メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech Signature Slim Solar+ Battery Replacement
必要な工具と部品
  1. Logitech Signature Slim Solar+ Battery Replacement, Prepare your keyboard for disassembly: 手順 1、 2の画像 1 Logitech Signature Slim Solar+ Battery Replacement, Prepare your keyboard for disassembly: 手順 1、 2の画像 2
    • Slide the keyboard's power switch into the OFF position.
    • A red indicator should be visible beneath the switch.
    • Lay your keyboard down with the feet facing up on a clean work surface.
    • If your work surface may scratch the keyboard, place a soft towel under it.
  2. Logitech Signature Slim Solar+ Battery Replacement, Remove the feet: 手順 2、 3の画像 1 Logitech Signature Slim Solar+ Battery Replacement, Remove the feet: 手順 2、 3の画像 2 Logitech Signature Slim Solar+ Battery Replacement, Remove the feet: 手順 2、 3の画像 3
    • Insert the point of a spudger under an end of the foot.
    • Push the spudger underneath the foot and lift until you can grip it with your fingers.
    • Peel the foot up and remove it. Keep it for reassembly.
  3. Logitech Signature Slim Solar+ Battery Replacement, Remove the remaining top feet: 手順 3、 3の画像 1 Logitech Signature Slim Solar+ Battery Replacement, Remove the remaining top feet: 手順 3、 3の画像 2 Logitech Signature Slim Solar+ Battery Replacement, Remove the remaining top feet: 手順 3、 3の画像 3
    • Repeat the procedure to remove two remaining feet along the top edge. Keep these for reassembly.
  4. Logitech Signature Slim Solar+ Battery Replacement, Remove the battery cover: 手順 4、 1の画像 1
    • Use a Phillips screwdriver to loosen the three captive screws securing the battery cover.
  5. Logitech Signature Slim Solar+ Battery Replacement: 手順 5、 3の画像 1 Logitech Signature Slim Solar+ Battery Replacement: 手順 5、 3の画像 2 Logitech Signature Slim Solar+ Battery Replacement: 手順 5、 3の画像 3
    • Lift and remove the battery cover.
  6. Logitech Signature Slim Solar+ Battery Replacement: 手順 6、 2の画像 1 Logitech Signature Slim Solar+ Battery Replacement: 手順 6、 2の画像 2
    • Use your fingers or a spudger to lift and remove the battery by its side tabs.
  7. Logitech Signature Slim Solar+ Battery Replacement, Install the replacement battery: 手順 7、 3の画像 1 Logitech Signature Slim Solar+ Battery Replacement, Install the replacement battery: 手順 7、 3の画像 2 Logitech Signature Slim Solar+ Battery Replacement, Install the replacement battery: 手順 7、 3の画像 3
    • Align the battery with its recess and push down firmly with your finger to click it in place.
  8. Logitech Signature Slim Solar+ Battery Replacement, Reassemble the keyboard: 手順 8、 2の画像 1 Logitech Signature Slim Solar+ Battery Replacement, Reassemble the keyboard: 手順 8、 2の画像 2
    • Lay the battery cover in place and gently press it onto the keyboard to engage the clips.
  9. Logitech Signature Slim Solar+ Battery Replacement: 手順 9、 1の画像 1
    • Use a Phillips screwdriver to tighten the three captive screws securing the battery cover.
  10. Logitech Signature Slim Solar+ Battery Replacement: 手順 10、 3の画像 1 Logitech Signature Slim Solar+ Battery Replacement: 手順 10、 3の画像 2 Logitech Signature Slim Solar+ Battery Replacement: 手順 10、 3の画像 3
    この手順で使用する道具:
    Tesa 61395 Tape
    $2.99
    • If you're installing new feet, remove them from their backing and firmly press them into place.
    • If you're reusing the feet, use a strip of double-sided tape to secure them in their recesses.
終わりに
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
作成者
4人の作成者と共同で作成されました。
Arthur Shi
メンバー登録日: 01/03/18
318,192 ポイント
736のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 18
過去 30 日: 150
今までの合計 468
