メインコンテンツにスキップ
Lenovo ThinkPad T470 Display Panel Replacement
必要な工具と部品
  1. Lenovo ThinkPad T470 Display Panel Replacement, External Battery: 手順 1、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement, External Battery: 手順 1、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement, External Battery: 手順 1、 3の画像 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 Display Panel Replacement: 手順 2、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 2、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 2、 3の画像 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 Display Panel Replacement, Internal Components: 手順 3、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement, Internal Components: 手順 3、 2の画像 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 Display Panel Replacement: 手順 4、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 4、 2の画像 2
    • Place the laptop so that the top is facing upwards.
    • Open the lid of the laptop.
  5. Lenovo ThinkPad T470 Display Panel Replacement: 手順 5、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 5、 2の画像 2
    • Place your fingers on the bottom edge of the keyboard.
    • Use a small amount of pressure to push the keyboard towards the screen.
  6. Lenovo ThinkPad T470 Display Panel Replacement: 手順 6、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 6、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 6、 3の画像 3
    • Grab the bottom edge of the keyboard with your hands, and flip the keyboard upside-down, so it rests on the bottom of the laptop.
    • Potential for device damage: The keyboard is still attached to the rest of the laptop, so be gentle when flipping it over.
  7. Lenovo ThinkPad T470 Display Panel Replacement: 手順 7、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 7、 2の画像 2
    • Use the flat end of a spudger to flip up the locking flaps securing each of the two ribbon cables.
  8. Lenovo ThinkPad T470 Display Panel Replacement: 手順 8、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 8、 2の画像 2
    • Use your hands to lift the keyboard up and away from the laptop.
  9. Lenovo ThinkPad T470 Display Panel Replacement: 手順 9、 1の画像 1
    • Close the laptop's lid and flip the laptop over so that the bottom is facing upwards.
  10. Lenovo ThinkPad T470 Display Panel Replacement: 手順 10、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 10、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 10、 3の画像 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  11. Lenovo ThinkPad T470 Display Panel Replacement: 手順 11、 1の画像 1
    • Remove the bottom cover from the laptop.
  12. Lenovo ThinkPad T470 Display Panel Replacement: 手順 12、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 12、 2の画像 2
    • Use a Phillips #1 screwdriver to remove two 5 mm screws from the internal battery.
  13. Lenovo ThinkPad T470 Display Panel Replacement: 手順 13、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 13、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 13、 3の画像 3
    • Use your hands to lift the battery up and away from the laptop.
  14. Lenovo ThinkPad T470 Display Panel Replacement: 手順 14、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 14、 2の画像 2
    • Use your fingers to flip the black flap covering the top stick of RAM down.
  15. Lenovo ThinkPad T470 Display Panel Replacement: 手順 15、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 15、 2の画像 2
    • Use your thumbs to push the metal clips on either end of the RAM outwards.
    • The RAM will pop up by a few millimeters.
  16. Lenovo ThinkPad T470 Display Panel Replacement: 手順 16、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 16、 2の画像 2
    • Use your fingers to lift the RAM out of its socket and away from the laptop to remove it.
  17. Lenovo ThinkPad T470 Display Panel Replacement: 手順 17、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 17、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 17、 3の画像 3
    • Use your fingers to flip the black flap covering the bottom stick of RAM up.
  18. Lenovo ThinkPad T470 Display Panel Replacement: 手順 18、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 18、 2の画像 2
  19. Lenovo ThinkPad T470 Display Panel Replacement: 手順 19、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 19、 2の画像 2
    • Use the flat end of a spudger to flip up the metal clip securing the SSD connector to the motherboard.
  20. Lenovo ThinkPad T470 Display Panel Replacement: 手順 20、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 20、 2の画像 2
    • Use the flat end of a spudger to separate the connector from its socket.
  21. Lenovo ThinkPad T470 Display Panel Replacement: 手順 21、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 21、 2の画像 2
    • Grab the tab on the left side of the hard drive, and pull up to remove it from the laptop.
  22. Lenovo ThinkPad T470 Display Panel Replacement: 手順 22、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 22、 2の画像 2
    • Use a finger to press the black flap covering the Wi-Fi card down.
  23. Lenovo ThinkPad T470 Display Panel Replacement: 手順 23、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 23、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 23、 3の画像 3
    • Use the flat end of a spudger to disconnect the two coaxial wires from the Wi-Fi card.
    • When reassembling, reattach the gray wire on the left and the black wire on the right.
  24. Lenovo ThinkPad T470 Display Panel Replacement: 手順 24、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 24、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the single 4 mm screw from the Wi-Fi card.
  25. Lenovo ThinkPad T470 Display Panel Replacement: 手順 25、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 25、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 25、 3の画像 3
    • Use your fingers to lift the Wi-Fi card up and out of its slot.
