メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
MacBook Air 11" Mid 2011 Upper Case Replacement
必要条件のみ
これは前提条件のみのガイドです!このガイドは別の手順の一部であり、単独で使用されません。
必要な工具と部品
  1. MacBook Air 11" Mid 2011 Upper Case Replacement, Lower Case: 手順 1、 1の画像 1
    この手順で使用する道具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
    FixBotに聞いてみる
    コメントを追加
  2. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 2、 1の画像 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    FixBotに聞いてみる
    コメントを追加
  3. MacBook Air 11" Mid 2011 Upper Case Replacement, Battery: 手順 3、 2の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement, Battery: 手順 3、 2の画像 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
    FixBotに聞いてみる
    コメントを追加
  4. MacBook Air 11" Mid 2011 Upper Case Replacement, Solid-State Drive: 手順 4、 1の画像 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
    FixBotに聞いてみる
    コメントを追加
  5. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 5、 2の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 5、 2の画像 2
    • Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
    • Do not lift the end of the SSD excessively.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
    FixBotに聞いてみる
    コメントを追加
  6. MacBook Air 11" Mid 2011 Upper Case Replacement, I/O Board Cable: 手順 6、 1の画像 1
    • Use the flat end of a spudger to pry the I/O board cable up from its socket on the I/O board.
    FixBotに聞いてみる
    コメントを追加
  7. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 7、 1の画像 1
    • Peel the I/O board cable up from the adhesive securing it to the fan.
    FixBotに聞いてみる
    コメントを追加
  8. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 8、 2の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 8、 2の画像 2
    • Use the flat end of a spudger to lift the I/O board connector up and out of its socket on the logic board
    • Be sure to lift straight up on the connector as you disconnect it from its socket. The socket is very deep on the logic board and prying it from side to side may damage the logic board
    • Remove the I/O board cable.
    FixBotに聞いてみる
    コメントを追加
  9. MacBook Air 11" Mid 2011 Upper Case Replacement, Fan: 手順 9、 1の画像 1
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    FixBotに聞いてみる
    コメントを追加
  10. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 10、 1の画像 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 3.6 mm T5 Torx screw
    FixBotに聞いてみる
    コメントを追加
  11. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 11、 1の画像 1
    • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
    FixBotに聞いてみる
    コメントを追加
  12. MacBook Air 11" Mid 2011 Upper Case Replacement, Battery: 手順 12、 1の画像 1
    • Remove the following five screws securing the battery to the upper case:
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
    FixBotに聞いてみる
    コメントを追加
  13. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 13、 1の画像 1
    • Do not touch or squeeze the six lithium polymer cells when handling the battery.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    FixBotに聞いてみる
    コメントを追加
  14. MacBook Air 11" Mid 2011 Upper Case Replacement, Logic Board: 手順 14、 2の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement, Logic Board: 手順 14、 2の画像 2
    • Use the flat end of a spudger to free the adhesive loop securing the I/O board power cable to the upper case.
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
    FixBotに聞いてみる
    コメントを追加
  15. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 15、 2の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 15、 2の画像 2
    • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Pull the keyboard backlight ribbon cable out of its socket.
    FixBotに聞いてみる
    コメントを追加
  16. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 16、 2の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 16、 2の画像 2
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
    FixBotに聞いてみる
    コメントを追加
  17. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 17、 1の画像 1
    • Use the tip of a spudger to de-route the right speaker cable from the slot cut into the logic board.
    FixBotに聞いてみる
    コメントを追加
  18. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 18、 1の画像 1
    • Use the flat end of a spudger to pry the right speaker cable connector up and out of its socket on the logic board.
    • Pry up from beneath the cables.
    FixBotに聞いてみる
    コメントを追加
  19. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 19、 3の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 19、 3の画像 2 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 19、 3の画像 3
    • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
    • Remove the small rubber gasket from the corner of the upper case near the display data cable.
    FixBotに聞いてみる
    コメントを追加
  20. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 20、 1の画像 1
    • While holding the lock away from the socket, gently pull the display data cable out of its socket.
    • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
    FixBotに聞いてみる
    コメントを追加
  21. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 21、 2の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 21、 2の画像 2
    • Use the flat end of a spudger to pry both antenna cable connectors up and off their sockets on the AirPort/Bluetooth card.
