メインコンテンツにスキップ
Mac mini Mid 2010の電源の交換
必要な工具と部品
  1. Mac mini Mid 2010の電源の交換, ボトムカバー: 手順 1、 2の画像 1 Mac mini Mid 2010の電源の交換, ボトムカバー: 手順 1、 2の画像 2
    • ボトムカバーに切った窪みに親指を置きます。
    • ボトムカバーに塗られている白い点がアウターケースに内接するリングに合うまで、ボトムカバーを反時計回りに回します。
  2. Mac mini Mid 2010の電源の交換: 手順 2、 1の画像 1
    • 底部カバーが外側ケースから外れるぐらいまでmini を傾けます。
    • ボトムカバーを取り外して脇に置きます。
  3. Mac mini Mid 2010の電源の交換, ファン: 手順 3、 1の画像 1
    • アンテナプレートの近くのロジックボードにファンを固定している2本の11.3 mm T6トルクスネジを取り外します。
    There are actually 3 T6 screws securing the fan. The third screw is out of the screenshot, just below the RAM.
    inferno10 - 返信
    Nope, that third screw is actually just a post that the rubber grommet attached to the fan body slips over. Step 4 shows how the fan comes off of it. When you go to remove the fan, you simply remove the two screws closest to the antenna plate and then lift the fan off this post. The screw you are talking about is removed in Step 14 and does not need to be removed until this point.
    Andrew Bookholt -
    Successful install completed, but I had some trouble getting the fan reinstalled. When I removed the fan from the "Step 14" post, the rubber piece stayed on the post. When attempting to reinstall the fan, it was impossible to get the loop to go back over that rubber piece. So, I had to remove the post (again), and with the help of the spudger and some patience, worked it through. Then installed the fan using the 2 screws and the post. I think it may have saved some time and trouble if I just removed all 3 in the first place, leaving the post in the fan.
    meag -
    On mine I needed to remove the 26 mm T6 Torx standoff during this step rather than step 12
    philipashlock - 返信
    on my mid-2011 mac mini, that 3rd T6 post/screw had to be removed to get the fan out. It goes right through a hole in the fan housing. No way the grommet is slipping over anything without wreaking major havoc.
    Derek Shaw - 返信
    On my mid-2010 mac mini, also removed the 26 mm T6 Torx standoff during this step instead of step 12. Having completed the steps, it appears my hard drive is from mid 2011, so maybe the production line for mine had changed.
    jstraath - 返信
  4. Mac mini Mid 2010の電源の交換: 手順 4、 1の画像 1
    • RAMに最も近いファンの耳を、外側ケースに固定されたスタンドオフから持ち上げて持ち上げます。
    • 適度な力でファンがスタンドオフネジから分離しない場合は、T6トルクスドライバを使用してこのネジを単に取り外すことができます。
    Pulling on the ear didn't do anything, so I removed the whole screw at this step. The screw stayed fixed on the fan and I didn't have to remove it at the step where you remove the logic board screws.
    Probably I didn't want to use too much force .. but it worked
    Alexander Kogler - 返信
    This is the approach I used. no way was the "ear" pulling over the head of the standoff without breaking something. The standoff simply unscrewed from whatever is under the logic board and stayed with the fan assembly. WAY safe
    Derek Shaw -
    Loosen the fan standoff from the motherboard using a T6 driver.
    bobcloninger - 返信
    When I pulled the fan ear off the standoff the rubber grommet stayed on the standoff. That's fine, but it makes it difficult to put the fan ear back on during reassembly. So I just pulled the rubber grommet off the standoff and put it into the hole in the fan ear. Then I was able to push the fan ear onto the standoff with out trouble during reassembly.
    Dave Hein - 返信
  5. Mac mini Mid 2010の電源の交換: 手順 5、 1の画像 1
    • miniのコネクターにアクセスするためにminiからファンをを持ち上げます。
    • 注意深くファンコネクタをロジックボード上のソケットから持ち上げるため、ファンケーブルを上に引っ張ります。
    • ファンを取り外します。
    Be careful here, this is not a simple action. Pulling on the wires risks them coming out of the sockets of the connector that attaches to the pins on the board. I had to use an Xacto knife to push on the end of the connector to push it off the pins rather than pull.
    Brian - 返信
    Actually, just sliding a spudger under the wires and edging upwards is the easiest way to disconnect this connector - and most others, too.