    • This laptop does not include a WWAN card, but if yours does, follow the same procedure as Steps 9-12 to remove it.
  26. Lenovo ThinkPad T470 Display Panel Replacement: 手順 26、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 26、 2の画像 2
    この手順で使用する道具:
    • Use a pair of blunt nose tweezers to pull the white connector out of its socket.
  27. Lenovo ThinkPad T470 Display Panel Replacement: 手順 27、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 27、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 27、 3の画像 3
    • Grab the wire attached to the coin cell battery, and lift it up and out of the laptop.
  28. Lenovo ThinkPad T470 Display Panel Replacement: 手順 28、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 28、 2の画像 2
    • Use a pair of blunt nose tweezers to pull the white fan connector out of its socket on the motherboard.
  29. Lenovo ThinkPad T470 Display Panel Replacement: 手順 29、 1の画像 1
    • Use a Phillips #1 screwdriver to loosen the first pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
    • Use a Phillips #1 screwdriver to loosen the second pair of captive screws on the fan and heat sink assembly in a crosswise pattern.
  30. Lenovo ThinkPad T470 Display Panel Replacement: 手順 30、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 30、 2の画像 2
    • Use your hand to pull the fan and heat sink assembly up and away from the laptop.
    • Clean the thermal paste from the heatsink and CPU and reapply fresh paste before reassembling.
  31. Lenovo ThinkPad T470 Display Panel Replacement, Motherboard: 手順 31、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement, Motherboard: 手順 31、 2の画像 2
    • Use the flat end of a spudger to flip up the metal clip securing the LCD cable to the motherboard.
  32. Lenovo ThinkPad T470 Display Panel Replacement: 手順 32、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 32、 2の画像 2
    • Use the flat end of a spudger to disconnect the LCD cable from its socket on the motherboard.
  33. Lenovo ThinkPad T470 Display Panel Replacement: 手順 33、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 33、 2の画像 2
    • Use the flat end of a spudger to flip the power button cable's black tab up.
  34. Lenovo ThinkPad T470 Display Panel Replacement: 手順 34、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 34、 2の画像 2
    • Use the flat end of a spudger to slide the power button cable out of its connector on the motherboard.
  35. Lenovo ThinkPad T470 Display Panel Replacement: 手順 35、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 35、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 35、 3の画像 3
    • Use your fingers to detach the red and blue antenna cables from their slots.
  36. Lenovo ThinkPad T470 Display Panel Replacement: 手順 36、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 36、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the two 4 mm screws from the USB bracket.
  37. Lenovo ThinkPad T470 Display Panel Replacement: 手順 37、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 37、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 37、 3の画像 3
    • Use your fingers to lift the USB bracket up and away from the laptop.
  38. Lenovo ThinkPad T470 Display Panel Replacement: 手順 38、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 38、 2の画像 2
    この手順で使用する道具:
    • Use a pair of blunt nose tweezers to disconnect the DC-in cable from its socket on the motherboard.
  39. Lenovo ThinkPad T470 Display Panel Replacement: 手順 39、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 39、 2の画像 2
    • Use the flat end of a spudger to flip up the metal bracket securing the camera cable to the motherboard.
  40. Lenovo ThinkPad T470 Display Panel Replacement: 手順 40、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 40、 2の画像 2
    • Use the flat end of a spudger to disconnect the camera cable from its socket on the motherboard.
  41. Lenovo ThinkPad T470 Display Panel Replacement: 手順 41、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 41、 2の画像 2
    • Use a pair of blunt nose tweezers to disconnect the speaker cable from its socket on the motherboard.
  42. Lenovo ThinkPad T470 Display Panel Replacement: 手順 42、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 42、 2の画像 2
    • Use the flat end of a spudger to flip up the black tabs on the trackpad and fingerprint reader cables.
  43. Lenovo ThinkPad T470 Display Panel Replacement: 手順 43、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 43、 2の画像 2
    • Use a pair of blunt nose tweezers to slide the trackpad and fingerprint reader cables out of their connectors on the motherboard.
  44. Lenovo ThinkPad T470 Display Panel Replacement: 手順 44、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 44、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the three 4 mm screws from the I/O bracket.
  45. Lenovo ThinkPad T470 Display Panel Replacement: 手順 45、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 45、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 45、 3の画像 3
    • Use your fingers to slide the I/O bracket to the left.
    • Lift the I/O bracket up and away from the laptop.
  46. Lenovo ThinkPad T470 Display Panel Replacement: 手順 46、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 46、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the six 4 mm screws from the motherboard.
    • This laptop does not have an NFC cable, but if yours does, use the flat end of a spudger to flip up the tab and slide the cable out of its connector.
