メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech G733 Power Button Replacement
必要な工具と部品
    1. Logitech G733 Power Button Replacement, Power Button: 手順 1、 1の画像 1
      • Before you begin, discharge the headset battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Gently start to pull the left ear pad off, starting from the top.
      • Slide your finger around the edges until it releases completely.
      • Remove the ear pad.
      FixBotに聞いてみる
      コメントを追加
    2. Logitech G733 Power Button Replacement: 手順 2、 2の画像 1 Logitech G733 Power Button Replacement: 手順 2、 2の画像 2
      • Remove the four screws securing the speaker housing using a T4 Torx screwdriver.
      • Place these screws on the magnetic project mat so you don't lose them.
      FixBotに聞いてみる
      コメントを追加
    3. Logitech G733 Power Button Replacement: 手順 3、 3の画像 1 Logitech G733 Power Button Replacement: 手順 3、 3の画像 2 Logitech G733 Power Button Replacement: 手順 3、 3の画像 3
      • Gently lift off the speaker housing, with care not to strain the connected cable.
      • Remove the screw on the bottom right-hand side of the motherboard using a Phillips #000 screwdriver.
      • Use your thumb to gently pull back the tab at the upper right-hand corner of the headphone and simultaneously pull the circuit board out.
      • The scroll wheel may fly out when you pop the circuit board out.
      FixBotに聞いてみる
      コメントを追加
    4. Logitech G733 Power Button Replacement: 手順 4、 2の画像 1 Logitech G733 Power Button Replacement: 手順 4、 2の画像 2
      • Once the motherboard is loose, gently pull the wire out of its harness.
      • The wiring harness is glued, so be careful with it. It should pull out easily.
      FixBotに聞いてみる
      コメントを追加
    5. Logitech G733 Power Button Replacement: 手順 5、 1の画像 1
      この手順で使用する道具:
      Halberd Spudger
      $2.99
      • Pop the power button out of its recess by pushing it through the side of the headphone with your finger.
      • Now use the hook end of the halberd spudger to pry the connecting piece of the power button off at the end furthest to the inside of the headphone.
      • This step is the most difficult, so be careful when prying.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Antonio Jensen
メンバー登録日: 02/14/23
727 ポイント
5のガイドは作成済み
チーム
Western Carolina University, Team 1-5, Virtue Spring 2023 Western Carolina University, Team 1-5, Virtue Spring 2023人のメンバー
WCU-VIRTUE-S23S1G5
4 メンバー
29のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 22
過去 30 日: 60
今までの合計 2,641
