メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech M215 Button Plate Replacement
必要な工具と部品
    1. Logitech M215 Button Plate Replacement, Remove the battery cover: 手順 1、 3の画像 1 Logitech M215 Button Plate Replacement, Remove the battery cover: 手順 1、 3の画像 2 Logitech M215 Button Plate Replacement, Remove the battery cover: 手順 1、 3の画像 3
      • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
      • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
      • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
      FixBotに聞いてみる
      コメントを追加
    2. Logitech M215 Button Plate Replacement, Remove old battery: 手順 2、 1の画像 1
      • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
      FixBotに聞いてみる
      コメントを追加
    1. Logitech M215 Button Plate Replacement, Top Cover: 手順 3、 2の画像 1 Logitech M215 Button Plate Replacement, Top Cover: 手順 3、 2の画像 2
      • The pads on the underside of the mouse hide the screws. Remove these first. You may need to use your fingernails or a prying tool.
      • There will be two 0.5mm phillips head screws. Both will be underneath the bottom two pads.
      FixBotに聞いてみる
      コメントを追加
    2. Logitech M215 Button Plate Replacement: 手順 4、 1の画像 1
      • Pry the top cover off. You may need to use a pry tool to help.
      FixBotに聞いてみる
      コメントを追加
    1. Logitech M215 Button Plate Replacement, Button Plate: 手順 5、 2の画像 1 Logitech M215 Button Plate Replacement, Button Plate: 手順 5、 2の画像 2
      • Use your fingernail to carefully remove the two skid stickers from the fat (non-button) end of the bottom of the mouse to reveal two Philips head screws. Remove these, then unclip the bottom cover. Don't get the sticky dusty. Now remove buttons; they're both attached by one 0.5mm Phillips head screw. It is located in the center of the top cover.
      FixBotに聞いてみる
      コメントを追加
    2. Logitech M215 Button Plate Replacement, Pry off buttons: 手順 6、 2の画像 1 Logitech M215 Button Plate Replacement, Pry off buttons: 手順 6、 2の画像 2
      • The button are now only attached by a small overhang near the front. You will need to use the pry tool to push the button plate off of this overhang as shown.
      • The button plate should be able to be completely removed at this point.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Hannah Pate
メンバー登録日: 01/30/15
1,742 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015人のメンバー
USFT-WATKINS-W15S1G1
4 メンバー
28のガイドは作成済み
2件のガイドコメント
Step 5 loops back to step 3. If you follow steps 3 and 4 you will break the tabs at the front of the top cover.
In step 4 use the pry tool to loosen the back end of the mouse if necessary but it should just come apart, then slide the top cover out from under the tabs at the front of the base.
Most of step 5 is a recap of steps 3 and 4, the circled screw in the second picture allows you to remove the button plate from the top cover.
Step 6 is only necessary for replacing the button plate or cleaning between the button plate and top cover, the actual switches are on the circuit board
William - 返信 共有
All of this did not help make my left button work. I still hear the clicking sound when I press the button but nothing happens on the screen. I made sure the circuit boards were clean and clear of any debris, but not luck after re-assembling it; right button still works.
Nadder - 返信 共有
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 15
過去 30 日: 50
今までの合計 6,725