    Aleks Gekht -
  6. Mac mini Mid 2010の電源の交換, カウリング: 手順 6、 1の画像 1
    • ヒートシンクにカウリングを固定している3.5 mm T6トルクスネジを1本取り外します。
    This is a screw into the head of another screw below it that holds the main board. When I took out the fan, the top screw AND the longer 26 mm screw came out together so when I was putting my mini back together I thought for a moment I had lost a screw.
    info - 返信
  7. Mac mini Mid 2010の電源の交換: 手順 7、 1の画像 1
    • アンテナプレートに最も近い端からカウリングを持ち上げます。
    • アウターケースからカウリングを回して外し、mini本体から取り出します。
    This is wrong step. If you need remove this out, it would be better to pull out logic board, and remember to remove cables attached on it before pull out.
    Lin Adison - 返信
  8. Mac mini Mid 2010の電源の交換, アンテナプレート: 手順 8、 1の画像 1
    • miniにアンテナプレートを固定している次のネジを外します。
    • 6.6 mm T8トルクスネジー2本
    • 5.0 mm T8トルクスネジ、もしくは2.0 mm六角ネジー2本
    The red circled screws are T9 in my Mac mini (not T8).
    Sven Harmstorf - 返信
    ditto here - the 6.6 mm screws that anchor to the HD (now SSD) are T9
    Derek Shaw -
    I have tried several times but I have been unable to get all four holes to line up when replacing the antenna plate. I can get the two closer to the center of the mini just fine but no matter how I align the plate, one of the screws closer to the edge of the mini will be so far out of alignment that I cannot get the screw to go in. I had to leave one screw uninstalled. The plate is not distorted in any way. It is installed the same way it was before I removed, as far as I can tell. I am baffled! Has anyone been through this?
    GalvanicMacPro - 返信
    Galvanic, it pops in.
    bkbkbk -
    I had a really hard time with this. I was able to resolve it though: secure the other three screws first. Then I pushed my precision screwdriver into the hole and levered the wayward tab into position: it wedged in with an audible snap sound! Then I was able to fasten the final screw.
    Aaron Vegh -
    I have trouble with this step every time I repair one of these minis. Aaron, your tip worked perfectly for me, thanks. -Anne
    DA IT Department -
    The antenna plate assembly is a tongue and groove type. The plate has a "groove" and the rim of the outer case is the "lip". You have to slide it in and align the parts ant it fits perfectly .
    jvilella -
    To solve this, just pick on the plate on the semi circle side and with the tool "open" just slighter the space where the semicircle have to fit
    Pedro -
    Had the same problem - the reason was the replacement drive I used - it is thinner than the original one. So I could not get the far side of the drive correctly into the holes for the notches mounted on the drive; that is - the drive was always a little bit too far to the center of the mac case. Everything works fine until you try to install all four screws.
    I found a simple solution: I attached some adhesive tape temporarily to the drive cover. By pulling on the tape while pushing the drive in its space the notches slipped into their holes. After this installing the antenna was no problem any more.
    Erwin Sommerauer -
    The key to this is to use needle-nose pliers to grasp the grate between the black plastic circle and the edge of the mini's case, and pull upwards (away from the hard drive beneath it). It will snap into place, and then the screw holes will line up.
    Brian -
    I had a similar problem with getting the antenna cover to fit back into place. I tried putting 3 screws back in and levering the 4th, but it did not work in my case. Finally, with three screws in place,, I carefully placed a thin pair of forceps into one of the holes in the cover and levered the entire cover upwards. That worked for me.
    Don - 返信
    Pulling up on the cover worked for me too. I found that the best place to pull up on the cover is at about "true north" in the picture ... near the black dot used to indicate lid-is-closed. I did it before installing any screws and all four screws went in fine.
    Fred Cat -
    As others have noted, the hardest part of the whole process is getting the holes lined up in reassembly. I ended up stripping one of the short screws, but it fits well enough to engage the slots in the circular plastic cover. If you leave a short screw out, I don't know how the bottom cover would fit securely. I would carefully note how the antenna cover fits while you remove it. The longer screws go into the actual hard drive, so I think alignment of the hard drive is part of the problem.
    Steve Dollar - 返信
    I had same problem..! U tried EVERTHING, and what worked PERFECT for me, and with very little effort is what "x10target" described here (scroll about half way down): Difficulty in re-installing Antenna Plate
    Mikey Marvel - 返信
    To replace the antenna plate, you need to patiently align the sides of the antenna and slide it in. I had similar problems as described above but, instead of using force, I resorted to patience. The plate's fit is very snug, just a little bit off the straight line and it won't sit properly. And when it sits, it really sits tight, you don't even need to hold it in place while screwing the screws back in.
