャーの平面側先端を使って、ロジックボード上のソケットからバッテリーコネクターを持ち上げます。
    gansodesoyaからの引用:
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - 返信
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - 返信
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - 返信
  4. MacBook Pro 13" Unibody Mid 2010のハードドライブケーブルの交換, ハードドライブ: 手順 4、 1の画像 1
    • 上部ケースとハードドライブブラケットを固定しているプラスネジを2本外します。
    • 実際、このネジはハードドライブブラケットに留められています。
  5. MacBook Pro 13" Unibody Mid 2010のハードドライブケーブルの交換: 手順 5、 1の画像 1
    • 上部ケースから固定ブラケットを取り出します。
  6. MacBook Pro 13" Unibody Mid 2010のハードドライブケーブルの交換: 手順 6、 1の画像 1
    • コンピューターに留められたケーブルに注意しながらプルタブを引っ張り、ハードドライブをケースの外側に向けて取り出します。
  7. MacBook Pro 13" Unibody Mid 2010のハードドライブケーブルの交換: 手順 7、 1の画像 1
    • ハードドライブからハードドライブケーブルをまっすぐに引き出して取り出します。
    I guess it's probably my fault that I broke the SATA cable during this step (unless the cable was somehow already weakened), but for anyone reading this, be extra careful. My connector was fitted really tightly, and when it finally came out it ripped the cable, which is pretty expensive in its own right (although you can get a cheaper deal on eBay).
    nitrous - 返信
  8. MacBook Pro 13" Unibody Mid 2010のハードドライブケーブルの交換, ハードドライブケーブル: 手順 8、 1の画像 1
    • IRセンサーケーブルとハードドライブを上部ケースに固定している次のネジを4本外します。
    • 1.5 mmプラスネジー2本
    • 9.5 mmプラスネジー2本
  9. MacBook Pro 13" Unibody Mid 2010のハードドライブケーブルの交換: 手順 9、 2の画像 1 MacBook Pro 13" Unibody Mid 2010のハードドライブケーブルの交換: 手順 9、 2の画像 2
    • ハードドライブとIRセンサーブラケットを上部ケースの端からスライドします。
    • ハードドライブとIRセンサーケーブルを上部ケースから丁寧に引っ張り、取り出します。
  10. MacBook Pro 13" Unibody Mid 2010のハードドライブケーブルの交換: 手順 10、 1の画像 1
    • スパッジャーの平面側先端を使って、ロジックボードからハードドライブケーブルのコネクターをまっすぐ持ち上げて接続を外します。
  11. MacBook Pro 13" Unibody Mid 2010のハードドライブケーブルの交換: 手順 11、 1の画像 1
    • ハードドライブ/IRセンサーケーブルアセンブリを上部ケースから持ち上げます。
    • 交換用のパーツにハードドライブブラケットやインジケーターランプが付いていない場合は、取り出したパーツからこれらを外して新しいパーツに装着してください。
    • 交換用のパーツに接着性フォームバンパーが入っている場合があります。これらはブラケットとハードドライブ両方の滑り止めです。必要に応じて装着してください。
    I had the same challenge with the ribbon cable clamp. There is a tiny orange ribbon, visible in the lower left corner of the photo for step 10, above, that needs to be connected to the new part using a tiny clamp, also visible right there in step 10. To open it, you flip up part of the clamp that is opposite the ribbon. That will release the ribbon, and enable you to slide the ribbon into the new clamp, which then you can adhere to the bracket. Hope that's helpful for future fixers.
    Bryony - 返信
    Thank you, Bryony! Very helpful clarification on how to open the clamp. All set now.
    Lucas -
    To connect the orange ribbon for the IR sensor you have to have to lift the little handle on the back part 90 dregrees up of the black plastic terminal piece. So now its open.
    After you did this its totally easy to insert the orange ribbon flat cable. After that close the little handle again - thats all!
    Jpat70 - 返信
終わりに
デバイスを再組み立てする際は、こららのインストラクションを逆の順番に従って作業を進めてください。
211 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
5人の作成者と共同で作成されました。
Walter Galan
694,782 ポイント
1,203のガイドは作成済み
6 件のコメント
Fantiastic!!
I had an SSD installed but it stopped working after a few months and I got the flashing question mark folder. It was very odd as the disk drive still worked, and the SSD did externally. Heard it could be the SATA as SSDs are more sensitive to damaged cables, so replaced it on the off chance and it worked! Definitely recommend trying this first if you have had the same problem
AC1 - 返信
Wow, this worked so GOOD! ...and those derps at the local Apple retailer told me to "let the computer go, and take a look at the new ones we have here!"
Did troubleshooting with ifixit, ordered part from ifixit and followed step-by-step guide provided by ifixit! You guys rule!
Many thanks from Sweden!
Mikael Parkman - 返信
This worked like a charm. My mid 2010 MacBook Pro is back. Although it was temping to claim my Mac as dead and buy the latest baddest MacBook, I had to try a $50 fix. It worked. I saved over $1200 now. I want to see how long my 2010 Mac lasts now. Thanks ifixit.com.
David Cantu - 返信
This went very smoothly. I had already tried replacing the hard drive, so there were only a few new steps for me. Glad I didn't have to take apart the bracket and light in the last step. Time machine is chugging away as I speak, and my 2010 is not on the scrap heap just yet.
David Haye - 返信
This is the second time this cable has failed in this machine (Apple fixed it once for free). Seeing the FIVE right-angle bends the cable makes to get from the disk to the motherboard connector makes it clear why this part fails. Being able to buy this cable from iFixit and follow the step-by-step guide is GREAT--since Apple refuses to touch machines after they are five years old.
One hint for reassembly: first pin the cable down with the four screws, then attach the motherboard connection, then use something to temporarily hold the disk connector/cable out of the way, then pre-place the sensor/light cable against the case so you know where you want it to go, then cheat the paper glue cover off of the sensor/light cable as you smooth it against the case. Then the disk connector goes onto the disk, the disk seats easily, and then the retaining bracket is trivial.
Removing the sensor/light/disk-seat from the case was a little fiddly. It feels "stuck" because the cable is GLUED to the case!
David Eckhardt - 返信
Does the cable cord have a # on it, asking because I need to buy a new one & they all have #’s on them. Which # is associated with a 2009/2010 MacBook Pro.?
Valerie Semenoro - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 27
過去 30 日: 98
今までの合計 116,073
