メインコンテンツにスキップ
MacBook Pro 13インチ Unibody Late 2011 フットパッドの交換
必要な工具と部品
  1. MacBook Pro 13インチ Unibody Late 2011 フットパッドの交換, 下部ケース: 手順 1、 1の画像 1
    • 次のネジを10本外します。
    • 14.4 mm #00プラスネジー3本
    • 3.5 mm #00プラスネジー3本
    • 3.5 mm #00 肩付きプラスネジー4本
    • 小さなネジを交換する際は、ケースのわずかに湾曲した部分に対し、垂直にネジを揃えてください。
    How much weight can I save by removing the optical drive?
    gunes314 - 返信
    You can save a lot of weight if lets say your installing a solid state drive or putting in a second hard drive but if you know that you use the CD/DVD disc drive a lot then you might just want to leave the drive alone.
    Marshall WahlstromHelgren -
    Tip: Use one of those weekday pill holders to have a cheep way to store screws you remove and each day of the week can be for different sizes or parts. It has been handy to have (much less expensive than the magnetic mat.
    Robert Wacker - 返信
    Hello, where can I buy the screws I need in case I lose one of them?
    taylornya - 返信
    I have one stripped screw... How opening without drill it?! Any suggestions please?
    rodrigosady - 返信
    I also stripped a couple screws. I wasn’t able to open it up without drilling. After drilling the heads and removing the cover it was easy to hacksaw the tip and unscrew with a standard driver.
    Michael Wilkens -
    My top tip - make sure you buy good quality Phillips screwdrivers and a magnetic holder. Cheap screwdrivers won’t get the screws undone safely. Without a magnetic holder you have no chance of getting the tiny crews in and out safely.
    jeremyyoung - 返信
    A good Phillips 00 is your friend here. Also, when reinserting the screws, gently start anticlockwise and you wil feel a click at the start of the thread. This tells you you’re in the right place and less likely to cross-thread through force in the wrong place.
    Iain Boyd - 返信
    I feel like these are 000 screws. Amazon sales describe them as such and my 000 screwdriver fits better
    cam2000deluxe -
    Before ordering a new Trackpad remove the existing battery and try clicking the Trackpad. If it clicks OK with the battery out the source of problem is likely a swollen battery, which should to be replaced even if it still works to some degree. From the side of the battery you will likely see the soft part of the battery bulging beyond the hard case.
    Patrick Langvardt - 返信
    That’s absolutely correct as I can testify. With the battery removed I also adjusted the T6 set screw that adjusts the sensitivity of the trackpad click, evidently someone had cranked mine down tighter than the factory setting.
    Gary Register -
    Le quatrième paragraphe dans les instructions en français n’est pas correct : ce ne sont pas les 2 petites vis, mais les 7 petites vis qui sont inclinées. Et les 3 grandes sont bien verticales.
    Degeorges - 返信
    Bonjour ! Merci de votre observation. J’ai corrigé la traduction. iFixit étant un wiki, n’hésitez pas à modifiez si vous remarquez une erreur :) Encore merci de votre attention et à bientôt !
    Claire Miesch -
    Tip: if you have a magnetic screw mat or similar, lay the macbook over the mat to make sure it catches any screws that may decide to fall of and hide under your table
    Moritz - 返信
    Funny, it's not her hands that are doing the close ups. :)
    Cinemated Man - 返信
    What's the difference between the shouldered and non shouldered screws? They look exactly the same to me.
    MLNLRD - 返信
  2. MacBook Pro 13インチ Unibody Late 2011 フットパッドの交換: 手順 2、 2の画像 1 MacBook Pro 13インチ Unibody Late 2011 フットパッドの交換: 手順 2、 2の画像 2
    • 排気口(液晶ヒンジ部)付近より、底ケースを指で開けます。
    • 底ケースを取り外します。
  3. MacBook Pro 13インチ Unibody Late 2011 フットパッドの交換, フットパッド: 手順 3、 3の画像 1 MacBook Pro 13インチ Unibody Late 2011 フットパッドの交換, フットパッド: 手順 3、 3の画像 2 MacBook Pro 13インチ Unibody Late 2011 フットパッドの交換, フットパッド: 手順 3、 3の画像 3
    • 壊れたりダメージの入ったフットパッドを取り外します。
    • フットパッド用のホールに残っている壊れたフットパッドのパーツをすべて取り出します。
    • ピンセットを使って、古いフットパッドから残っている接着テープを綺麗に剥がします。
  4. MacBook Pro 13インチ Unibody Late 2011 フットパッドの交換: 手順 4、 1の画像 1
    • 残りの接着剤を取るため、接着剤リムーバーを使ってフットパッド用パッドで磨きます。
    On my mid-2009 unibody MacBook Pro, there were thin, circular, black cloth pieces inside the case, covering the holes where the feet came through. I had to remove this tape, in order to push the feet through.
    Edward Horner - 返信
  5. MacBook Pro 13インチ Unibody Late 2011 フットパッドの交換: 手順 5、 1の画像 1
    • クリーナーで残っている残りの接着剤を取るため、アルコールパッドを使ってフット部分をワイプします。
  6. MacBook Pro 13インチ Unibody Late 2011 フットパッドの交換: 手順 6、 1の画像 1
    • 交換用のフットパッドからプラスチックの裏地を剥がします。
  7. MacBook Pro 13インチ Unibody Late 2011 フットパッドの交換: 手順 7、 3の画像 1 MacBook Pro 13インチ Unibody Late 2011 フットパッドの交換: 手順 7、 3の画像 2 MacBook Pro 13インチ Unibody Late 2011 フットパッドの交換: 手順 7、 3の画像 3
    • フットパッドのパッド内側の位置に新しい交換用パッドを揃えます。
    • 足部分の凹み位置にフットパッドの外周部分がきちんと揃っているか確認します。
    • 定位置を確認しながらフットパッドを取り付けます。
    • ピンセットを使って下部ケース内側と位置を揃えます。
  8. MacBook Pro 13インチ Unibody Late 2011 フットパッドの交換: 手順 8、 1の画像 1
    • 指でしっかりとフットパッドを押さえ、約30秒間接着剤を固定しながら装着します。指でフットを抑えながら、カバーの反対側をサポートします。
    • 壊れたりダメージの入ったフットパッドがあれば、最後の6手順を繰り返してください。
    Support the rear feet from inside with your other hand before pressing down on new foot. Failure to do so may damage the plastic air grille inside the rear of the lower case. See the photos in step 3 above.
    hterlecki - 返信
    My A1278 hasn't got holes in the backplate?
    The feet just seem to be stuck on with adhesive.
    Do I still have to unscrew the back?
    Regards,
    Rob.
    Rob Haygarth - 返信
    Hi Rob,
    If the backplate doesn’t have the holes, you can still use the feet by just glueing them on. You would not have to open the backplate.
    Arthur Shi -
    I have been told that if you are using adhesive, you should follow these steps and remove the bottom.
    This way, adhesive doesn’t get inside the machine.
    Larry D Turner - 返信
    Hi Larry,
    That is definitely true, if you are adding liquid adhesives. The feet we sell come with adhesive pre-installed on the feet. All you have to do is peel and stick!
    Arthur Shi -
終わりに
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
29 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
2人の作成者と共同で作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
196,940 ポイント
416のガイドは作成済み
コメント 1 件
Fine tutorial !
I have an ecological proposal: no need of adhesive remover, an alcohol prep on a dish towel is enough to remove any remaining adhesive or residue. Less wastes !
Clément Llobet - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 41
今までの合計 5,698
