メインコンテンツにスキップ
Lenovo ThinkPad T460s Battery Replacement
必要な工具と部品
  1. Lenovo ThinkPad T460s Battery Replacement, Battery: 手順 1、 1の画像 1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Battery Replacement: 手順 2、 1の画像 1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Battery Replacement: 手順 3、 1の画像 1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s Battery Replacement: 手順 4、 3の画像 1 Lenovo ThinkPad T460s Battery Replacement: 手順 4、 3の画像 2 Lenovo ThinkPad T460s Battery Replacement: 手順 4、 3の画像 3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
終わりに
For optimal performance, after completing this guide, calibrate your newly installed battery.
14 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
kewei xia
メンバー登録日: 10/01/19
477 ポイント
2のガイドは作成済み
13件のガイドコメント
I have a question, please. Are the two batteries identical?
Felipe L.R. - 返信
No, the batteries are different.
Battery 1 Part Number: 00HW022. (23.510 mWh)
Battery 2 Part Number: 01AV405. (26.330 mWh)
Best regards!
Rafael -
Hi there, anyone know which battery is number 1? - only battery 1 is broken in my laptop, 2 still works.
Jonas Andersen - 返信
Hello!!?? Any in iFixit knows the answer to Jonas’ question???
Ruben -
Battery 1 is 00HW022. (23.510 mWh)
Battery 2 is 01AV405. (26.330 mWh)
You can confirm it by yourself running powercfg /batteryreport on cmd
Hope it helps!
Rafael -
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 97
過去 30 日: 483
今までの合計 54,419
