メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Mac Powerbook 140 Hard Drive Replacement
必要な工具と部品
  1. Mac Powerbook 140 Hard Drive Replacement, Opening the computer(bottom): 手順 1、 1の画像 1
    • Turn the 140 upside down and remove the 4 screws in the bottom with a T10 star-headed screwdriver
    FixBotに聞いてみる
    コメントを追加
    • Being careful to hold the top and bottom halves of the computer together, turn to the back side of the computer and remove the final screw with a T17 Star-headed screwdriver.
    FixBotに聞いてみる
    コメントを追加
    • Slide the battery panel or switch(depending on your battery) toward the front of the computer, then pull the battery straight out.
    FixBotに聞いてみる
    コメントを追加
  2. Mac Powerbook 140 Hard Drive Replacement, Removing the screen/keyboard: 手順 4、 2の画像 1 Mac Powerbook 140 Hard Drive Replacement, Removing the screen/keyboard: 手順 4、 2の画像 2
    • CAREFULLY lift the back of the screen and keyboard unit(the top of the computer) and GENTLY push the front left and right corners away from the bottom unit until a click is heard. Then, SLOWLY lift the top unit and remove the interconnect cable (the large somewhat brittle cable connecting the two halves) from its socket in the sisterboard.
    FixBotに聞いてみる
    コメントを追加
    • Using the T-17 Star headed screwdriver, take out the screws holding in drive retainer that covers the hard drive and floppy disc drive. Some of these screws may be inserted very tightly. If any stick, CAREFULLY use a pair of needle-nosed pliers to twist the screw out.
    FixBotに聞いてみる
    コメントを追加
    • Now, remove the long, flat HDA cable from the hard drive by pulling the white plastic piece directly out of the bottom of the hard drive. Be sure to do this CAREFULLY, as the flat cable can easily become disconnected from the plastic piece. Should this happen, pull the top and bottom of the piece away from each other and GENTLY re-insert the cable.
    FixBotに聞いてみる
    コメントを追加
    • Locate your new and COMPATIBLE hard drive. Ensure that is is in proper working order and will not damage your computer or pose any health or safety risk to you.
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. Once complete, start up your computer to ensure the hard drive works. Should you have any issues, ensure all connections were made correctly and that all parts were properly replaces. For further questions, refer to this guide or to the iFixit Answers Forum.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jack
メンバー登録日: 10/23/15
810 ポイント
3のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 52
今までの合計 1,830
