メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech M215 Battery Replacement
必要な工具と部品
    1. Logitech M215 Battery Replacement, Remove the battery cover: 手順 1、 3の画像 1 Logitech M215 Battery Replacement, Remove the battery cover: 手順 1、 3の画像 2 Logitech M215 Battery Replacement, Remove the battery cover: 手順 1、 3の画像 3
      • The battery compartment cover is located on the top of the mouse. The seam running horizontally across the mouse is the top of the cover.
      • There is a button to pop off the cover. It is located on the bottom of the mouse. you may need to press hard on this button to pop the cover.
      • If the button does not work, you will need to pry off the cover. You can use your fingernails or a prying tool in order to do this, as seen in the third image.
      FixBotに聞いてみる
      コメントを追加
    2. Logitech M215 Battery Replacement, Remove old battery: 手順 2、 1の画像 1
      • Remember to insert the new battery in the same orientation as the old one. The positive (plus) end should be facing away from the buttons.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
28 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Hannah Pate
メンバー登録日: 01/30/15
1,742 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team 1-1, Watkins Winter 2015 USF Tampa, Team 1-1, Watkins Winter 2015人のメンバー
USFT-WATKINS-W15S1G1
4 メンバー
28のガイドは作成済み
10件のガイドコメント
I disassembled this exactly as stated and now I can't get the cover back on?
Rei Peterson - 返信 共有
I am a electronic technologist and this is a poor design for a mouse. No wonder the later version is different.
Joseph Wonderless - 返信 共有
Thanks for the information. It worked perfectly for me. Easy removal. Images and instructions were very helpful.
Tracy Moore - 返信 共有
The green battery light went on, although the lazar light did not. What should I do?
Susan Petho - 返信 共有
well this is a bit horrible, because i don’t have an extra AA battery.. and i have a M325, but the battery life is dead..
Diana Lee - 返信 共有
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 48
過去 30 日: 244
今までの合計 124,303
