メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Mac Pro First Generation Power Supply Unit Replacement
必要な工具と部品
    1. Mac Pro First Generation Power Supply Unit Replacement, Case Panel: 手順 1、 1の画像 1
      • Lift the lever to unlock the case.
      FixBotに聞いてみる
      コメントを追加
    2. Mac Pro First Generation Power Supply Unit Replacement: 手順 2、 1の画像 1
      この手順で使用する道具:
      Anti-Static Wrist Strap
      $7.95
      • Remove the side panel of the Mac Pro.
      • Discharge any static electricity by touching a grounded surface prior to working on any internal components. Touching the metal PCI slot covers works great, or any other grounded metal surface. You can also wear a anti-static wrist strap.
      FixBotに聞いてみる
      コメントを追加
    1. Mac Pro First Generation Power Supply Unit Replacement, Removing the Disk Drive: 手順 3、 3の画像 1 Mac Pro First Generation Power Supply Unit Replacement, Removing the Disk Drive: 手順 3、 3の画像 2 Mac Pro First Generation Power Supply Unit Replacement, Removing the Disk Drive: 手順 3、 3の画像 3
      • The optical drive must be removed to access the power supply unit
      • Firmly grasp the handles of the shown compartment and pull out firmly to remove the optical drive bay.
      FixBotに聞いてみる
      コメントを追加
    2. Mac Pro First Generation Power Supply Unit Replacement, Unplugging the Disk Drive: 手順 4、 2の画像 1 Mac Pro First Generation Power Supply Unit Replacement, Unplugging the Disk Drive: 手順 4、 2の画像 2
      • Firmly hold each of the two connectors and pull them out of their respective sockets.
      FixBotに聞いてみる
      コメントを追加
    3. Mac Pro First Generation Power Supply Unit Replacement, Un-Mounting the Power Supply Unit: 手順 5、 2の画像 1 Mac Pro First Generation Power Supply Unit Replacement, Un-Mounting the Power Supply Unit: 手順 5、 2の画像 2
      • Remove the 4 marked 6-32 hex screws with a 2mm Phillips hex screwdriver.
      • There are a number of Phillips head screws underneath. These don't need to be removed to remove the power supply.
      • Note the different PSU for Mac Pro 1,1 through 3,1 versus Mac Pro 4,1 and 5,1.
      FixBotに聞いてみる
      コメントを追加
    4. Mac Pro First Generation Power Supply Unit Replacement, Removing the Power Supply: 手順 6、 3の画像 1 Mac Pro First Generation Power Supply Unit Replacement, Removing the Power Supply: 手順 6、 3の画像 2 Mac Pro First Generation Power Supply Unit Replacement, Removing the Power Supply: 手順 6、 3の画像 3
      • Be careful when pulling the power supply out, as it has several attached cables which don't have much slack.
      • Grip the handle on the left side of the power supply casing while gripping the right side of the power supply casing and pull upwards firmly to to take it out.
      FixBotに聞いてみる
      コメントを追加
    5. Mac Pro First Generation Power Supply Unit Replacement, If power Supply only comes out a few Inches.: 手順 7、 2の画像 1 Mac Pro First Generation Power Supply Unit Replacement, If power Supply only comes out a few Inches.: 手順 7、 2の画像 2
      • For the Mac Pro (Early 2008/9), a.k.a. MacPro3,1 In the MacPro3,1, the power supply screws are 2.5mm hex, not T-10. Also, there is a cover plate behind the superdrive that has to be removed (2 phillips screws) to expose the power cable connections and those connectors must be detached and slid under fan before the power supply can be removed.
      FixBotに聞いてみる
      コメントを追加
    6. Mac Pro First Generation Power Supply Unit Replacement, Disconnecting the Power Supply: 手順 8、 2の画像 1 Mac Pro First Generation Power Supply Unit Replacement, Disconnecting the Power Supply: 手順 8、 2の画像 2
      • Locate the four marked cables
      • Push down on the clip that is above each cable connector while firmly grasping each connector and pull each one back to remove each clip.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
79 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Eric Kuhta
メンバー登録日: 10/12/14
1,241 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 6-24, Maness Fall 2014 Cal Poly, Team 6-24, Maness Fall 2014人のメンバー
CPSU-MANESS-F14S6G24
4 メンバー
25のガイドは作成済み
23件のガイドコメント
15 min power on after off
Manish Kumar - 返信 共有
Hi
Very difficult to find the exact size of the bit for the screwdriver. And it is very tight to unscrew one of the screws.
Maybe I had spoiled the head of the screw.
What is the solution?
Thank you in advance.
Michel
Michel - 返信 共有
missing a very crucial step before step 6. if you don't remove the cover (where cd rom is) and unplug the PSU cable, you'll damage something.
for screws, 2.5mm didn't work for me, but i used a 3/32 hex with ball end, and at an angle, it will loosen screws.
Tino - 返信 共有
Doesn't work for a micron. Step 6 is impossible. Can't get the power supply out of its place more than a few centimeters. The side closest to the backplate of the casing can't come up only some millimeters, while also the fixed!! power cord is a serious obstruction.
Moreover there are nowhere cover plates left, so this is not a comparable situation as described in step 7.
Hugo Walg - 返信 共有
My last remark should be forgotten. The power cord has been connected to the Mac pro to give the impression that it's mounted fixedly to the power supply. But if you pull with very much force (an attempt of despair), it then again appears to be a 3-hole connector like is the case for common computers. If you don't know these systems, this is very treacherous.
Hugo Walg - 返信 共有
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 57
過去 30 日: 280
今までの合計 89,361
