メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech G910 Keyboard Key Cap Replacement
必要な工具と部品
  1. Logitech G910 Keyboard Key Cap Replacement, Key: 手順 1、 1の画像 1
    • Unplug the keyboards USB cord from the computer. This is to ensure it is powered off.
    • Make sure the keyboard is facing up towards you and on a level and sturdy surface.
    FixBotに聞いてみる
    コメントを追加
  2. Logitech G910 Keyboard Key Cap Replacement: 手順 2、 1の画像 1
    • Gently use your fingers to remove the key caps from the keyboard by firmly grasping the key and pulling directly up.
    • Make sure the pins line up and it is facing the correct direction. Once you have done this, firmly push it in until you hear it click into place and works like normal again.
    • If the key cap doesn't push in all the way or won't pop back up from being pressed down then it is either in the wrong spot or oriented the wrong way. Pull it off, make sure no debris is blocking the pin hole and try putting it the correct way again.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
10 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Shadi Alzanbagi
メンバー登録日: 01/16/18
460 ポイント
1ガイドが承認済み
チーム
13件のガイドコメント
I am sorry, but why did you wrote a tutorial and describe how to open up G910 (and lose the warranty along the way) just to take of the keyCAP?
Keycap can be removed in a matter of seconds with use of $0.99 keycap removal tool
https://www.ebay.com/itm/Keyboard-Key-Ke...
heggathestrasni - 返信 共有
It’s not just the Key Cap, you can remove the mechanical switch too. I have a busted G910 and I’ve been wanting to replace the switches for a while now.
Wildcard001 - 返信 共有
dude same, I have a few broken switches on mine that I'm keeping held together with some wadded up paper. the 9 key is completely gone sadly.
Shady Hero - 返信 共有
Rofl, you don’t need to do steps 1-4, literally jusst do 5 if you are replacing the keycap lmao
rob.chan - 返信 共有
I think step 3 and 4 are in the wrong order, you can’t get to the screws until you get that face-plate off
Brett Yoakum - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 96
過去 30 日: 277
今までの合計 70,770