    FixBotに聞いてみる
    コメントを追加
  22. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 22、 1の画像 1
    • Gently de-route the antenna cables from the slot cut into the logic board.
    FixBotに聞いてみる
    コメントを追加
  23. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 23、 1の画像 1
    • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
    FixBotに聞いてみる
    コメントを追加
  24. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 24、 1の画像 1
    • Gently lift the logic board assembly out of the upper case, minding the fragile heat sink and any cables that may get caught.
    FixBotに聞いてみる
    コメントを追加
  25. MacBook Air 11" Mid 2011 Upper Case Replacement, Display Assembly: 手順 25、 1の画像 1
    • Remove the small rubber gasket from the corner of the upper case nearest the I/O board.
    FixBotに聞いてみる
    コメントを追加
  26. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 26、 2の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 26、 2の画像 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the microphone cable ZIF socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the microphone ribbon cable straight out of its socket.
    FixBotに聞いてみる
    コメントを追加
  27. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 27、 2の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 27、 2の画像 2
    • De-route the left speaker cable from the notch cut into the I/O board.
    • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
    • Pry up from beneath the wires.
    FixBotに聞いてみる
    コメントを追加
  28. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 28、 1の画像 1
    • Pull the camera cable parallel to the face of the I/O board toward the rear edge of the Air to disconnect it from its socket.
    • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
    FixBotに聞いてみる
    コメントを追加
  29. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 29、 1の画像 1
    • Remove the single 3.6 mm T5 Torx screw securing the I/O board to the upper case.
    FixBotに聞いてみる
    コメントを追加
  30. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 30、 1の画像 1
    • Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
    FixBotに聞いてみる
    コメントを追加
  31. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 31、 3の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 31、 3の画像 2 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 31、 3の画像 3
    • Peel up the six cable loops securing the antenna cables to the upper case.
    • Gently pull the cable loops slightly out of the channel cut into the upper case one at a time.
    • Use your spudger to open up the plastic loops as you de-route the antenna cables through them.
    • Repeat this for all of the retaining loops.
    FixBotに聞いてみる
    コメントを追加
  32. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 32、 2の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 32、 2の画像 2
    • Remove the inner 4.9 mm T8 Torx screw securing each display hinge to the upper case (two screws total).
    FixBotに聞いてみる
    コメントを追加
  33. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 33、 1の画像 1
    • Open the display until it is perpendicular to the upper case and place it on a table as shown.
    • While holding the Air steady, remove the remaining 4.9 mm T8 Torx screw from the lower display bracket.
    FixBotに聞いてみる
    コメントを追加
  34. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 34、 1の画像 1
    • Before removing the last display screw, be sure to hold the display and upper case steady with your other hand. Failure to do so may allow the components to fall onto the table, causing potentially expensive damage.
    • Remove the last 4.9 mm T8 Torx screw securing the display to the upper case.
    FixBotに聞いてみる
    コメントを追加
  35. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 35、 2の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 35、 2の画像 2
    • Push the upper case slightly toward the display assembly, then rotate it away from the front of the display assembly.
    • Once the two display hinges have cleared the upper case, remove the display and set it aside.
    FixBotに聞いてみる
    コメントを追加
  36. MacBook Air 11" Mid 2011 Upper Case Replacement, Upper Case: 手順 36、 2の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement, Upper Case: 手順 36、 2の画像 2
    • Use the flat end of a spudger to pry the right speaker off the adhesive securing it to the upper case.
    • Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
    • Remove the right speaker from the upper case.
    FixBotに聞いてみる
    コメントを追加
  37. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 37、 2の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 37、 2の画像 2
    • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
    • Remove the left speaker from the upper case.
    FixBotに聞いてみる
    コメントを追加
  38. MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 38、 2の画像 1 MacBook Air 11" Mid 2011 Upper Case Replacement: 手順 38、 2の画像 2
    • Use the tip of a spudger to pry the microphone away from the side of the upper case.
    • Remove the microphone from the upper case.
    • Upper case remains.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
6 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Walter Galan
710,326 ポイント
1,203のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 41
今までの合計 5,767