    Eric Schneider - 返信
    In the “arch” of the plate is sort of a tongue & groove that fits over & under the lip of the body. I used Kelly Forceps to coax everything back together.
    tom - 返信
    After replacing the HDD with an SSD, I found that one of the front locating screws didn’t fit back in (no corresponding screw hole on the new drive caddy). I also found it hard to fit the antenna plate back in the slot, but found that removing one of the rubber “feet” (where there was no longer a corresponding screw hole on the disk) helped a lot, as did gently folding back the edge of the antenna plate. Refitting this was definitely the hardest part of the process - excellent instructions!
    Tim Cutting - 返信
    After completing the whole operation, impossible to screw the two T8 5mm (orange ones) screws back in place. The plate sit properly, but the screws just wobble, even with full force when trying. I can’t close the backplate. Anybody had the same issue?
    Pierre Prézelin - 返信
    BEFORE putting any screws in, you have to get the antenna place to “snap” intot he Aluminum chassis first. Once that is snapped in, the screw holes all line up nicely.
    I installed an SSD, which is thinner than the original HDD, so the two recessed screws don’t reach it… Going to just leave them taped into their holes. I’m hoping that will not affect antenna function too much (It will remove some potential grounding to the HDD).
    Demis John - 返信
  9. Mac mini Mid 2010の電源の交換: 手順 9、 2の画像 1 Mac mini Mid 2010の電源の交換: 手順 9、 2の画像 2
    • RAMに一番近い端からアンテナプレートをわずかに持ち上げます。
    • アンテナプレートをアウターケースの円形リムから慎重にまっすぐ引き離します。
    • AirPort/Bluetoothボードに装着している状態のアンテナプレートは、まだ外さないでください。
    When I tried to do step 9 and disconnect these connectors, I found that not only the cable/connector but the receptacle tore off the logic board -- momentary panic! This happened to both connectors.
    Left on the logic board were two tiny fragile gold pins (per connector). Fortunately they were pretty straight, and upon re-assembly, I was able to gently slot the receptacles back into the tiny pins. Upon reassembly, everything's working fine (no crazy fan noise) so I guess I got lucky...maybe VERY lucky. :)
    Thanks iFixIt for a fantastic guide. I've got a replacement drive in there and it's definitely going to extend the life of my Mini for another season.
    David Das - 返信
  10. Mac mini Mid 2010の電源の交換: 手順 10、 1の画像 1
    • スパッジャーの先端を使って、AirPort/Bluetoothボードからアンテナコネクタを注意深く持ち上げます。
    I broke the connector on the bluetooth board when trying to remove the antenna when I tried to replace the hard drive. Currently, the exact replacement bluetooth board 607-6509A is very hard to find or otherwise, expensive. Instead, I was able to use a cheap replacement that can be found on eBay: Apple Macbook Unibody A1342 Airport Bluetooth Module 607-6771A. There is a black plastic sheath at the back of the 607-6771A. Just cut out the part that cover the 2 holes, you are good to go.
    millicurie77 - 返信
    Good info, thanks
    maccentric -
    Hmmm just broke the port as well; it is tricky and sticky even after the port came off …
    Choat - 返信
    Thanks for the info; my port just broke here as well :( It is sticky and port connector is so fragile!
    Choat - 返信
    it’s so painful ! almost all the time is spend to try to put this ridiculous connector. my last mini mac is a server, and use ethernet not the wifi so i gave up after 1 hour .
    admin - 返信
    It would be nice if there was a close up pic of the different connectors. Then, one would know how the connectors attach. In this case, this connector is kinda like an old “F” plug. Used Kelly Forceps to pull straight up. Came off and went back on. No sweat.
    tom - 返信
    Tom, it was bear trying to put this “F” connector back on. There’s a torx screw right where the connector should lay down, and it appears to put it in a bind making it difficult to seat. I’ll try to post a picture of mine.,
    Kirk Carver -
    2nd time I did this step (due to breaking the HD heat sensor board the 1st time - see all the comments below!) I didn’t disconnect the airport antenna, since it was so difficult for me to re-plug back in (took ~5 minutes of trying); very hard to line up properly. Instead, I carefully flipped the cover over and to the side, pushing down on the connector to keep it from unplugging. (Since I already had put in a 7mm SSD the 1st time around, the antenna wire also wasn’t in the way when pulling it out.) I recommend trying this due to 3 comments above who broke theirs.
    amiller770 - 返信
    I left it plugged in and flipped it over to tape it to the chassis.
    chris warren - 返信
    Reconnecting the antenna connector to the Airport/Bluetooth board was the second most difficult step for me. It was not just the reverse step of using the spudger to disconnect the connector.
