メインコンテンツにスキップ
Logitech MX Vertical Feet Replacement
必要な工具と部品
  1. Logitech MX Vertical Feet Replacement, Turn off the mouse: 手順 1、 1の画像 1
    • Before you begin, flip the mouse's power switch into the OFF position.
  2. Logitech MX Vertical Feet Replacement, Lay the mouse buttons-side down: 手順 2、 1の画像 1
    • The mouse's unique shape prevents it from laying flat. If you need to, lay it button-side down onto a soft towel to prevent wobble.
  3. Logitech MX Vertical Feet Replacement, Heat the feet adhesive: 手順 3、 2の画像 1 Logitech MX Vertical Feet Replacement, Heat the feet adhesive: 手順 3、 2の画像 2
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the feet on the mouse's underside for about two minutes.
    • Alternatively, a hair dryer or a heat gun may also be used, but be careful not to overheat the mouse.
  4. Logitech MX Vertical Feet Replacement, Remove the mouse feet: 手順 4、 3の画像 1 Logitech MX Vertical Feet Replacement, Remove the mouse feet: 手順 4、 3の画像 2 Logitech MX Vertical Feet Replacement, Remove the mouse feet: 手順 4、 3の画像 3
    この手順で使用する道具:
    • Insert one arm of a pair of sharp tweezers underneath the end of one foot.
    • Grip the foot and begin to peel it away from the bottom of the mouse.
    • Peel slowly, making sure the foot and its adhesive are removed in one piece.
    • The foot should come away from the mouse without the need for much force. If it feels stuck, apply more heat and try again.
  5. Logitech MX Vertical Feet Replacement: 手順 5、 3の画像 1 Logitech MX Vertical Feet Replacement: 手順 5、 3の画像 2 Logitech MX Vertical Feet Replacement: 手順 5、 3の画像 3
    • Use a pair of tweezers to peel the foot away from the mouse to completely remove it.
    • Place the foot adhesive-side up on a clean surface.
  6. Logitech MX Vertical Feet Replacement: 手順 6、 3の画像 1 Logitech MX Vertical Feet Replacement: 手順 6、 3の画像 2 Logitech MX Vertical Feet Replacement: 手順 6、 3の画像 3
    • Insert a tweezer arm underneath the end of the second foot.
    • Peel the foot away from the mouse to completely remove it.
    • The foot should come away from the mouse without much force. If it feels stuck, apply more heat and try again.
    • During reassembly, remove any leftover adhesive before installing new feet.
終わりに
5 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Carsten Frauenheim
メンバー登録日: 03/10/20
135,551 ポイント
371のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,418のガイドは作成済み
2 件のコメント
Do you have to heat it to re-apply the feet?
Jimmy - 返信
Beste,
Weet je toevallig, waar ik de nieuwe voetjes van Logitech MX Vertical kan kopen?
Groeten,
peter smith
peter - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 33
過去 30 日: 89
今までの合計 3,744
