メインコンテンツにスキップ
MacBook Air 15" 2023 Screen Replacement
必要な工具と部品
  1. MacBook Air 15" 2023 Screen Replacement, Prepare your Macbook Air for disassembly: 手順 1、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Prepare your Macbook Air for disassembly: 手順 1、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Prepare your Macbook Air for disassembly: 手順 1、 3の画像 3
    • Allow your MacBook's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully power off your MacBook.
    • Close the display and lay your MacBook upside down. Keep your laptop closed until you've physically disconnected the battery.
  2. MacBook Air 15" 2023 Screen Replacement, Unfasten the lower case: 手順 2、 2の画像 1 MacBook Air 15" 2023 Screen Replacement, Unfasten the lower case: 手順 2、 2の画像 2
    この手順で使用する道具:
    FixMat
    $36.95
    • Use a P5 pentalobe screwdriver to remove the four 6.4 mm‑long screws securing the lower case.
  3. MacBook Air 15" 2023 Screen Replacement, Insert an opening pick: 手順 3、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Insert an opening pick: 手順 3、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Insert an opening pick: 手順 3、 3の画像 3
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle to create a gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. MacBook Air 15" 2023 Screen Replacement, Release the snapping clips: 手順 4、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Release the snapping clips: 手順 4、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Release the snapping clips: 手順 4、 3の画像 3
    • During the next two steps you'll feel and hear six snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next two clips.
  5. MacBook Air 15" 2023 Screen Replacement: 手順 5、 3の画像 1 MacBook Air 15" 2023 Screen Replacement: 手順 5、 3の画像 2 MacBook Air 15" 2023 Screen Replacement: 手順 5、 3の画像 3
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the three remaining snapping clips.
  6. MacBook Air 15" 2023 Screen Replacement, Release the sliding tabs: 手順 6、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Release the sliding tabs: 手順 6、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Release the sliding tabs: 手順 6、 3の画像 3
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat to the frame and firmly slide it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. MacBook Air 15" 2023 Screen Replacement, Remove the lower case: 手順 7、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Remove the lower case: 手順 7、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Remove the lower case: 手順 7、 3の画像 3
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the six snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
  8. MacBook Air 15" 2023 Screen Replacement, Remove the battery connector cover tape: 手順 8、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Remove the battery connector cover tape: 手順 8、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Remove the battery connector cover tape: 手順 8、 3の画像 3
    この手順で使用する道具:
    • Use blunt nose tweezers or your fingers to remove the piece of tape covering the battery connector cover.
    • During reassembly, use the leftover adhesive to secure the tape to the cover.
  9. MacBook Air 15" 2023 Screen Replacement, Remove the battery connector cover: 手順 9、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Remove the battery connector cover: 手順 9、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Remove the battery connector cover: 手順 9、 3の画像 3
    • Use a 3IP Torx Plus screwdriver to remove the two 1.5 mm‑long screws securing the battery connector cover.
    • Remove the cover.
  10. MacBook Air 15" 2023 Screen Replacement, Disconnect the battery: 手順 10、 2の画像 1 MacBook Air 15" 2023 Screen Replacement, Disconnect the battery: 手順 10、 2の画像 2
    • Use an opening pick to pry up and disconnect the battery connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  11. MacBook Air 15" 2023 Screen Replacement, Unfasten the speaker cable and hinge covers: 手順 11、 2の画像 1 MacBook Air 15" 2023 Screen Replacement, Unfasten the speaker cable and hinge covers: 手順 11、 2の画像 2
    • The right speaker will be on your left-hand side when working on the MacBook, as it's laying upside down.
    • Use a 3IP Torx Plus screwdriver to remove the following screws:
    • Two 2.6 mm‑long screws securing the left hinge cover
    • Two 1.5 mm‑long screws securing the speaker cable cover
  12. MacBook Air 15" 2023 Screen Replacement, Remove the covers: 手順 12、 1の画像 1
    • Remove the speaker cable cover.
  13. MacBook Air 15" 2023 Screen Replacement: 手順 13、 3の画像 1 MacBook Air 15" 2023 Screen Replacement: 手順 13、 3の画像 2 MacBook Air 15" 2023 Screen Replacement: 手順 13、 3の画像 3
    • Insert the point of a spudger into one of the left hinge cover's screw holes.
    • Push the hinge cover away from the back edge to dislodge it.
    • Remove the hinge cover.
  14. MacBook Air 15" 2023 Screen Replacement, Disconnect the right speaker: 手順 14、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Disconnect the right speaker: 手順 14、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Disconnect the right speaker: 手順 14、 3の画像 3
    • Use the point of a spudger to pry up and disconnect the right speaker press connector.
