メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech M720 Micro-switch Replacement
必要な工具と部品
  1. Logitech M720 Micro-switch Replacement, Dissembly: 手順 1、 3の画像 1 Logitech M720 Micro-switch Replacement, Dissembly: 手順 1、 3の画像 2 Logitech M720 Micro-switch Replacement, Dissembly: 手順 1、 3の画像 3
    • Begin disassembly by removing the battery
    • Peel off the sticker underneath the battery to reveal the small Philips screw underneath. As my particular mouse had already been disassembled, the sticker is not shown in the images
    • Using a flat blade screwdriver or similar instrument, peel off the rubber pad at the upper edge of the mouse to reveal two more screws
    • Unscrew a total of 5 Phillips head scews as marked
    FixBotに聞いてみる
    コメントを追加
  2. Logitech M720 Micro-switch Replacement, Separating top and bottom housings: 手順 2、 1の画像 1
    • Gently separate the top and bottom parts of the mouse, being careful not to pull the two parts too far apart, so as to avoid damaging the small ribbon cable that connects the switches on the top housing to the main board
    • Un-clip and remove the ribbon cable from the main board as shown. The two parts of the mouse are now separate
    FixBotに聞いてみる
    コメントを追加
    • The connector on the main board is much smaller and more fragile than the connector at the other end. It would be better to leave the small end alone and unclip the big end.
    FixBotに聞いてみる
    コメントを追加
  3. Logitech M720 Micro-switch Replacement, Removing scroll wheel assembly: 手順 4、 3の画像 1 Logitech M720 Micro-switch Replacement, Removing scroll wheel assembly: 手順 4、 3の画像 2 Logitech M720 Micro-switch Replacement, Removing scroll wheel assembly: 手順 4、 3の画像 3
    • Remove the clip holding the translucent scroll wheel assembly to the black plastic piece
    • Lift off the scroll wheel assembly, making sure not to loose the two small springs underneath, towards the front. The springs were already missing in my mouse, but I have marked the location in red
    • Remove the two screws holding down the black plastic piece, to which the scroll wheel assembly was attached
    FixBotに聞いてみる
    コメントを追加
  4. Logitech M720 Micro-switch Replacement, Main board removal: 手順 5、 3の画像 1 Logitech M720 Micro-switch Replacement, Main board removal: 手順 5、 3の画像 2 Logitech M720 Micro-switch Replacement, Main board removal: 手順 5、 3の画像 3
    • Lift off the main board and place it gently to the side, taking care not to damage the remaining ribbon cable attached to a small switch and bracket assembly on the bottom housing
    • Unscrew and lift off the metal bracket. The ribbon cable and small piece of PCB at it's end should now be free
    • Make sure not to lose the small plastic on-off slider switch cover, which should now be free to fall out if the bottom housing is turned over
    FixBotに聞いてみる
    コメントを追加
  5. Logitech M720 Micro-switch Replacement, Desoldering micro-switches: 手順 6、 3の画像 1 Logitech M720 Micro-switch Replacement, Desoldering micro-switches: 手順 6、 3の画像 2 Logitech M720 Micro-switch Replacement, Desoldering micro-switches: 手順 6、 3の画像 3
    この手順で使用する道具:
    Desoldering Pump
    $3.99
    • Identify and de-solder the micro-switch solder pads using your preferred de-soldering method, such as a solder pump or de-soldering wick. Your soldering iron tip should be clean and properly tinned, unlike my atrocious tip pictured here
    • If required, pry the old switches off with a flat-blade screwdriver while applying heat to the solder pads
    FixBotに聞いてみる
    コメントを追加
  6. Logitech M720 Micro-switch Replacement, Switch replacement: 手順 7、 3の画像 1 Logitech M720 Micro-switch Replacement, Switch replacement: 手順 7、 3の画像 2 Logitech M720 Micro-switch Replacement, Switch replacement: 手順 7、 3の画像 3
    • Install and solder the new switches
    • Again, be sure to use a correctly tinned and clean soldering iron tip. Your tip should not be as gnarly as mine is in these pictures
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
23 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Santaji
メンバー登録日: 03/25/11
1,383 ポイント
4のガイドは作成済み
11件のガイドコメント
Next time show ALL screws, type and position.
On this mouse screws are not all similar and if somebody forget that your “guide” don’t help
John Travolta - 返信 共有
Thanks for the guide! It helped so very much.
The_Rural_Juror - 返信 共有
thank you! i only needed to open and clean the dust inside and it clicks well again.
mine was double clicking when i click and hold.
was about to unsolder and swap the left and right switches but didn't have to go all the way there.
screws are fine i think. just be careful and put them on a safe place with the same relative positions to make it easier to put back, as with all other devices when disassembling.
UPDATE: mine is double clicking again 1 month later, and just found out recently from reddit that breathing humidity to the switches will often fix the double clicking problem with these Omron switches inside. it's magic! i tried and it really fixed it.
ted - 返信 共有
Just replaced mine m720's switches with Kailh GM 8.0 Mouse Switches, working like charm!
Dishendra - 返信 共有
Wow. I read your comment and bought some Kailh GM 8.0 switches. They are really awesome. It's such a great mouse to use now. Thanks for such a great recommendation.
Edward Furey - 返信 共有
コメントを追加
統計データ:
過去 24時間: 20
過去 7 日: 226
過去 30 日: 801
今までの合計 32,675
