メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech M100 USB Cable Replacement
必要な工具と部品
  1. Logitech M100 USB Cable Replacement, USB Cable: 手順 1、 2の画像 1 Logitech M100 USB Cable Replacement, USB Cable: 手順 1、 2の画像 2
    • Not all variants of this mouse require the mouse feet to be taken off for disassembly, but their removal is detailed anyway.
    • Carefully remove the feet of the mouse with an opening pick.
    • Keep track of the mouse feet, as you'll be reapplying them at the end of the guide.
    FixBotに聞いてみる
    コメントを追加
  2. Logitech M100 USB Cable Replacement: 手順 2、 2の画像 1 Logitech M100 USB Cable Replacement: 手順 2、 2の画像 2
    • Use a Phillips #0 screwdriver to remove the 10mm screws on the bottom of the mouse.
    • Once all screws are removed, use the plastic opening tool to gently pry the mouse apart. This shouldn't take much force.
    FixBotに聞いてみる
    コメントを追加
  3. Logitech M100 USB Cable Replacement: 手順 3、 2の画像 1 Logitech M100 USB Cable Replacement: 手順 3、 2の画像 2
    • Once the mouse is opened, locate the USB cable's 5-pin connector, which is plugged directly into the mouse's mainboard.
    • Take note of the position and route that the USB cable takes before removal. The replacement cable must follow the same route when inserted.
    • Using a plastic opening tool, gently remove the 5-pin connector from the mainboard.
    FixBotに聞いてみる
    コメントを追加
  4. Logitech M100 USB Cable Replacement: 手順 4、 2の画像 1 Logitech M100 USB Cable Replacement: 手順 4、 2の画像 2
    • Take the replacement USB cable and connect it to the mainboard.
    FixBotに聞いてみる
    コメントを追加
  5. Logitech M100 USB Cable Replacement: 手順 5、 2の画像 1 Logitech M100 USB Cable Replacement: 手順 5、 2の画像 2
    • Ensure that the 5-pin connector is fully seated into its slot on the mainboard. You may want to use a spudger to apply pressure onto it.
    • Using a plastic opening tool, route the cable through the case in the same way that was noted in Step 3.
    FixBotに聞いてみる
    コメントを追加
  6. Logitech M100 USB Cable Replacement: 手順 6、 1の画像 1
    • After re-assembling the mouse, don't forget to reattach the mouse feet onto their correct locations on the bottom of the mouse.
    FixBotに聞いてみる
    コメントを追加
終わりに
To reassemble, follow the steps in reverse order.
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Jake Janicke
メンバー登録日: 10/26/17
161 ポイント
1ガイドが承認済み
チーム
DePaul University, Team S1-G5, Dush Fall 2017 DePaul University, Team S1-G5, Dush Fall 2017人のメンバー
DPU-DUSH-F17S1G5
2 メンバー
1のガイドは作成済み
1件のガイドコメント
Removing the mouse feet is completely unnecessary, as there are no screws underneath the feet.
Andy Joonseo Bae - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 35
今までの合計 6,539