    Marc - 返信
  11. Mac mini Mid 2010の電源の交換: 手順 11、 1の画像 1
    • miniからアンテナプレートを取り外します。
    When you replace the antenna plate, it can be tricky. The curved edge of it actually slots both over and under the edge of the case. If it doesn’t seem to fit properly, the edges of the cut perforations may be slightly squashed. Tweak them with a small screwdriver and it will suddenly seat properly.
    Ben G - 返信
    This is as far as I needed to go. The only connection I needed to remove was the fan (I probably could have left that connected and just moved it out of my way). I was able to set the antenna to the side without disconnecting it. I was able to pull the hard drive out after step 11. I did not disconnect the temp sensor from the board. I removed the tape holding the sensor wire to the side of the hard drive and then removed the sensor from the hard drive and moved it out of my way. It has to be pulled off the hard drive anyway, so better to do it this way then messing with connection on logic board. When replacing the hard drive, reapply the sensor to the end of the hard drive with a very small amount of clear silicone and a piece of black electrical tape to hold it into place while the silicone sets up. Not having to disconnect all the wires from the logic board is the way to go. Stop at step 11 and go straight to step 17.
    Kevin Ginther - 返信
    Excellent advice, Kevin…I did the same and HDD came out no problem…Thank you for the pointer.
    Jurgen -
    If you look at the edge of the antenna plate near the Mac mini body, you'll see a groove where the metal from the unibody fits. I found that if you turn the mini around so the antenna plate is closest to you and us the pointy end of a spudger to lift and place the antenna plate, you can get this groove to fit properly and the screws pop into place.
    rothgar - 返信
  12. Mac mini Mid 2010の電源の交換, ロジックボード: 手順 12、 1の画像 1
    • 次の3本のネジを外します。
    • 5.0 mm T8トルクス、もしくは 2.0mm六角ネジ-1本
    • 16.2 mm T6トルクスネジ-1本
    • 26 mm T6トルクススタンドオフ-1本
    In my case, the yellow circled standoff already came out with the previously removed fan.
    Sven Harmstorf - 返信
    My standoff screw was really tight and my T6 stripped the screw. :( But, because it's effectively just used as a post to stabilise the fan, I ended up using some surgical clamps, grabbing the standoff where the rubber grommet sits, and gently twisted the screw loose. No major damage because that part of the screw isn't really used! Just be careful and gently twist (patience is KEY) to loosen.
    alc217 - 返信
    The weak design of the long standoff screw (not enough material around the star-patterned socket head) has probably caused damage of the internal head during production of the Mac Mini!
    The standoff screw was in my case extremely tightened and the T6 Torx screw driver could not be used anymore (due to damage of the socket head after applying too much torque during the original assembly).
    I needed to use a High Leverage Combination Plier in vertical position to loosen the screw without damage to other parts. I tried to keep the rotation axis of the screw at the centre of the flat nose of the plier. Minor scratches to the screw can not be avoided in this way.
    Marc - 返信
  13. Mac mini Mid 2010の電源の交換: 手順 13、 2の画像 1 Mac mini Mid 2010の電源の交換: 手順 13、 2の画像 2
    • 両側のハードドライブのサーマルセンサーのワイヤーを慎重に引き上げた後、コネクターを持ち上げてロジックボードのソケットから外します。
    The thermal sensor is VERY delicate, hold the connector down with a spudger and lift the cable with some tweezers. Long list of people online who have accidentally removed the connector from the logic board because the solder is insufficient.
    anthonypshaw - 返信
    I second the comment about using something, say a small screwdriver, to carefully put some pressure on the connector whilst then prying the cable up.
    Simon Martin - 返信
    Excellent advice - thanks. I used a small set of tweezers to gently lift up enough cable to hold onto, and then to hold the sockets onto the logic board whilst I pulled! Success!
    Mike Haines - 返信
    Note: the clips lift straight up, although after they are removed, it appears that tiny "prongs" are in the remaining socket. What look like tiny prongs are just horizontal wires. To replace, push the clips straight down. I used metal picks (like fine bent ice picks - available at Harbor Freight) to get under the edge of the plastic clip and lift up. I pulled gently on the wires with tweezers as I pried up the clips, but I would not count on pulling alone to get the job done.
