メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Logitech G27 C-Clamp Replacement
必要な工具と部品
  1. Logitech G27 C-Clamp  Replacement, Steering Wheel: 手順 1、 1の画像 1
    • Remove the six gray 25mm hex screws with a 4mm allen wrench.
    • Watch out when you lift the wheel up, as there are fragile wires connected to the bottom side.
    • Carefully lift up the wheel, but do not disconnect it from the rest of the device.
    FixBotに聞いてみる
    コメントを追加
  2. Logitech G27 C-Clamp  Replacement: 手順 2、 1の画像 1
    • Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
    FixBotに聞いてみる
    コメントを追加
  3. Logitech G27 C-Clamp  Replacement: 手順 3、 1の画像 1
    • Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  4. Logitech G27 C-Clamp  Replacement: 手順 4、 1の画像 1
    • Carefully remove the PCB board from the wheel hub.
    FixBotに聞いてみる
    コメントを追加
  5. Logitech G27 C-Clamp  Replacement: 手順 5、 1の画像 1
    • Carefully pinch and unplug the large 7-pin connector under the PCB board.
    • Be careful when unplugging this adapter, try not to pull on the wires to avoid damaging them. Instead, wiggle around the plastic connector while pulling on it to loosen it.
    FixBotに聞いてみる
    コメントを追加
  6. Logitech G27 C-Clamp  Replacement: 手順 6、 1の画像 1
    • You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
    • Remove the innermost three 37.5mm silver screws with a Phillips #2 screwdriver.
    • Remove the wheel hub and push the connector through the center of the hub.
    FixBotに聞いてみる
    コメントを追加
  7. Logitech G27 C-Clamp  Replacement: 手順 7、 1の画像 1
    • The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
    • Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  8. Logitech G27 C-Clamp  Replacement: 手順 8、 1の画像 1
    • Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
    • The housing cover can be set aside until you put the wheel back together.
    FixBotに聞いてみる
    コメントを追加
  9. Logitech G27 C-Clamp  Replacement: 手順 9、 1の画像 1
    • Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #2 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  10. Logitech G27 C-Clamp  Replacement: 手順 10、 1の画像 1
    • Unplug the three plastic connectors on the left side of the PCB board.
    • Unplug the two plastic connectors on the top of the PCB board.
    • Unplug the three plastic connectors on the right side of the PCB board.
    • Pulling the plastic connectors requires a lot of force, but be careful and don't pull directly on the wires. Try to wedge or push the male side of the connector out.
    • If you need some extra leverage when removing these connectors, try using a plastic opening tool to pry off the connectors.
    • Removing these connectors allows easier access to the four screws attaching the PCB board mount to the motor housing.
    FixBotに聞いてみる
    コメントを追加
  11. Logitech G27 C-Clamp  Replacement: 手順 11、 1の画像 1
    • Remove the PCB board after all of the plastic connectors are disconnected.
    • You can now set it aside.
    FixBotに聞いてみる
    コメントを追加
  12. Logitech G27 C-Clamp  Replacement: 手順 12、 1の画像 1
    • Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
    • Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  13. Logitech G27 C-Clamp  Replacement: 手順 13、 2の画像 1 Logitech G27 C-Clamp  Replacement: 手順 13、 2の画像 2
    • Remove the PCB board mount and remove the clear plastic piece underneath.
    • Set them aside until you reassemble the wheel.
    FixBotに聞いてみる
    コメントを追加
  14. Logitech G27 C-Clamp  Replacement, C-Clamp: 手順 14、 1の画像 1
    • Unscrew the piece holding the C-Clamp in place with your hand.
    FixBotに聞いてみる
    コメントを追加
  15. Logitech G27 C-Clamp  Replacement: 手順 15、 2の画像 1 Logitech G27 C-Clamp  Replacement: 手順 15、 2の画像 2
    • Push the remaining nob forward and then inward through the slot.
    FixBotに聞いてみる
    コメントを追加
  16. Logitech G27 C-Clamp  Replacement: 手順 16、 2の画像 1 Logitech G27 C-Clamp  Replacement: 手順 16、 2の画像 2
    • The C-Clamp can now be easily pulled out of the bottom of the device.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
24 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Daniel Louis
メンバー登録日: 04/28/15
758 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 15-4, Amido Spring 2015 Cal Poly, Team 15-4, Amido Spring 2015人のメンバー
CPSU-AMIDO-S15S15G4
4 メンバー
25のガイドは作成済み
15件のガイドコメント
Where would I buy the replacement C-Clamps from because one of mine are broken and I need to install a new one.
Mumin Mazhar - 返信 共有
Look for it at eBay.
Eduardo - 返信 共有
I also need to find a place to buy replacement C-clamps from
hockeyjockone - 返信 共有
Can you tell me where I can buy these clamps?
kholiwen - 返信 共有
step 9 to 13 not needed ... please confirm
Matt Na - 返信 共有
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 34
過去 30 日: 131
今までの合計 50,396
