メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech M185 Wireless Mouse Disassembly
必要な工具と部品
    1. Logitech M185 Wireless Mouse Disassembly, Remove the Battery Cover and Battery: 手順 1、 2の画像 1 Logitech M185 Wireless Mouse Disassembly, Remove the Battery Cover and Battery: 手順 1、 2の画像 2
      • Remove battery cover by sliding it off.
      FixBotに聞いてみる
      コメントを追加
    2. Logitech M185 Wireless Mouse Disassembly, Unscrew: 手順 2、 2の画像 1 Logitech M185 Wireless Mouse Disassembly, Unscrew: 手順 2、 2の画像 2
      • Unscrew the Phillips #1 screw in the battery compartment after removing the battery.
      • Some mice have a smaller screw, directly down and to the side of the on/off slider. The rest of the disassembly is the same.
      FixBotに聞いてみる
      コメントを追加
    3. Logitech M185 Wireless Mouse Disassembly, Remove the top cover: 手順 3、 1の画像 1
      • There is no need to remove its rubber feet since it is held together by only one screw.
      • Wiggle the grey part of the top to remove it by pulling it towards you(away from the scroll wheel).
      • Do not pull the grey cover towards the top and do not pull the part near the keys.
      • Reasoning by Jacob Hickey "because in the internal top part of the mouse where the buttons/scroll wheel is, there’s hinges-like “tooth” that’ll snap if you do pull on it. It’s like opening a jewelry box that has a hinge on one end of the box… if that makes sense…"
      • The image is what your mouse should look like in the end.
      FixBotに聞いてみる
      コメントを追加
    4. Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: 手順 4、 3の画像 1 Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: 手順 4、 3の画像 2 Logitech M185 Wireless Mouse Disassembly, Remove Circuit Board: 手順 4、 3の画像 3
      • Push back small black clips to release the circuit board.
      • Slide up the metal battery connectors to free them from the casing. (Note that these are soldered to the circuit board.)
      • Fully remove the circuit board with the battery connectors and image sensor still attached.
      FixBotに聞いてみる
      コメントを追加
    5. Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: 手順 5、 3の画像 1 Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: 手順 5、 3の画像 2 Logitech M185 Wireless Mouse Disassembly, Separate top casing layers: 手順 5、 3の画像 3
      • Working from back to front (left to right in the first image) unclip the first two pairs of black plastic clips.
      • Slide the black upper casing forwards over the mouse wheel whilst applying pressure the two front clips to release them.
      • Separate the two casing layers fully.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
43 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Karmanyaah Malhotra
メンバー登録日: 09/23/18
1,185 ポイント
1ガイドが承認済み
12件のガイドコメント
Thank you Karmanyaah Malhotra for takin’ the time to do this for everybody like me :-)
Jacob Hickey - 返信 共有
were can i buy these iems telll mee please
Brayden Karanian - 返信 共有
TElll me now or else
I will be sad
コメントを追加
統計データ:
過去 24時間: 16
過去 7 日: 108
過去 30 日: 475
今までの合計 43,759
