メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Lytro First Generation Light Sensor Replacement
必要な工具と部品
  1. Lytro First Generation Light Sensor Replacement, Light Sensor: 手順 1、 1の画像 1
    • Lytro has closed its doors, and can no longer service your camera if you break it further during this repair. They also cannot provide replacement parts to other camera repair shops.
    FixBotに聞いてみる
    コメントを追加
  2. Lytro First Generation Light Sensor Replacement: 手順 2、 3の画像 1 Lytro First Generation Light Sensor Replacement: 手順 2、 3の画像 2 Lytro First Generation Light Sensor Replacement: 手順 2、 3の画像 3
    • Remove the lens covering by using the plastic opening tool to pry it away from the camera. There are strong magnets attached to the bottom so some force is required.
    FixBotに聞いてみる
    コメントを追加
  3. Lytro First Generation Light Sensor Replacement: 手順 3、 3の画像 1 Lytro First Generation Light Sensor Replacement: 手順 3、 3の画像 2 Lytro First Generation Light Sensor Replacement: 手順 3、 3の画像 3
    • Remove the four screws surrounding the lens using a screwdriver.
    • The screws hold the lens and screen assemblies together.
    FixBotに聞いてみる
    コメントを追加
  4. Lytro First Generation Light Sensor Replacement: 手順 4、 3の画像 1 Lytro First Generation Light Sensor Replacement: 手順 4、 3の画像 2 Lytro First Generation Light Sensor Replacement: 手順 4、 3の画像 3
    • The seperation of the lens assembly and the screen assembly allows access to the motherboard
    • gently disconnect the two ribbon cables (indicated in red on the second image) that connect the motherboard to the lens assembly by lifting up the black pieces of the bracket and pulling gently.
    • The ribbon cables are extremely difficult to reattach. Disconnect at your own risk.
    • There will be a slight bit of glue connecting the two potions that can be removed with a a little force.
    FixBotに聞いてみる
    コメントを追加
  5. Lytro First Generation Light Sensor Replacement: 手順 5、 1の画像 1
    • Remove the three black screws indicated in red
    • Repeat the same process done to the first two ribbon cables with this one, indicated in orange.
    FixBotに聞いてみる
    コメントを追加
  6. Lytro First Generation Light Sensor Replacement: 手順 6、 2の画像 1 Lytro First Generation Light Sensor Replacement: 手順 6、 2の画像 2
    • Remove the three springs (yellow) and unscrew the three screws (blue).
    • Replace the light sensor.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Mira Green
メンバー登録日: 05/31/16
57 ポイント
1ガイドが承認済み
チーム
Central Coast New Tech High, Team 6-1, Rushing Spring 2016 Central Coast New Tech High, Team 6-1, Rushing Spring 2016人のメンバー
CCNTH-RUSHING-S16S6G1
2 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 46
今までの合計 1,884