  47. Lenovo ThinkPad T470 Display Panel Replacement: 手順 47、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 47、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 47、 3の画像 3
    • Use both hands to lift the motherboard up and away from the laptop.
  48. Lenovo ThinkPad T470 Display Panel Replacement, Display Assembly: 手順 48、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement, Display Assembly: 手順 48、 2の画像 2
    • Use your fingers to remove the camera cable from its slot.
  49. Lenovo ThinkPad T470 Display Panel Replacement: 手順 49、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 49、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 49、 3の画像 3
    • Use your fingers to lift the black and blue wires out of their slots along the top of the laptop.
  50. Lenovo ThinkPad T470 Display Panel Replacement: 手順 50、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 50、 2の画像 2
    • Use your fingers to lift the red and gray wires out of their slots.
  51. Lenovo ThinkPad T470 Display Panel Replacement: 手順 51、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 51、 2の画像 2
    • Use your fingers to lift the LCD cable out of its slot.
  52. Lenovo ThinkPad T470 Display Panel Replacement: 手順 52、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 52、 2の画像 2
    • Use a Phillips #1 screwdriver to remove three 4.5 mm screws from the hinge in the upper right corner.
  53. Lenovo ThinkPad T470 Display Panel Replacement: 手順 53、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 53、 2の画像 2
    • Use a Phillips #1 screwdriver to remove two 4.5 mm screws from the hinge in the upper left corner.
  54. Lenovo ThinkPad T470 Display Panel Replacement: 手順 54、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 54、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 54、 3の画像 3
    • Use both hands to lift the laptop body up and away from the display assembly.
  55. Lenovo ThinkPad T470 Display Panel Replacement, Display Bezel: 手順 55、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement, Display Bezel: 手順 55、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement, Display Bezel: 手順 55、 3の画像 3
    • Use the iFixit opening tool to create a gap between the bezel and the display, starting in the upper left corner.
    • Continue to use the iFixit opening tool around the left side, bottom, and right side of the laptop to detach the clips securing the bezel to the display.
    • You may hear loud snaps when detaching the clips; this is normal.
  56. Lenovo ThinkPad T470 Display Panel Replacement: 手順 56、 1の画像 1
    • Insert the iFixit opening tool between the bezel and display on the top side.
    • This part of the bezel is attached to the display with adhesive, so you may need to use your hands to gently peel the bezel away.
  57. Lenovo ThinkPad T470 Display Panel Replacement: 手順 57、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 57、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 57、 3の画像 3
    • Use both hands to lift the bezel up and away from the display assembly.
  58. Lenovo ThinkPad T470 Display Panel Replacement, Display Panel: 手順 58、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement, Display Panel: 手順 58、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the four 3 mm screws from each corner of the screen.
  59. Lenovo ThinkPad T470 Display Panel Replacement: 手順 59、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 59、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 59、 3の画像 3
    • Use both hands to lift the bottom corners of the display panel
    • Gently flip the display panel over.
    • Potential for device damage: The display cable is still connecting the display panel to the rest of the display assembly, so be sure to flip the display panel over with caution.
  60. Lenovo ThinkPad T470 Display Panel Replacement: 手順 60、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 60、 2の画像 2
    この手順で使用する道具:
    • Use a pair of blunt nose tweezers to remove the clear tape from the display cable.
  61. Lenovo ThinkPad T470 Display Panel Replacement: 手順 61、 2の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 61、 2の画像 2
    • Use the flat end of a spudger to flip up the metal bar securing the connector.
    • Use the flat end of a spudger to disconnect the display cable from its socket.
  62. Lenovo ThinkPad T470 Display Panel Replacement: 手順 62、 3の画像 1 Lenovo ThinkPad T470 Display Panel Replacement: 手順 62、 3の画像 2 Lenovo ThinkPad T470 Display Panel Replacement: 手順 62、 3の画像 3
    • Use your hands to remove the display panel from the rest of the display assembly.
終わりに
作成者
1人の作成者と共同作成されました。
Kristen Gismondi
メンバー登録日: 11/12/14
92,618 ポイント
241のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,643のガイドは作成済み
2件のガイドコメント
DO NOT WASTE YOUR TIME WITH THIS GUIDE. I am a certified repair technician and there is absolutely zero reason to disassemble the system and remove the motherboard for a panel swap. You can simply disconnect the antenna cables and EDP connectors; open the laptop and hang the LCD assembly over the edge of a table; then remove the hinge screws and lift it off. Nearly all ThinkPad models are like this. Please read the Hardware Maintenance Manual on the Lenovo support site for the correct way to do this. Page 93: https://download.lenovo.com/pccbbs/mobil...
[deleted] - 返信
Right, I was wondering why the nonsense that require me to remove all the mother board and things
Hưng Hoàng - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 14
過去 30 日: 68
今までの合計 5,160
