メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LexiBook Tablet One Camera Replacement
必要な工具と部品
  1. LexiBook Tablet One Camera Replacement, Camera: 手順 1、 3の画像 1 LexiBook Tablet One Camera Replacement, Camera: 手順 1、 3の画像 2 LexiBook Tablet One Camera Replacement, Camera: 手順 1、 3の画像 3
    • Find the seam in the casing. Insert the blue plastic opening tool, and slide to either side carefully undoing the clips. The clips are hidden within the casing and are spaced roughly 1.5 in. apart.
    • When opening the device, be wary of the speaker wire. It is best to open the device from the right side with the camera oriented to the top.
    FixBotに聞いてみる
    コメントを追加
  2. LexiBook Tablet One Camera Replacement: 手順 2、 2の画像 1 LexiBook Tablet One Camera Replacement: 手順 2、 2の画像 2
    • Insert a spudger between the speaker and the casing. Gently pop the speaker out, and set the panel to the side.
    FixBotに聞いてみる
    コメントを追加
  3. LexiBook Tablet One Camera Replacement: 手順 3、 1の画像 1
    • Using a plastic spudger, wedge the tool between the battery and LCD. Repeatedly gouge and work around the edges of the battery until the adhesive breaks free. You will have to apply generous pressure, as long as you push horizontally the components should not be further damaged.
    • Be careful not to damage any wires or to puncture the battery casing when peeling the adhesive.
    • A similar flat tool can be used in place of a plastic spudger.
    FixBotに聞いてみる
    コメントを追加
  4. LexiBook Tablet One Camera Replacement: 手順 4、 3の画像 1 LexiBook Tablet One Camera Replacement: 手順 4、 3の画像 2 LexiBook Tablet One Camera Replacement: 手順 4、 3の画像 3
    • Remove the ribbon cable leading to the camera by carefully using a flat headed tool to open the ribbon clip.
    • Gently slide the ribbon cable out while holding the clip open.
    FixBotに聞いてみる
    コメントを追加
  5. LexiBook Tablet One Camera Replacement: 手順 5、 1の画像 1
    • When inserting your new camera, maintain the clip's open position and slide the new ribbon cable in.
    • It is imperative the clip not close partially when installing the new ribbon, or the new cable can be damaged.
    • When the ribbon can go no further into the clip, close the clip.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jordan
メンバー登録日: 03/11/15
650 ポイント
4のガイドは作成済み
チーム
Colorado Springs, Team 2-5, Panko Spring 2015 Colorado Springs, Team 2-5, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S2G5
3 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 25
今までの合計 457
