メインコンテンツにスキップ
MacBook Air 11インチ Mid 2013のI/Oボードの交換
必要な工具と部品
  1. MacBook Air 11インチ Mid 2013のI/Oボードの交換, 下部ケース: 手順 1、 1の画像 1
    この手順で使用する道具:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $11.99
    購入する
    • まず、コンピューターをシャットダウンし、柔らかい素材の表面上に天面を下にして置きます。
    • 以下の10本のネジを外します:
    • 星型ペンタローブネジ 8mm 2本
    • 星型ペンタローブネジ 2.5mm 8本
    • 星型ペンタローブネジを外す際に必要な特別ドライバーはこちらで購入できます。
    When you say:
    Remove the following ten screws:
    Two 8 mm 5-point Pentalobe screws
    Eight 2.5 mm 5-point Pentalobe screws
    Do the 8mm & 2.5mm dimensions refer to the LENGTH of those screws, or the size of the pentalobe? That is, are there other sizes of pentalobe drivers like there are for hex, phillips and torx? When only one dimension is provided, it is usually the socket/driver size, not the screw length, maybe since the length cannot be seen when the screw is installed.
    Can I suggest that you clarify your instructions so folks are confident they are only in need of _one_ pentalobe driver?
    Nerdily yours,
    Larry (whose iPhone 4S can now get through a day without 6 recharges thanks to ifixit.com ;-)
    larryleveen - 返信
    The 8mm and 2.5mm are the length of the screws. One pentalobe P5 screwdriver suffices for all the screws (P5 is implicitly the size of the pentalobe screw heads).
    Michael Welham -
    I sourced all the parts from ifixit, plus a magnetic project mat which I found to be very useful for organising the teardown and reassembly.
    Allen - 返信
    The magnetic mat is
    GERARD SZAREK -
    Keep the 2.5mm tiny screws away from the MagSafe connector as they will be attracted and sucked in to the magnet.
    Frank O'Carroll - 返信
    A tip an old bench tech taught me that has saved me many times: I put clear “Scotch” tape over the case screws as they became “free”. The tape kept them in place while I lifted the lid off, cleaned it etc.
    Michael Mee - 返信
    Thank you for a really smart tip! I will be using that countless more times!
    Lilljedahl -
    I’m confused about internet recovery and installing MacOS. Is all of this done before placing in the new ssd card or after. I don’t have any files that I would like to safe/transfer, is all of this necessary, if I don’t do it before placing new ssd, will I still be able to instal/upgrade macOS afterwards.
    It’s an old Mac and now it won’t start or charge, I know I will have to replace battery and put new battery first and turn on Mac before doing the ssd stuff. Since it won’t effing start.
    I’m really clueless about backing up old ssd, since I don’t need any files, besides MacOS(software) ,and is that related to the ssd?
    AMG - 返信
    The answer to your question: You need to insert your SSD into the computer before internet recovery. If you start the recovery before inserting SSD, it won’t affect the setup, you won’t damage anything. But your SSD will not be detected (as there isn’t one inserted.)
    Also, a little tip: If you bought a used SSD, go into Disk Utility and format the drive with the highest security level to permanently remove all of the previous files.
    Also a FYI: Internet Recovery will load up Mac OS X 10.9.5 Mavericks, so I would recommend making a recovery drive from a Big Sur (or desired version) through another Mac, and a USB. You can visit this support doc: https://support.apple.com/en-us/HT201372
    Hope this helps! -Dan
    danielwen -
    I got a macbook air with a damaged and swollen battery. I could remove all screws, except one 2,5 mm screw. I’m afraid it got damaged while attempting to remove it, I have no grip with the P5 pentalobe screwdriver. How can I proceed?
    Robert Hermans - 返信
    Hi Robert!
    Try some techniques found in this stripped screw removal guide. Good luck!
    Arthur Shi -
    Hello I have a macbook air they are say they do not have parts for my laptop macbook air 11 inches 2013 mid need to replace battery which one to buy
    vensilver - 返信
    Hello! This is the part you want—maybe we’re not able to ship it to you if you’re out of the United States. The battery in your MacBook Air should be the same for all 11” between mid-2011 to early-2015.
    Arthur Shi -
    The smaller screws went in more easily when I put back all the screws along the hinge edge first.
    Rachel Slatkin - 返信
  2. MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 2、 1の画像 1
    • ディスプレイと下部ケースの間に指を入れ、下部ケースを引き上げて外します。
  3. MacBook Air 11インチ Mid 2013のI/Oボードの交換, バッテリーコネクター: 手順 3、 2の画像 1 MacBook Air 11インチ Mid 2013のI/Oボードの交換, バッテリーコネクター: 手順 3、 2の画像 2
    • 作業中に部品がショートするのを防ぐためにバッテリーを取り外します。
    • スパッジャーの平面側先端を利用し、バッテリーコネクターを持ち上げてロジックボードのソケットから外します。
    • ロジックボードから外したコネクターのケーブルをわずかに曲げて、コネクター部分が誤ってソケットに接触しないようにします。
    When reassembling the connector wire needs to be bent to fit.
