メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech M331 Disassembly
必要な工具と部品
    1. Logitech M331 Disassembly, Remove the bottom screw: 手順 1、 1の画像 1
      • Flip the mouse over so the power switch is facing up.
      • Slide the battery door towards the back of the mouse to release its clips and remove it.
      • Remove the battery (if installed).
      • Remove the sticker from the battery well.
      • Use a Phillips screwdriver to remove the black screw in the battery well.
      FixBotに聞いてみる
      コメントを追加
    2. Logitech M331 Disassembly: 手順 2、 1の画像 1
      • Carefully detach the upper case and the lower case of the mouse by holding the lower case and sliding the upper case forward.
      FixBotに聞いてみる
      コメントを追加
    3. Logitech M331 Disassembly: 手順 3、 1の画像 1
      • Unscrew the screw in the purple circle and unfasten the plastic pins in blue circles to remove the board from the plastic cover.
      FixBotに聞いてみる
      コメントを追加
    4. Logitech M331 Disassembly: 手順 4、 2の画像 1 Logitech M331 Disassembly: 手順 4、 2の画像 2
      • To disassemble the upper case of the mouse, detach the plastic pins located in the blue circles. The two pins located in purple circles will be automatically unfastened once the four blue pins are detached.
      • To disassemble the light propagator, detach the small plastic pin at the bottom of the mouse case and light propagator connection.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
24 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
garfieldknight
メンバー登録日: 02/13/19
1,157 ポイント
2のガイドは作成済み
9件のガイドコメント
first time using ifixit
this was just what i needed thanks!
Prentiss Johnson - 返信 共有
Thanks for the guide! I was able to clean the scroll wheel properly and fixed the annoying inaccurate scroll issue.
Gabriel Louie Cubelo - 返信 共有
Exactly what I needed, a clear and direct guide. Thank you so much!
Zıbın Zıbınoğlu - 返信 共有
Finally my mouse-wheel has stopped ghost scrolling, I used to have this problem where when I scrolled down and up it would go the opposite direction, at first I thought it was a bug but turns out on my other wired logitech mouse, it worked normally.
Upon following this instruction manual (A++) I managed to put some WD40 in the mouse wheel scrolling part, from the inside (not the wheel but the thing it’s attached to) and scrolled it a couple of times, now it works normally :)
Thanks to the author!
TAY CHU TSE ANDREW - 返信 共有
Thanks, cleaning up my M331 and put nachi tape on right-mouse-button so it works again (after it deform slightly).
yayanm 1k - 返信 共有
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 52
過去 30 日: 208
今までの合計 18,658
