メインコンテンツにスキップ
MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換
必要な工具と部品
  1. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換, 下部ケースのネジを外す: 手順 1、 1の画像 1
    • MacBook Pro 13インチ Unibodyに留められた底ケースから次のネジを10本外します。
    • 3 mmプラスネジー7本
    • 13.5 mmプラスネジー3本
    Compare the short screws carefully before reinstalling them. The shouldered screws go in the holes on the front edge.
    David Kilbridge - 返信
    Before I started removing any screws I took a piece of paper and drew the bottom of the laptop and put a piece of double-sided tape in the spot where each screw goes. That way when I took out the screws, I could put them on the tape so I knew exactly which screw went in which spot. I did the same thing for dismantling the inside on another sheet of paper, then a third sheet for the screen after getting the front glass off.
    mastover - 返信
    I use a similar technique: I print out the iFixit manual for the job, and Scotch-tape down the screws/brackets/cables I remove at each step next to the component descriptions. That way, when I'm reassembling, the bits are taped right next to the photo of where they came from.
    adlerpe -
    That's exactly what I do for all my repairs! It's the best way to keep track of all of the parts ' original location and to make sure that you don't miss any parts during reassembly.
    joyitsjennie -
    Great idea and one I use often
    Thomas Overstreet -
    Excellent idea! Thanks for sharing it here.
    Laura Sharkey -
    I used a 00 that fit but the screws were very tight so I used a tiny paintbrush with some wd40 on it and put it around the edges of the screws. Worked like a charm
    valentinedhdh - 返信
    I use a magnetic mat and place the screws in order on that :)
    Cary B - 返信
  2. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換, 下部ケースを持ち上げて外す: 手順 2、 1の画像 1
    • 取付台タブを外すため、底ケースをわずかに持ち上げて、デバイス本体の背中側に向けて押します。
    In the introduction you should link fixers to this excellent doc: https://www.ifixit.com/Misc/HD_Software_...
    It is really critical, super easy, and free(!) to clone your existing drive onto the new one you will install. I ran into one error, but SuperDuper! support replied immediately on how to fix it...Thanks ifixit and SuperDuper! (I ponied up the $28 for the software anyway, I was so impressed!)
    Mike - 返信
    Long story short: I drank the AppleKoolAid back in 1984 and have always left the guts of my machines up to Apple - until recently when I needed to swap the SATAs from my original MacDaddy (2009 13" MBPro that I killed in 2018 - coffee + blackout = OOOOPS) into a pristine 2009 MBPro from a Goodwill in North Carolina through eBay. I need the files from iCal and MacMail that can't be opened in my newer machines.
    Well . . . I ain't never done nuttin' like that, before!
    Enter Luke Miani on YouTube. He raves about you guys! So, I watched everything I could, read your site, bought the right tools and at the ripe old age of 72, I sat down, this morning and did the work. Now my original MacDaddy lives in MacDaddy2.0.
    Am I allowed to cry?
    Seriously, I can't thank you enough for your bitchen site and killer tools. I wish I'd'a been turned on to this shizzle 30+ years ago.
    IFIXIT - IDIGIT!
    kath myers - 返信
    HAHAHAHAHAHAHAHAHAHA.
    That was a brilliant read.
    Yes, I came across ifixit a few years ago. Totally helped me out on several occasions.
    Glad your Mac repair journey worked out.
    Cary B -
  3. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換, バッテリー: 手順 3、 1の画像 1
    • 作業前の注意点として、放電を防ぐためロジックボードからバッテリーコネクターの接続を外してください。
    • スパッジャーの平面側先端を使って、ロジックボード上のソケットからバッテリーコネクターを持ち上げます。
    gansodesoyaからの引用:
    why is step 3 necessary?
    Just to disconnect any power source to avoid damages by short-circuits.
    MrKane - 返信
    How do you get that battery connector back on? Do you just press it in back in place after you're done?
    Horace Chung - 返信
    yes. I usually plug it in before I screw it down so I can lift the battery a bit and have enough slack to be able to go straight down on the connector, otherwise it comes in on a bit of an angle, which can't be good (though not necessarily bad).
    maccentric -
    This step almost finished me, and I did extensive damage to the battery plug. Fortunately, I later replaced the battery, and the replacement came with a new plug! :) Newbies need to know - 1. The battery plug is like a thin lip on a thicker lip, so you need to pry BETWEEN 2 thin lips to get it off, else you are trying to yank out the socket. 2. Mine was initially VERY tight, and trying to get it out broke the plastic on all sides of plug, even though I was as careful as possible. Luckily, this didn't hurt functionality and I later replaced the battery. AFTER disconnecting once, it was never so tight again,
    Jeff Diamond - 返信
  4. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換, ファン: 手順 4、 3の画像 1 MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換, ファン: 手順 4、 3の画像 2 MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換, ファン: 手順 4、 3の画像 3
    • スパッジャーを使ってファンコネクターをまっすぐロジックボードから持ち上げて取り出します。
    • スパッジャーをファンケーブルワイヤの下から軸方向にひねって使うとコネクターから外しやすいです。
    • ファンのソケットとファンのコネクターは2番目と3番目の画像で確認できます。スパッジャーを使ってソケットからファンコネクターをまっすぐ持ち上げるため、プラスチックのファンソケットを壊さないようにご注意ください。ロジックボードのレイアウトは2番目の画像に表示していますが、お持ちのデバイスと比べると若干異なる可能性があります。ファンソケットの位置は同一のはずです。
    I just soldered it back on. . . I tried to clean the pads with braid first, but it didn't do much so I don't think that's necessary. I first supper-glued it in place with the pins on the pads and then I put a tiny dab of solder on each pin/pad. Plugged in the fan and i works!
