この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
The frame over your ports.
必要な工具と部品
Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
Remove the following 3 screws:
One 11 mm Phillips#00 in the middle of the lower case. (Head: 5mm dia. x .75mm thick)
Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
Disconnect the MagSafe board cable from the logic board by pulling the snap-in connector out (to the right).
15 の人々がこのガイドを完成させました。