  15. MacBook Air 15" 2023 Screen Replacement, Unfasten the right speaker: 手順 15、 2の画像 1 MacBook Air 15" 2023 Screen Replacement, Unfasten the right speaker: 手順 15、 2の画像 2
    • Remove the three screws securing the right speaker:
    • One 5.5 mm‑long 4IP Torx Plus screw
    • One 2.7 mm‑long 4IP Torx Plus screw
    • One 3.5 mm‑long 6IP Torx Plus screw
  16. MacBook Air 15" 2023 Screen Replacement, Remove the right speaker: 手順 16、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Remove the right speaker: 手順 16、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Remove the right speaker: 手順 16、 3の画像 3
    • Make sure the cable on the top right edge of the speaker doesn't get caught on the logic board, as it may tear.
    • Lift the speaker's left edge over the frame and slide it to the left to remove it.
    • During reassembly, slide the speaker cable under the left edge of the antenna bar assembly before laying the speaker in its recess.
  17. MacBook Air 15" 2023 Screen Replacement, Unfasten the speaker cable and hinge covers: 手順 17、 2の画像 1 MacBook Air 15" 2023 Screen Replacement, Unfasten the speaker cable and hinge covers: 手順 17、 2の画像 2
    • The left speaker will be on your right-hand side when working on the MacBook, as it's laying upside down.
    • Two 2.6 mm‑long screws securing the right hinge cover
  18. MacBook Air 15" 2023 Screen Replacement, Remove the covers: 手順 18、 1の画像 1
  19. MacBook Air 15" 2023 Screen Replacement, Remove the right hinge cover: 手順 19、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Remove the right hinge cover: 手順 19、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Remove the right hinge cover: 手順 19、 3の画像 3
    • Insert the point of a spudger into one of the right hinge cover's screw holes.
  20. MacBook Air 15" 2023 Screen Replacement, Disconnect the left speaker: 手順 20、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Disconnect the left speaker: 手順 20、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Disconnect the left speaker: 手順 20、 3の画像 3
    • Use the point of a spudger to pry up and disconnect the left speaker press connector.
  21. MacBook Air 15" 2023 Screen Replacement, Unfasten the left speaker: 手順 21、 2の画像 1 MacBook Air 15" 2023 Screen Replacement, Unfasten the left speaker: 手順 21、 2の画像 2
  22. MacBook Air 15" 2023 Screen Replacement, Remove the left speaker: 手順 22、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Remove the left speaker: 手順 22、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Remove the left speaker: 手順 22、 3の画像 3
    • Make sure the cable on the top left edge of the speaker doesn't get caught on the logic board, as it may tear.
    • Lift the speaker's right edge over the frame and slide it to the right to remove it.
    • During reassembly, slide the speaker cable under the right edge of the antenna bar assembly before laying the speaker in its recess.
  23. MacBook Air 15" 2023 Screen Replacement, Remove the antenna cables cover: 手順 23、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Remove the antenna cables cover: 手順 23、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Remove the antenna cables cover: 手順 23、 3の画像 3
    • Use a 3IP Torx Plus screwdriver to remove the two 1.5 mm‑long screws securing the antenna cables cover.
    • Remove the cover.
  24. MacBook Air 15" 2023 Screen Replacement, Disconnect the antenna bar: 手順 24、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Disconnect the antenna bar: 手順 24、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Disconnect the antenna bar: 手順 24、 3の画像 3
    この手順で使用する道具:
    $3.99
    • Insert one arm of a pair of angled tweezers under the metal neck of one of the antenna connectors and lift straight up to disconnect it.
    • Disconnect the other antenna.
    • To reconnect antenna connectors, hold each one in place over its socket and press down with the flat end of your spudger. The connector will snap into place.
  25. MacBook Air 15" 2023 Screen Replacement, Unfasten the antenna bar: 手順 25、 2の画像 1 MacBook Air 15" 2023 Screen Replacement, Unfasten the antenna bar: 手順 25、 2の画像 2
    • Use a 4IP Torx Plus screwdriver to remove the two 5.5 mm‑long screws securing the antenna bar.
  26. MacBook Air 15" 2023 Screen Replacement, Remove the antenna bar: 手順 26、 2の画像 1 MacBook Air 15" 2023 Screen Replacement, Remove the antenna bar: 手順 26、 2の画像 2
    • Remove the antenna bar.
  27. MacBook Air 15" 2023 Screen Replacement, Remove the foam pad: 手順 27、 2の画像 1 MacBook Air 15" 2023 Screen Replacement, Remove the foam pad: 手順 27、 2の画像 2
    この手順で使用する道具:
    Tesa 61395 Tape
    $2.99
    • A foam pad hides two screws securing the display and camera cables cover. It's secured with light adhesive.
    • Use tweezers or your fingers to remove the foam pad from the cover.
    • During reassembly, use the leftover adhesive to secure the pad. If the pad doesn't stick, use double-sided tape to secure it.
  28. MacBook Air 15" 2023 Screen Replacement, Unfasten the cables cover: 手順 28、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Unfasten the cables cover: 手順 28、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Unfasten the cables cover: 手順 28、 3の画像 3
    • Use a 3IP Torx Plus screwdriver to remove the four 1.5 mm‑long screws securing the display and camera cables cover.