    Steve Dollar - 返信
    Don’t have these, solid state drives?
    chris warren - 返信
    I wanted to change the Superdrive on a 2010 Mac mini and when I took off the thermal connector from the hard drive, one of the two cables came off.
    The hard drive has 2, it is the one on the other side of the SATA connector.
    If you don't connect that cable, the fan always starts at 5000rpm. It is Apple Part Number: 076-1369
    I was looking on Ebay/Ali and the cable is for €9, luckily you can insert the cable back into the connector and put a drop of thermal silicone to apply force and so far it works ok.
    morrit - 返信
  14. Mac mini Mid 2010の電源の交換: 手順 14、 2の画像 1 Mac mini Mid 2010の電源の交換: 手順 14、 2の画像 2
    • スパッジャーの平面側先端を使って、ハードドライブ と光学ドライブのコネクタ両方を、ロジックボードのソケットからこじ開けます。
    The removal of the SATA connectors for the hard drive and the optical drive should probably be separated into two steps. It's easy to miss the second one and pull a SATA connector off.
    Not confirming that I did it, but I am looking for someone to solder a SATA connector back on. ;)
    jrmn - 返信
  15. Mac mini Mid 2010の電源の交換: 手順 15、 1の画像 1
    • 光学ドライブのサーマルセンサーを外すには、親指とスパッジャーの間にケーブルを挟み、スパッジャーを上向きにこじ開けて、ロジックボードのソケットからコネクターを持ち上げます。
    These sensors are too fragile in some cases. In my case both the hard drive and optical sensor cables tore off despite all my best efforts. The plastic holding down the cables appears to be too fragile or brittle and simply tears as the cables are pulled away.
    nirv - 返信
    Pulling the socket off the board seems to be a common problem. I am going to investigate making a tool to hold down the socket while prying up on the plug.
    For the time being I am using an app that controls the fan speed by sampling other sensors, such as the CPU heat sink.
    papa Hajek - 返信
    There are two problems with these connectors. First off they're made of very thin plastic so break easily (something addressed in later Mac mini's). Second the socket melts to the connector making it impossible to lift it.
    If you do break it the metal tabs of the socket should we easily resoldered. Some practice beforehand, a fine tip solder iron, some leaded solder and your away.
    Brent - 返信
    En mi caso perdi el sensor de la unidad optica y ahora el ventilador se mantiene acelerado y no se si para que vuelva a su velocidad normal habré de conseguir el sensor optico. (cuando hice las pruebas con el equipo abierto, mientras probaba otra unidad optica no me daba esa falla).
    Monserrat Bojorges Flores - 返信
    Don’t see this connection, wires, only an empty connector.
    chris warren - 返信
    When in doubt which of the two nearby sensors is the HD or the optical drive thermal sensor during assembly (!), look for instance at the guide to remove the hard drive. The two thermal sensors of the hard drive (see step 13 of this guide) are taped to the outside of the HD. The cable of the optical drive thermal sensor is below the HD (with the Mac mini upside down).
    Marc - 返信
  16. Mac mini Mid 2010の電源の交換: 手順 16、 1の画像 1
    • スパッジャーの先端を使って、ロジックボード上のソケットからIRセンサーコネクタを持ち上げて外します。
  17. Mac mini Mid 2010の電源の交換: 手順 17、 3の画像 1 Mac mini Mid 2010の電源の交換: 手順 17、 3の画像 2 Mac mini Mid 2010の電源の交換: 手順 17、 3の画像 3
    この手順で使用する道具:
    Mac mini Logic Board Removal Tool
    • ロジックボードを取り外すには、赤で表示されている穴に2本の円筒形ロッドを挿入してください。 赤で表示されている穴以外のロジックボードの穴に挿入してしまうと、ロジックボードが破損する可能性があります。
    • 赤で表示されている2つの穴にMac mini ロジックボード用取り外しツールを挿入します。 作業を続ける前に、ロジックボード下のアウターケースに接触していることを確認してください。
    • ロジックボード取り外しツールが手元にない場合は、直径2.5mmの2つのツールで代用できます。 ハイライトされた各穴に1つずつ挿入するだけです。
    • ツールをI/Oボード側に向かって慎重に引きます。 ロジックボードとI/Oボードアセンブリは、アウターケースからわずかにスライドして取り出せます。
    • I / Oボードがアウターケースから外れていれば、こじ開ける必要はありません。 Mac miniロジックボードの取り外しツールを取り外します。
    I had a couple of 3/32" drill bits in my tool chest. Worked perfectly (2.38 mm)
    Derek Shaw - 返信
    two fischertechnik screw drivers work perfectly as well!