    Ron Hudson - 返信
    Just the answer I was looking for Ron! Awesome work buddy!
    lucasjmenzie -
    i recommend not to use the spudger. you damage more than by unpluggin the plug by hand. just simply pull the cable close to the plug of the old fan softly upwards out. the plug than comes easily out. put the new fan in and push the new plug by hand in. it is much easier than using a spudger. i also started with a spudger but nearly broke the plug out, so i watched a youtube tutorial and learned about it…
    andre - 返信
  5. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 5、 1の画像 1
    • 上部ケースとファンに固定された次のネジを3本外します。
    • 6.5 mmプラスネジー1本
    • 5.5 mmプラスネジー1本
    • 4.5 mmプラスネジー1本
  6. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 6、 1の画像 1
    • 上部ケースからファンを取り出します。
  7. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換, 基板: 手順 7、 3の画像 1 MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換, 基板: 手順 7、 3の画像 2 MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換, 基板: 手順 7、 3の画像 3
    • ディスプレイデータケーブルのロックに固定されているプラスチックのプルタブを手に取り、デバイスのDC-in側に向けて回転させます。
    • ディスプレイデータケーブルコネクタをソケットから、デバイスのDC-in側に向けて引き抜きます。
  8. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 8、 2の画像 1 MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 8、 2の画像 2
    • ディスプレイデータケーブルのブラケットを上部ケースに固定している次の2本のネジを外します。
    • 7 mmプラスネジー1本
    • 5 mmプラスネジー1本
    • 上部ケースからディスプレイデータケーブルのブラケットを持ち上げます。
    Mine are Torx and got an extra clamp for the cable, just above the left screw
    Martin - 返信
    If you only want to replace the DC-in board, stop here and GOTO 17 (and DO NOT 4 and 6).
    When the Logic board is loose, lift it up on the Harddrive end and shift slightly towards the HD, so that the USB connectors at the outside come free from under the case rim and the board can be lifted up a bit. Then there´s enough room to move the DC in board, pull the cable out with a pair of tweezers, wriggle it out from under the microphone cable and wriggle the new connector in. It can be pushed into the socket with tweezers or a small screwdriver. This worked perfect for me.
    Be careful not to bend the logic board, but otherwise I think there´s much less risk of messing anything up with all the connectors and bits and pieces that need to be loosened and fastened.
    Mike - 返信
  9. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 9、 1の画像 1
    • スパッジャーの平面側先端を使って、基板からサブウーファーと右側スピーカーのコネクタを引き上げます。
  10. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 10、 1の画像 1
    • この手順ではカメラケーブルの接続を外します。多くのデバイスでは小さな接着付きプラスチックのリテイナーが、コネクタを固定する目的で基板に付いています。ケーブルの接続を外す前に、このリテイナーを作業の邪魔にならない位置に外してください。
    • カメラケーブルのコネクタを光学ドライブ側に向けて引き、基板から接続を外します。
    • このソケットはメタル製で簡単に曲がってしまいます。2つのパーツを合わせる前に基板上のソケットとコネクタの位置を揃えてください。
    There is a small piece just below this connector which is just an adhesive block to keep the connector from coming out. It is easiest to peel it up first with a fingernail or spudger then remove the cable. Likewise reinsert the cable before reapplying the adhesive safety stop.
    Justin Jett - 返信
    I couldn't reconnect this cable correctly, so my camera is not working anymore.
    It doesn't matter to me, I didn't used the camera that often...
    But the Ambient Light Sensor uses the camera to control keyboard lighting, so I wasn't able to see my keyboard in the dark anymore... :(
    If you have the same problem, after a couple of google hits I've found this app: https://www.macupdate.com/app/mac/22151/...
    Problem solved! YAY!
    PS: be careful because WIFI passes through this cable as well!!!!
    simbass - 返信
    Look at the photo intently. The connector is inserting not in parallel, but at a slight angle. The bottom corner of the connector is slightly ahead. It is important! Singular metod to insert it.
