はじめに
For the official, updated iFixit guide, click here. This guide is archived for historical purposes.
必要な工具と部品
Use a P5 driver to remove the following screws:
Two 7.6 mm screws (with a 2.7mm collar)
Two 7.1 mm screws
Six 2.3 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Use a T3 Torx driver to remove the one 1.1 mm screw securing the antenna cable bracket.
Remove the antenna cable bracket.
Lift the antenna bar straight up and out of the case. Take care not to snag the antenna bar on any cables or connectors.
Remove the antenna bar.
Use a T9 Torx driver to remove the six 4.7 mm screws securing the display hinges to the upper case.
2 の人々がこのガイドを完成させました。
2件のガイドコメント
Great guide! Did you encounter any tamper-proof seals? Anything that would make it obvious that the MacBook was disassembled?
No tamper proof seals encountered. Didn’t find anything that would “make it obvious that the MacBook was disassembled”.