    Norbert Wagner - 返信
    Used 2 bigger paperclips. Straightened into single wire. Then in one of the previous bends I had bent it again and squeezed with pliers together so I have 2 "legs" of this improvised tool for better stiffness of wire. Went out nicely. It actually looks like a older hairpin, but more flattened...
    But now I see there is a lot of paperclips on the market. Only the "smaller" ones I might use to bent it into 3 parts. So it depends of what is lying around.
    Petr Sourek - 返信
  18. Mac mini Mid 2010の電源の交換: 手順 18、 1の画像 1
    • I/Oボードの両端にある2つのプラスチッククリップをI/Oボードの中央に向かって同時に押し、I/Oボードを外側のケースから引き離します。
    I’ve popped the logic board out a little bit, but it won’t move any further. I can’t see what the clips are or how to work them.
    Ben - 返信
    Look at step 20 below - you see one of these connectors on the side of the IO board, just under the fingers.
    Aleks Gekht -
  19. Mac mini Mid 2010の電源の交換: 手順 19、 1の画像 1
    • 電源コネクタにアクセスできるだけの十分なスペースができるまで、I/Oボード/ロジックボードアセンブリをアウターケースから引き出します。
    • ピンセットを使って、ロジックボードから電源ケーブルの接続を外します。
    • 電源ケーブルコネクタを、光学ドライブの開口部に向けて引っ張ります。
    Tweezers aren't strong enough. Use some small needle-nose pliers. Hold the I/O board and it pull away.
    Tyrone Steele - 返信
    By the time you get to this step, the hard drive can be easily removed by simply sliding it out over the logic board. Then you can simply pull off the cable with your fingers. When re-assembling, again, attach the power cable connector first, with your fingers and slide the logic board all the way in. Then slide the hard drive in over the logic board.
    Aleks Gekht - 返信
    I suggest to list this specific type of tweezers as shown in Step 19 at the beginning as useful/recommended tool to reconnect (!) the power cable. I could pry the power cable with the blunt side of a scalpel knife. But I sorely missed something like this tweezer when trying to reconnect the cable.
    Marc - 返信
  20. Mac mini Mid 2010の電源の交換: 手順 20、 1の画像 1
    • ケーブルが巻き込まれないよう注意しながら、ロジックボードアセンブリを注意深くスライドして、miniから取り出します。
  21. Mac mini Mid 2010の電源の交換, 電源: 手順 21、 1の画像 1
    • 電源と光学ドライブをアウターケースに固定している7.9mm T6トルクスネジを外します。
  22. Mac mini Mid 2010の電源の交換: 手順 22、 2の画像 1 Mac mini Mid 2010の電源の交換: 手順 22、 2の画像 2
    • アウターケース側面からシルバーのメタル製AC-Inソケットリテーナーを引き離して、miniから取り外します。
  23. Mac mini Mid 2010の電源の交換: 手順 23、 2の画像 1 Mac mini Mid 2010の電源の交換: 手順 23、 2の画像 2
    • AC-Inコネクタを90度反時計回りに回転させます。
  24. Mac mini Mid 2010の電源の交換: 手順 24、 1の画像 1
    • ケーブルが巻き込まれないよう注意しながら、miniから電源をスライドして取り出します。
    I had to wiggle the power cable to help remove the power supply.
    Simon Martin - 返信
    The plastic tab with the 7.9 mm T6 Torx screw which secures the power supply has an internal lip which may get caught on the part underneath. Lift the tab to slide out the power supply.
    Ben Patterson - 返信
    When re-installing the power supply, double check the position of the plug before inserting back into the chassis. Keep in mind that you need to hold the plug in that earlier (90 deg counter clockwise) position as you slot it in, otherwise you'll have a heck of a time twisting the plug back properly.
    alc217 - 返信
    I remove the harddrive first, then you have better access to the power supply. Its already loose at this point.
    Heiner Melling - 返信
終わりに
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
21 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
7人の作成者と共同で作成されました。
Andrew Bookholt
592,004 ポイント
619のガイドは作成済み
コメント 1 件
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 63
今までの合計 21,879