    GERARD SZAREK - 返信
  4. MacBook Air 11インチ Mid 2013のI/Oボードの交換, I/Oボードケーブル: 手順 4、 2の画像 1 MacBook Air 11インチ Mid 2013のI/Oボードの交換, I/Oボードケーブル: 手順 4、 2の画像 2
    • スパッジャーの平面側先端を使って、I/Oボード上の各ソケットから左右のI/Oボードケーブルコネクタを持ち上げます。
  5. MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 5、 1の画像 1
    • I/Oボードケーブルを持ち上げて外します。
  6. MacBook Air 11インチ Mid 2013のI/Oボードの交換, ファン: 手順 6、 2の画像 1 MacBook Air 11インチ Mid 2013のI/Oボードの交換, ファン: 手順 6、 2の画像 2
    • スパッジャーの先端を使って、iSightカメラケーブルのコネクタの両側を慎重に押さえて、ロジックボード上のソケットからコネクタの接続を緩めます。
    • ソケットからコネクタを外す際は、慎重にずらしながら作業を行なってください。
  7. MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 7、 2の画像 1 MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 7、 2の画像 2
    • ファンに留められた接着剤からiSightカメラケーブルを剥がします。
    Additionally it seems as though the display assembly I have is from an earlier model with a different built in camera. I don’t care if the camera works, could I chop the cord, power it up, and just no have a working camera?
    Aidan - 返信
  8. MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 8、 2の画像 1 MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 8、 2の画像 2
    • スパッジャーの先端を使って、ファンケーブルのZIFソケット上の固定フラップを注意深く跳ね上げます。
    • ソケットではなく、蝶番で動く固定フラップのみを跳ね上げているか確認してください。
    Be sure you understand how the connector works, if you have to go and look up “apple ZIF connector” and watch a video. The one above flips up from where the tool is pointing at. Again do not damage the connector. Click the second picture to see this!
    joe - 返信
  9. MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 9、 1の画像 1
    • 上部ケースをファンに固定している次の3本のネジを外します。
    • 5.5 mm T5トルクネジー2本
    • 4.6 mm T5トルクネジー1本
    • あるモデルによっては、このサイズの代わりに3.6 mm T5トルクネジが使用されています。
  10. MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 10、 3の画像 1 MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 10、 3の画像 2 MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 10、 3の画像 3
    • ファンを持ち上げますが、上部ケースの底からファンを完全に取り出さないでください。
    • Airからファンを取り出す際に、ソケットからファンのリボンケーブルを慎重に引き抜いてください。
  11. MacBook Air 11インチ Mid 2013のI/Oボードの交換, バッテリー: 手順 11、 1の画像 1
    • 上部ケースにバッテリーを固定している、次の5本のネジを外します。
    • 5.2 mm T5 トルクネジー2本
    • 6 mm T5 トルクネジー1本
    • 2.6 mm T5 トルクネジー2本
  12. MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 12、 1の画像 1
    • バッテリーの取り扱い作業中、6つのリチウムポリマーバッテリーセルを触ったり、握ったりしないでください。
    • ロジックボードに一番近い側の端からバッテリーを持ち上げて、上部ケースから取り出します。
  13. MacBook Air 11インチ Mid 2013のI/Oボードの交換, I/Oボード: 手順 13、 2の画像 1 MacBook Air 11インチ Mid 2013のI/Oボードの交換, I/Oボード: 手順 13、 2の画像 2
    • ロジックボード上のソケットからケーブルを引き抜きながら、I/Oボードの電源ケーブルをロジックボードから接続を外します。
    • Airの正面端側に向けて、ロジックボード表面と平行にケーブルを引っ張ってください。
  14. MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 14、 2の画像 1 MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 14、 2の画像 2
    • 必要であれば、ピンセットを使って、マイクケーブルのZIFコネクタを覆っているテープを剥がします。
  15. MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 15、 3の画像 1 MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 15、 3の画像 2 MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 15、 3の画像 3
    • スパッジャーの先端を使って、マイクケーブルのZIFソケット上の固定フラップを注意深く跳ね上げます。
    • ソケットではなく、固定フラップのみを跳ね上げているか確認してください。
    • ソケットからマイクリボンケーブルをまっすぐ引き抜きます。
  16. MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 16、 2の画像 1 MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 16、 2の画像 2
    • スパッジャーの先端を使用して、コネクター付近のスピーカーケーブルの下からこじ開けて、コネクターをソケットからまっすぐ持ち上げます。
  17. MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 17、 2の画像 1 MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 17、 2の画像 2
    • I/Oボード上の切り欠きからケーブルを巻き戻して外します。
  18. MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 18、 2の画像 1 MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 18、 2の画像 2
    • I/Oボードに最も近い上部ケースのコーナーから、小さなゴム製ガスケットを外します。
  19. MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 19、 1の画像 1
    • I/Oボードを上部ケースに固定している3.6mm T5トルクスネジを1本外します。
    • このネジが3.1mm T5トルクスネジのモデルもあります。
  20. MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 20、 3の画像 1 MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 20、 3の画像 2 MacBook Air 11インチ Mid 2013のI/Oボードの交換: 手順 20、 3の画像 3
    • ケースの端から電源ケーブル付近のI/Oボードを慎重に持ち上げて、ケースの端から引き抜きます。
終わりに
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
21 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
作成者
5人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
465,777 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
コメント 1 件
Great tutorial. I may do this for sure. I get no audio and no microphone on my MacBook air. I took it to Apple and they told me it was hardware and not software. In Settins in Audio, there is no Audio Ouput available and No built in Mic available. Would you imagine this might be what is wrong with my Air?
Jon Bonci - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 9
過去 30 日: 27
今までの合計 8,472