    Vladimir -
  11. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 11、 3の画像 1 MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 11、 3の画像 2 MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 11、 3の画像 3
    • スパッジャーの平面側先端を使って、光学ドライブ、ハードドライブとトラックパッドケーブルのコネクタを基板から引き抜きます。
  12. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 12、 3の画像 1 MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 12、 3の画像 2 MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 12、 3の画像 3
    • 指の先かスパッジャーの先端を使って、キーボードリボンケーブル用のZIFソケット上のフラップを固定しているケーブルを引き上げます。
    • スパッジャーを使って、ソケットからキーボードリボンのケーブルをスライドします。
    When reinserting the keyboard ribbon cable, make sure you push it in all the way (two plastic tools are helpful - one to push it down flat, the other to coax it all the way in). For 3 days after replacing a top case, my MacBook Pro 13" wouldn't start up. I thought the main logic board was fried too. However, reinserting the keyboard ribbon cable again, this time perhaps 1mm farther in, and it started up again! I did the same for the "keyboard backlight ribbon cable" (i.e. reinserted it just to make sure). Really not sure which completed the circuit so is would start, but I suspect the keyboard ribbon cable.
    amiller770 - 返信
    amiller770からの引用:
    I usually use a piece of sticky transparent office tape and stick it over the flat cable a bit further away from the mating part then pull on it. There is no better way to force the flat cable into a stiff connector without damaging the fragile cable.
    Leo Bodnar - 返信
    As others have stated, if the keyboard ribbon cable isn't fully inserted the MBP will not power on. Leo Bodnar's recommendation to use a piece of transparent office tape did the trick for me. Many thanks Leo!
    Matthew Rankin - 返信
    Inserting the ribbon cable for the keyboard was really difficult, but i was able to get it in using a piece of tape and pulling it up, just like the tape on the keyboard backlight.
    Kelly Legner - 返信
    Using a piece of tape is sheer genius Kelly. My mom once said her definition of genius was an idea that, when you hear it, you say to yourself, “now why didn’t I think of that?” But you never would have thought of it. Brava (or bravo) Kelly!
    JonnyLine -
  13. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 13、 1の画像 1
    • キーボードのバックライト用リボンケーブルのソケットから黒色のテープに着いている小サイズのストリップを剥がします。
  14. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 14、 3の画像 1 MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 14、 3の画像 2 MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 14、 3の画像 3
    • スパッジャーの先端を使って、キーボードのバックライト用リボンケーブル用のZIFソケット上のフラップを固定しているケーブルを引き抜きます。
    • スパッジャーを使って、ソケットからキーボードバックライト用のリボンケーブルをスライドします。
  15. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 15、 1の画像 1
    • スパッジャーの平面側先端を使って、基板からバッテリーのインディケーターケーブル用のコネクターの接続を外します。
  16. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 16、 1の画像 1
    • スパッジャーの先端を使って、上部ケースに付けられた接着剤からマイクを取り出します。
  17. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 17、 1の画像 1
    • 次のネジを外します。
    • 3.1 mmプラスネジー5本
    • 3.9 mmプラスネジー2本
    • DC~inボードから7 mmプラスネジー2本
  18. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 18、 2の画像 1 MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 18、 2の画像 2
    • バッテリーと上部ケースを固定している次のトライポイントネジを外します。
    • 5.5 mmトライポイントネジー1本
    • 13.5 mmトライポイントネジー1本
    • 上部ケースからバッテリーを持ち上げます。
  19. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 19、 2の画像 1 MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換: 手順 19、 2の画像 2
    • ポートが上部ケースの端から外れるまで、基板を左側端から持ち上げます。
    • 上部ケース側から基板を引き離して取り出します。DC-inボードに絡まないようご注意ください。
    • マイクアセンブリの壊れやすいコネクタプラグを引き裂かないようご注意ください。
    When putting the logic board back in place, it's easier to angle the mic down in it's place as you are placing the board in, rather than after the board is seated.
    amiller770 - 返信
  20. MacBook Pro 13インチ Unibody Mid 2009 DC-In Boardの交換, DC-In Board: 手順 20、 1の画像 1
    • 基板上のソケットからDC-In Boardのコネクタを引っ張り、DC-In Boardの接続を外します。
終わりに
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
89 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
作成者
5人の作成者と共同で作成されました。
Walter Galan
694,877 ポイント
1,203のガイドは作成済み
5 件のコメント
Reassembling: Make sure, the cable of the DC-In board is on the logic board-side of the screw hole when putting in the logic board. Otherwise the display data cable bracket won't fit in and you have to remove the board again.
So I hope, the DC-In board was really the cause of my problems. I changed the battery and the charging cable before and still had problems. At this moment my macbook loads again, but I don't know if its because of the board or again just luck. Thank you very much for the guide.
lichthexe - 返信
Thank you Team for wonderful blog, I had replaced DC-in board successfully.
~Dushyanta
Dushyanta - 返信
I just replaced the DC-in board but my Mac did not turn on. Any other suggestion?
gypsyp - 返信
Many thanks for this great manual. You helped me to prolong my old MacBook’s life and I saved a lot of money. Carry on the good work!
Yannick Baumann - 返信
Any possibilities to also show “how to upgrade the mother board”?
mats_kallmyr - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 64
今までの合計 59,495
