必要な工具と部品
Press the touch pad and support plate together to undo slightly peeling them apart. Attach the battery to the plate, Install plate/ battery in mouse. Plug in battery and touch panel cables, rotate touch panel and support plate back into place. Place the front tab in its slot and press the back down to attach the clips to the bar.
Unless the chosen battery is different, reassembly is in reverse order.
