メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech Gamepad F310 Trigger Spring Replacement
必要な工具と部品
  1. Logitech Gamepad F310 Trigger Spring Replacement, Case: 手順 1、 2の画像 1 Logitech Gamepad F310 Trigger Spring Replacement, Case: 手順 1、 2の画像 2
    • Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
    FixBotに聞いてみる
    コメントを追加
  2. Logitech Gamepad F310 Trigger Spring Replacement: 手順 2、 2の画像 1 Logitech Gamepad F310 Trigger Spring Replacement: 手順 2、 2の画像 2
    • Press along the seams of the controller and gently pull the front and rear case apart.
    • If necessary, use an opening tool to help pry the front and rear case apart.
    • Make sure to open the controller with the front facing down so that the buttons do not fall out.
    FixBotに聞いてみる
    コメントを追加
  3. Logitech Gamepad F310 Trigger Spring Replacement: 手順 3、 1の画像 1
    • Separate the front and rear case.
    • There are two side panels on the controller that come apart as well. When putting them back together, they slot into place on the sides of the controller.
    FixBotに聞いてみる
    コメントを追加
  4. Logitech Gamepad F310 Trigger Spring Replacement, Trigger Spring: 手順 4、 2の画像 1 Logitech Gamepad F310 Trigger Spring Replacement, Trigger Spring: 手順 4、 2の画像 2
    • Use a Phillips #1 screwdriver to remove:
    • Four 3 mm screws
    • One 5 mm screw
    • Remove the central silver screw last.
    • Gently lift the motherboard off of the back case and slide the cord out of the top slot.
    FixBotに聞いてみる
    コメントを追加
  5. Logitech Gamepad F310 Trigger Spring Replacement: 手順 5、 1の画像 1
    • Make note of the slot on the controller and the slot on the trigger that the spring is connected to.
    • Press the trigger down until the spring pops loose.
    • You may need to fish the spring out of the pocket it is in. The spring will be accompanied by a small black piece that fits inside the spring.
    FixBotに聞いてみる
    コメントを追加
  6. Logitech Gamepad F310 Trigger Spring Replacement: 手順 6、 1の画像 1
    • In order to properly place the spring into the controller, make sure that the black piece is inside, and make sure each end of the spring goes into the correct slots.
    FixBotに聞いてみる
    コメントを追加
終わりに
You're all finished! To reassemble your device, follow these instructions carefully in reverse order.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Alan Mendoza DracoKing
メンバー登録日: 02/05/24
194 ポイント
2のガイドは作成済み
チーム
University of North Texas, Team 2-6, Kilpatrick Spring 2024 University of North Texas, Team 2-6, Kilpatrick Spring 2024人のメンバー
UNT-KILPATRICK-S24S2G6
4 メンバー
6のガイドは作成済み
1件のガイドコメント
I completed this guide in conjunction with this video:
How to disassemble and reassemble the Logitech Gamepad F310
Khalon - 返信 共有
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 21
過去 30 日: 111
今までの合計 1,624