    • Remove the cover.
  29. MacBook Air 15" 2023 Screen Replacement, Disconnect the display and camera: 手順 29、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Disconnect the display and camera: 手順 29、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Disconnect the display and camera: 手順 29、 3の画像 3
    • Use a spudger to pry up and disconnect the display and camera cable press connectors.
  30. MacBook Air 15" 2023 Screen Replacement, Reassembly information: 手順 30、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Reassembly information: 手順 30、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Reassembly information: 手順 30、 3の画像 3
    • During reassembly, use the flat end of a spudger to gently push the display and camera cables under the logic board.
  31. MacBook Air 15" 2023 Screen Replacement, Unfasten the display and camera cables: 手順 31、 2の画像 1 MacBook Air 15" 2023 Screen Replacement, Unfasten the display and camera cables: 手順 31、 2の画像 2
    • Use a 3IP Torx Plus screwdriver to remove the two 2.8 mm‑long screws securing the display and camera cables to the frame.
  32. MacBook Air 15" 2023 Screen Replacement, Disconnect the lid angle sensor: 手順 32、 2の画像 1 MacBook Air 15" 2023 Screen Replacement, Disconnect the lid angle sensor: 手順 32、 2の画像 2
    • Use the point of a spudger to pry up and disconnect the lid angle sensor from the top left corner of the MacBook.
    • If your replacement screen does not come with a lid‑angle sensor installed on the hinge, you'll need to remove the sensor. Use a 1IP Torx Plus screwdriver to remove the screw securing the sensor. Then, remove the sensor and set it aside for reassembly.
    • During reassembly, if you removed the lid angle sensor, install it on your replacement screen's hinge.
  33. MacBook Air 15" 2023 Screen Replacement, Partially unfasten the hinges: 手順 33、 2の画像 1 MacBook Air 15" 2023 Screen Replacement, Partially unfasten the hinges: 手順 33、 2の画像 2
    • Use an 8IP Torx plus screwdriver to loosen (not remove) the eight hinge screws.
  34. MacBook Air 15" 2023 Screen Replacement, Open your MacBook and set it down: 手順 34、 2の画像 1 MacBook Air 15" 2023 Screen Replacement, Open your MacBook and set it down: 手順 34、 2の画像 2
    • Fully open your MacBook and gently place it keyboard side down on a table so the screen hangs over the edge.
  35. MacBook Air 15" 2023 Screen Replacement, Remove the hinge screws: 手順 35、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Remove the hinge screws: 手順 35、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Remove the hinge screws: 手順 35、 3の画像 3
    • Support the screen with one hand and use your free hand to remove the eight 4.7 mm‑long 8IP Torx Plus screws securing the hinges.
    • Keep a firm grip on your laptop, as it can easily fall off the table.
  36. MacBook Air 15" 2023 Screen Replacement, Remove the screen: 手順 36、 3の画像 1 MacBook Air 15" 2023 Screen Replacement, Remove the screen: 手順 36、 3の画像 2 MacBook Air 15" 2023 Screen Replacement, Remove the screen: 手順 36、 3の画像 3
    • Hold the screen with both hands and lift the hinges out of their recesses to remove the screen.
    • Make sure the screen hinges are fully open and guide them into their recesses in the frame.
    • Install and partially tighten the eight hinge screws.
    • Close your laptop and make sure the screen is properly aligned. If it clicks or snaps, readjust the alignment.
    • Fully tighten the hinge screws.
終わりに
6 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Spencer Day
メンバー登録日: 09/14/22
150,359 ポイント
995のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,660のガイドは作成済み
5件のガイドコメント
hi, I looked for the exact answer to the question in many places, but I couldn't find it. I understand that the display replacement problem only affects the 14" mbp because of the chip, correct?
géza mutyán - 返信
Hi! This guide is for the MacBook Air 15" 2023. We swapped screens between two of these models and found no artifacts. The same is true for the MacBook Air 2022.
You're correct about the MacBook Pros. As this article explains, the problem is with the 14" M1 and M2 MacBook Pro models. The 16" models didn't have artifacts.
Spencer Day -
Is it possible to switch screens between a2941 same model 8gb - 256 base model to 16gb - 1tb model ? well my 1 tb one has broken screen and i am thinking to buy a second hand base model to se its screen.
Harun Sivaslı - 返信
Excellent Guide! It would have been helpful to have a bit better picture of the location of the screen position sensor screw. Everything was perfectly accurate.
Kranky Mikey - 返信
Will a color change, a Starlight screen on a Space Gray body, work? Just looking for available screens and would like the best quality and don't care about color mismatch.
Hog Fillet - 返信
コメントを追加
統計データ:
過去 24時間: 23
過去 7 日: 145
過去 30 日: 678
今までの合計 14,069
